mtldesigns Posted May 8, 2021 Share Posted May 8, 2021 I got a request from a builder wondering of we can do MLS floor plans? I've done many plans for this guy and we reproduced the same plan for multiple builds, now he wants to market as his competitors do. He sent me an example of how he wants these to look (compliments of Lennar Homes). Trying to think the best way to go about this with Chiefs layer sets. You guys/gals do any of these and have some tips you could share? Link to comment Share on other sites More sharing options...
rgardner Posted May 8, 2021 Share Posted May 8, 2021 Use the wall hatching tool and a poly line with background color set to right level with draw order tool. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 8, 2021 Share Posted May 8, 2021 You don’t even need any polylines. You can just use the Room Fill. Link to comment Share on other sites More sharing options...
LevisL Posted May 8, 2021 Share Posted May 8, 2021 17 minutes ago, Alaskan_Son said: You don’t even need any polylines. You can just use the Room Fill. One drawback with room fills is you'll get white gaps at doors and doorways. A polyline on the back drawing group gives a better look I think. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 8, 2021 Share Posted May 8, 2021 1 hour ago, LevisL said: One drawback with room fills is you'll get white gaps at doors and doorways. A polyline on the back drawing group gives a better look I think. True tale. Link to comment Share on other sites More sharing options...
lbuttery Posted May 8, 2021 Share Posted May 8, 2021 My partner Joe was doing these prior to 2008 I don't have any samples handy at this time with everything having been archived when we closed the business in 2012 Lew Link to comment Share on other sites More sharing options...
rgardner Posted May 8, 2021 Share Posted May 8, 2021 10 hours ago, Alaskan_Son said: You don’t even need any polylines. You can just use the Room Fill. That is the easy way but as Levi mentions 9 hours ago, LevisL said: One drawback with room fills is you'll get white gaps at doors and doorways. A polyline on the back drawing group gives a better look I think. the filled poly line in a drawing group behind the hatching gives it through the openings. Link to comment Share on other sites More sharing options...
mtldesigns Posted May 8, 2021 Author Share Posted May 8, 2021 7 hours ago, rgardner said: filled poly line I did the filled polyline. I tried the room fill, but that's not a layer I can turn off, so as not to mess with the plan set. My first attempt. Not liking the white closet shelving, but maybe that will be ok. Whatcha guys think of my first attempt? Maybe another stream of income, huh? Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 8, 2021 Share Posted May 8, 2021 9 minutes ago, mtldesigns said: Not liking the white closet shelving Having Fill Control by layer on ALDO would fix that, something I've requested Link to comment Share on other sites More sharing options...
mtldesigns Posted May 8, 2021 Author Share Posted May 8, 2021 4 minutes ago, Chrisb222 said: ALDO what's ALDO Chris? Prob a dumb question, but its got be baffled. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 8, 2021 Share Posted May 8, 2021 16 minutes ago, mtldesigns said: Whatcha guys think of my first attempt? Maybe another stream of income, huh? Since you asked.... Here goes. I do like the blue of the water fixtures on the original that chief is also capable of. Since you did the polyline fill it would be great to break it and pull it away from the interior window sills. Vanities and shelves could be the same fill color. ALOD - Active Layer Display Options. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 8, 2021 Share Posted May 8, 2021 36 minutes ago, mtldesigns said: I tried the room fill, but that's not a layer I can turn off As Levis already pointed out, there are other good reasons not to use room fills, but for this one, you just need to turn off the "Rooms" layer. Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 8, 2021 Share Posted May 8, 2021 2 hours ago, mtldesigns said: what's ALDO Chris? Prob a dumb question, but its got be baffled. Active Layer Display Options panel Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 8, 2021 Share Posted May 8, 2021 1 hour ago, Chopsaw said: Vanities and shelves could be the same fill color. Wouldn't those settings then appear on all Plan Views? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 8, 2021 Share Posted May 8, 2021 2 minutes ago, Chrisb222 said: Wouldn't those settings then appear on all Plan Views? Yes quite possibly. I would like to see fill and material by layer options in ALDO. Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 8, 2021 Share Posted May 8, 2021 1 minute ago, Chopsaw said: Yes quite possibly. I would like to see fill and material by layer options in ALDO. I made that suggestion two years ago Link to comment Share on other sites More sharing options...
Chopsaw Posted May 9, 2021 Share Posted May 9, 2021 6 minutes ago, Chrisb222 said: I made that suggestion two years ago You forgot material but lets see if we get fill style first I guess. Link to comment Share on other sites More sharing options...
rgardner Posted May 9, 2021 Share Posted May 9, 2021 17 hours ago, mtldesigns said: Not liking the white closet shelving, but maybe that will be ok. BTW you can change the white in the shelving by changing the 2d part of the symbol. Personally I like the white. I also modified that symbol to put stretch planes on the shelf part of the symbol so that when it was stretched it doesn't distort the hangers. You only have to place one one each wall that way and when you stretch it the hangers stay to one end. Link to comment Share on other sites More sharing options...
robdyck Posted May 9, 2021 Share Posted May 9, 2021 20 hours ago, mtldesigns said: Whatcha guys think of my first attempt? You asked...and no offense but I think it looks pretty bad. If your client wants it to look the example you provided, then you'll probably want to make a CAD detail from your floor plan, or use a SVP so you can add filled polylines in order to exactly replicate the example, including the text font and size, and all other fills. BTW you can use the color eyedropper to match those fill colors exactly. Then, you'll have a satisfied client, and a SVP and layer set and fill and text items that you can easily reuse. Link to comment Share on other sites More sharing options...
mtldesigns Posted May 9, 2021 Author Share Posted May 9, 2021 5 hours ago, robdyck said: I think it looks pretty bad Guess what Rob, he agrees. He doesn't like the fill after all. Just the solid hatch for walls, and white (no fill) for each room. Now that is easy. BTW I did make a SVP for this and layer set. Link to comment Share on other sites More sharing options...
lbuttery Posted May 10, 2021 Share Posted May 10, 2021 suggestion, use blue fill for the sinks etc., so they have water in them Lew 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted May 10, 2021 Share Posted May 10, 2021 Hi Michael, I don't do much of these but if it's a serious venture it seems it would not be that difficult to build up a library of the various fixtures including colors, hatching etc. that the client wanted then used in any future plans. There are some limitations, since I assume this will be built off an original floor plan, and saving as a new 'MLS plan' with differently filled walls and fixtures would not lend itself to future changes in both plans. Would like to see what you come up with as a solution. Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 10, 2021 Share Posted May 10, 2021 On 5/8/2021 at 5:28 PM, mtldesigns said: Whatcha guys think of my first attempt? Maybe another stream of income, huh? Here's my, hopefully helpful critique. Don't use so many different line and text colours. Text should be black. All lines black or varying degrees of grey. Blue fills for water in tubs, sinks, etc... When you have to use a different color to highlight cabinets or shelving then make it just a darker shade of your room color. For example, that purple Chief line color for cabinets is horrendous. Unfortunately its OOTB in Chief and we all get used to it and think it's great. Just like Chief's "Blueprint" text. Yuck. Nothing says noob draftsman as a dated artificially architectural script like that text style, cringe inducing if you ask me. Reminds my of how impressed we were with 3D lettering back in the late 80's on our Commodore 64. It's dated. 1 Link to comment Share on other sites More sharing options...
