Dan_Park Posted August 7, 2015 Share Posted August 7, 2015 You can get the update using the media creation tool: http://windows.microsoft.com/en-us/windows-10/media-creation-tool-install Also if you are joined to a domain you won't get the update icon. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 7, 2015 Share Posted August 7, 2015 I get the icon, and it says my computer is ready, and ok. It just fails when update tries to download. I also have 600gb left on my hard dive Link to comment Share on other sites More sharing options...
Dan_Park Posted August 7, 2015 Share Posted August 7, 2015 If you have a different computer you might try downloading to a usb drive or dvd using the media creation tool? If just found this article: http://windows.microsoft.com/en-us/windows-10/upgrade-install-errors-windows-10 I'm not certain if it will help but it does list the problem I had. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 7, 2015 Share Posted August 7, 2015 Changing the size of the System Partition will destroy Win7's ability to Boot as you are moving the Start point of the Boot Partition on the HD, so make sure you also know how to do a Startup Repair with the Win7 DVD , you may need to run the startup repair 2-3 times before it works properly...don't panic if it doesn't work the 1st time you run it , it should auto attempt repairs once it locates the existing installation of win 7 and then reboot but may take more than one run through before it works. (remove the dvd between tries or it will boot from it again) M. Link to comment Share on other sites More sharing options...
country Posted August 7, 2015 Share Posted August 7, 2015 My laptop (Win7) wouldn't update from the update icon so I went to MS updates and downloaded from there. It worked just like every other update and is running fine. It just took some time and patience even with the SSD. Link to comment Share on other sites More sharing options...
builtright3 Posted August 7, 2015 Share Posted August 7, 2015 My laptop (Win7) wouldn't update from the update icon so I went to MS updates and downloaded from there. It worked just like every other update and is running fine. It just took some time and patience even with the SSD. My problem is patients! Messes me up because I click around to much. My computer has old timers disease "SLOW". Link to comment Share on other sites More sharing options...
Rich_Winsor Posted August 7, 2015 Share Posted August 7, 2015 Just to throw a cat amongst the pigeons, has anybody tried upgrading a machine with a dual boot configuration to Windows 10. i.e. upgrading from XP Pro/Win 7 Pro to XP Pro/Windows 10. Link to comment Share on other sites More sharing options...
Dan_Park Posted August 7, 2015 Share Posted August 7, 2015 I created a dual boot prior to upgrading from Win 7 and it remained after installing 10. We also had a system with a third party bool manager and it upgraded without issues. If upgrade the Win 7 your XP should remain. Your Win 7 would be changed to Win 10. Clearly the best advice is to back up everything prior to doing the upgrade. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted August 8, 2015 Share Posted August 8, 2015 Thanks Dan, it's comforting to know that someone has successfully accomplished this. Since I don't have this machine hooked up to the internet I'm thinking that I will use the method of creating a Windows 10 installation DVD and install it that way. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 8, 2015 Share Posted August 8, 2015 I have found out that my problem has to do with a section of the registry that is wrong, and won't allow the update to run, they will have a fix tomorrow, or a few weeks from now. Who knows. Link to comment Share on other sites More sharing options...
Doug_Park Posted August 10, 2015 Share Posted August 10, 2015 I upgraded my dual boot, Windows 8.1 and Ubuntu machine. The only issue I had was that the Grub2 boot loader reported Windows 10 as Window 8. This is probably a bug with how Windows 10 installs. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted August 10, 2015 Share Posted August 10, 2015 I use Outlook 20003 for email and contacts, calander. Does the new email handle all those functions? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 10, 2015 Share Posted August 10, 2015 It does in Win 8'1 and outlook 2010 Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted August 10, 2015 Share Posted August 10, 2015 Perry I assume Outlook 2010 was a separate purchase and did not come with win 8? Or did it? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 10, 2015 Share Posted August 10, 2015 Yes, had it since 2010 ,an upgrade from 2003. Now they want you to go with the subscription, outlook (office) 365. . I don't think they make a stand alone version anymore. Link to comment Share on other sites More sharing options...
jcaffee Posted August 10, 2015 Share Posted August 10, 2015 The built-in "Apps" are not particularly mature (functional). Office 365, or the free Outlook.com, are a better option at this stage. jon Link to comment Share on other sites More sharing options...
BryceEngstrom Posted August 10, 2015 Share Posted August 10, 2015 Trying to search for e-mails in Outlook 2010 was an exercise in patience and frustration. Ridiculously slow. I can search years of e-mails almost instantly in Gmail. And never mind having online access from anywhere. Looked into Outlook online before switching and didn't find it very highly rated. Link to comment Share on other sites More sharing options...
builtright3 Posted August 11, 2015 Share Posted August 11, 2015 I have office 365 and I love it!!! Subscriptions I think are the future more and more Link to comment Share on other sites More sharing options...
Kbird1 Posted August 11, 2015 Share Posted August 11, 2015 Jon, Maybe, but I'm most interested in getting my app windows to have the same "Frames, Title Bars, Icons, etc". This Theme addon may help with some of it Joe , I hate the all white look too.... http://www.tenforums.com/tutorials/7935-color-window-borders-title-bars-change-windows-10-a.html Link to comment Share on other sites More sharing options...
jtcapa1 Posted August 12, 2015 Share Posted August 12, 2015 Well MS is not very forthcoming about the bugs in this new OS. I ended up with the Login bug which gave a "Critical Errors" message asking to have you sign out. Its a recursive loop. Error message keeps popping back up, essentially making it impossible to log into your account or computer. Had to search the web for a while to discover this has been plaguing MS Win 10 for some time. You end up either having to revert back to your previous version, find a restore point, or create a new login user. My new recommendation is wait for MS to work out the bugs. You'll be much less stressed. Link to comment Share on other sites More sharing options...
country Posted August 12, 2015 Share Posted August 12, 2015 I had a major log out problem but contacted Support and they did their magic. No more problem and I really like Win 10. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted August 14, 2015 Share Posted August 14, 2015 Check this out for Window10 users (not sure if that works with Mac) Right Click on your Desktop and open a new Folder and it will give you an option to name it... Enter this as a folder name: GodMode.{ED7BA470-8E54-465E-825C-99712043E01C} and dbl click on the folder and you will have all your settings to Win 10 at your finger tips. Enjoy Link to comment Share on other sites More sharing options...
Rashid_Garuba Posted August 14, 2015 Share Posted August 14, 2015 There was a time I would run to the store and buy the latest windows but that past a looong time ago. Let's see... I was forced to finally stop using XP last year and move to Windows 7.. I wonder when I will move to 10... I do like the no re-installing programs idea though.... Link to comment Share on other sites More sharing options...
Kbird1 Posted August 14, 2015 Share Posted August 14, 2015 There was a time I would run to the store and buy the latest windows but that past a looong time ago. Let's see... I was forced to finally stop using XP last year and move to Windows 7.. I wonder when I will move to 10... I do like the no re-installing programs idea though.... In the next 9-12 months or it won't be Free M. Link to comment Share on other sites More sharing options...
Steve-C Posted August 15, 2015 Share Posted August 15, 2015 Check this out for Window10 users (not sure if that works with Mac) Right Click on your Desktop and open a new Folder and it will give you an option to name it... Enter this as a folder name: GodMode.{ED7BA470-8E54-465E-825C-99712043E01C} and dbl click on the folder and you will have all your settings to Win 10 at your finger tips. Enjoy Shut the front door! Love it! Link to comment Share on other sites More sharing options...
