EmmaCox Posted 1 hour ago Share Posted 1 hour ago Hello, I'm trying to figure out how to deafult base molding for floor 0. I have it set up for floor 1, but my issue is on my template file I don't have floor 0 created yet, as I wait to draw the main floor and then build the foundation (floor 0) based on the main floor footprint. So in the default settings there is only floor 1 showing, no floor 0. I tried building the foundation plan on my template file, then adding the default baseboard, then deleting the foundation to see if the setting would stay, but it goes back to no base molding. Any ideas on how to add to add this? Should I already have floor 0 created on my template file? Thanks in advance! Link to comment Share on other sites More sharing options...
GaryOhmer Posted 46 minutes ago Share Posted 46 minutes ago Just curious why you want base in the foundation? Link to comment Share on other sites More sharing options...
EmmaCox Posted 41 minutes ago Author Share Posted 41 minutes ago (edited) 27 minutes ago, GaryOhmer said: Just curious why you want base in the foundation? Because we use it as the basement plan, a lot of our plans have walkout finished basements. Maybe we should have floor 0 as basement and then foundation below it? Edited 18 minutes ago by EmmaCox Link to comment Share on other sites More sharing options...
