buzzsaw204 Posted August 3, 2016 Share Posted August 3, 2016 hi, just a quick survey/question... what do you use in your practice, of Text vs. Rich Text for?? thanks, Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 3, 2016 Share Posted August 3, 2016 RT for almost everything Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 3, 2016 Share Posted August 3, 2016 me too, rt for everything but some things must use text Link to comment Share on other sites More sharing options...
ShaneK Posted August 3, 2016 Share Posted August 3, 2016 Text but I'm migrating to rich text and joining Joe Carrick macro club SOON. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 3, 2016 Share Posted August 3, 2016 Labels by default are simply Text. OTOH, any RTB can have macros and text formatted, colored, filled, etc. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 3, 2016 Share Posted August 3, 2016 Both...but mostly RT. Link to comment Share on other sites More sharing options...
johnny Posted August 3, 2016 Share Posted August 3, 2016 I use primarly standard text. Link to comment Share on other sites More sharing options...
Kiwideziner Posted August 3, 2016 Share Posted August 3, 2016 90% RT Link to comment Share on other sites More sharing options...
chief58 Posted August 3, 2016 Share Posted August 3, 2016 RT Link to comment Share on other sites More sharing options...
johnny Posted August 3, 2016 Share Posted August 3, 2016 I'm surprised so many use RT more often. For me I found tables very difficult to control...and I use a lot of footnotes on my plans. With standard text I simply "tab" to create new column and it stays put even if I need to resize text etc. RT in CA has been much more challenging IMO. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 3, 2016 Share Posted August 3, 2016 Johnny, The key to using tables in RT is to use a fixed font (Courier New). Within Macros, I use the .ljust(nplaces) and .rjust(nplaces) methods for each column. Link to comment Share on other sites More sharing options...
Northriver Posted August 3, 2016 Share Posted August 3, 2016 Rich Text. I am hoping for superscript in the next update. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 3, 2016 Share Posted August 3, 2016 Jeff, Some superscript (special) characters can be used by pressing the Alt Key and then entering the ASCII code. Chief also provides some built-in macros for that purpose. Link to comment Share on other sites More sharing options...
johnny Posted August 3, 2016 Share Posted August 3, 2016 Joe, are you saying that those macros fix the following problem with RT? Link to comment Share on other sites More sharing options...
Northriver Posted August 3, 2016 Share Posted August 3, 2016 Joe, can we now properly label our door and window sizes using superscript numerical characters? Is this something new in version X8? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 3, 2016 Share Posted August 3, 2016 Yes, "Test".ljust(20) + "This is a Test to show ........" "Test doesn't work".ljust(20) + "This will be aligned with the above" because the first part of both lines are padded to 20 characters. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 3, 2016 Share Posted August 3, 2016 On 8/3/2016 at 10:05 PM, Northriver said: Joe, can we now properly label our door and window sizes using superscript numerical characters? Is this something new in version X8? No, the only superscript characters we can use at present are 1,2, & 3. All of the other superscript characters require Ruby support for characters above ASCII-255. CA would need to add UNICODE support to Ruby or provide a custom font with the superscript characters 4,5,6,7,8,9 & 0 in a non-standard location. This is something I requested but I have no way of knowing if they will do either. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted August 3, 2016 Share Posted August 3, 2016 I think standard text has a HUGE (to quote Trump) advantage in that the size can be controlled on a dynamic basis by layer. (And therefore, anno set.) Rich text, once placed, is fixed in size. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 3, 2016 Share Posted August 3, 2016 On 8/3/2016 at 10:16 PM, Richard_Morrison said: I think standard text has a HUGE (to quote Trump) advantage in that the size can be controlled on a dynamic basis by layer. (And therefore, anno set.) Rich text, once placed, is fixed in size. Good point - which works perfectly for most Labels. But for custom data tables it prevents hiliting headings, paragraph titles, etc. That's where RT shines. Link to comment Share on other sites More sharing options...
Kelly_K Posted August 3, 2016 Share Posted August 3, 2016 A problem I have with rich text is you have to dig thru the dbx to turn on an arrow, and when you do it comes in unattached. Unless this was fixed with X8 ( I will say once the arrow is attached it behaves better than the one accompanying regular text). Most of my template text dates to 9.5 which frankly I think performs better with arrows connected than the X series of text. Link to comment Share on other sites More sharing options...
HumbleChief Posted August 3, 2016 Share Posted August 3, 2016 Text 99% of the time Link to comment Share on other sites More sharing options...
javatom Posted August 3, 2016 Share Posted August 3, 2016 Almost all text. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 4, 2016 Share Posted August 4, 2016 Rich Text 95% of the time and Regular text for charts and Hyperlinks. Link to comment Share on other sites More sharing options...
MoeGia Posted August 4, 2016 Share Posted August 4, 2016 Text almost exclusively. Link to comment Share on other sites More sharing options...
dshall Posted August 4, 2016 Share Posted August 4, 2016 On 8/3/2016 at 10:16 PM, Richard_Morrison said: I think standard text has a HUGE (to quote Trump) advantage in that the size can be controlled on a dynamic basis by layer. (And therefore, anno set.) Rich text, once placed, is fixed in size. Yes, this has been my thinking. However I am starting to using RT for boiler plate note blocks. Link to comment Share on other sites More sharing options...
