Roof Issues
Designer100
Can anyone help me with this roof? You cannot use automatic roof etc. I have been messing with this for 4 hours trying to fix this roof. front to back is 8:12 and sides 10:12 and some sides 8:12.
It says to large to upload? what can I do?
Thanks
for any help.
chief architect x7
713.385.3622
newell.cheatheam@gmail.com
Luedeker 3.zip
The problem is that your geometry will not allow the roof planes to meet.
The one area that is a problem is the roof over Bath 3 and the Attic.
If you want to retain the existing roof pitches, you need to reduce the ceiling height in those 2 rooms to 238".
This will then allow the lower roof to build over those 2 rooms as a single plane.
The roofs CAN be built automatically - very easy.
Is this what you are after?
Here is the fixed plan with auto build roofs.
Apart from the problem with the ceiling heights at the rear of level 2, there were 2 roof pitches defined for the gable behind the chimney.
You will need to fix up the columns in the front porch.
If you don't want to drop the ceiling heights in the bath and attic, you will need to increase the pitch or height of the roofs coming up from the rear of the ground floor (if you want the upper and lower roofs to be coplanar).
Luedeker 3 fixed by Glenn (2).zip
Glenn, YOU never cease to amaze me!
I know, and with one hand tied behind his back on.................. gasp...................... imperial plans. That alone is worth an award. I love metric, and wish we would finally switch.
There's really nothing to learn. Everything is divisible by 10. And 1000sf is roughly 100sm. I did my first metric job a few years ago in Bangkok for a friend. It was a 230sm renovation of a condo. There wasn't any learning curve whatsoever.
Agreed,
I too thought it would be hard to learn, but there really was no learning curve at all. Very simple, never deal with fractions, and so much easier than imperial.
That's the beauty. There are no fractions. Just meters, centimeters, and millimeters. All divisible by 10.
In Oz, we don't even use centimeters, just meters and millimeters, but mostly just millimeters.
The only difference really is where the decimal point goes.
Yeah, in metric plans I've done, I simply just use mm (other than site stuff where meters are easier with smaller numbers). No thinking involved, no math, no calculators, no fractions, just easy.
That's a nice wish but be careful what you wish for.  It would cause a lot of teeth gnashing when trying to do a remodel in the USA.  All of our existing construction is based on 12" increments.  (304.8 mm) which would be a b****h to work with.  A meter is a nice module but I think (I could be wrong) most metric sheet goods are 1200x2400 mm (just under 4'x8').  Maybe it's 1220x2440 which is just over 4'x8'.  IAE, it's not really as simple as just changing the units.  Lots of manufacturing would have to be changed an a lot of old guys would need their brains re-wired.
Chief makes working in both formats easy - especially for dimensions.
You can choose to show both metric and imperial units by using the Secondary Format.
Or you can change the default Format between Metric and Imperial.
This means that you can draw a plan in imperial and then change the default format to metric and all the dimensions will change to metric - how easy is that!
Australia changed to decimal currency back in 1966 and 1971 for measurements.
What...Oz can do it, but the US can't!
Just to keep things consistent, maybe you should go the other way and go completely imperial and use Imperial pounds, shillings and pence for your currency!
They tried changing the gas pumps to liters (or was
that litres?) here a while back. I think it lasted about
six months. It's not that we can't change to metric
but rather we don't want to change. Besides Imperial
has a nice ring to it.
Heck, you metric guys are so screwed up you probably
only get 10 eggs in a dozen.  :P
    32065
    Shatimwene
    Shatimwene
  • Similar Content
    • By mprovost129
      Ever since I upgraded to X14 I've had an issue where the trim doesn't populate on some of my roofs / roof belts. Has anyone else had this issue? Maybe I should try reinstalling X14? These roofs were copied from the adjacent roof that has the trim and has the same properties. It just makes no sense. I sent a request to support, and they couldn't recreate it at the time.
      220804 - Krupa Residence - Lot 8C The Preserve at Brook St. Rehoboth, MA.zip
    • By EmmaCox
      I'm trying to draw a skirt roof but the fascia is not showing, see screenshot. Any ideas? I just updated to X14 so not sure if this is a glitch? I've never had issues with this in the past using older versions!
    • By KO1413
      Hi there
      I'm pretty new to Chief Architect and I have a project with a pretty bizarre roof line.  I'm SO close to connecting everything but I'm not sure how to have a roof slope in two different directions.  I've attached images of the section of roof I'm interested in fixing (if it's possible).  It's a triangle that connects to other roof sections at two of three corners.  However, one corner sits high because that section needs to slope in two directions.  I was hoping there was a way to select the two corners and simply join them and have the program figure out the slope needed for this but I can't seem to figure this out on my own.  Anyone have any tips/tricks/advice?
      Below is a OneDrive link to the .plan file I am working on:
      https://1drv.ms/u/s!AjJMbQMG7iV1gsch39gBGIlQ9B519Q
      I am using Chief Architect X14.
      Thanks in advance
      Kristy
    • By AndrewSopher
      Hello,
      I have run across a problem and I am having trouble figuring out the solution with energy heels. On the front porch I need a 43" energy heel, the back portion of the house I need a 18" energy heel and then the gables I need a 6'' energy heel. I manually generated the roof but was wondering the ways to determine the energy heels. Is the only way to solve this is by placing roof trusses and measuring from there? To go along with that question, I am wondering if I raise my roof planes through the Z delta (in the transform/replicate dbx) is that the same as what the energy heel would be if I were to place trusses and measure? Thanks.
