sthieldesign Posted May 26, 2022 Share Posted May 26, 2022 I am missing a lot of images that were on my Layout Pages. I backed up My Layout - Extracted the Files- Placed the images in the same file folder. I still am missing the images? How do I retrieve these without having to redo the entire page again? How do I keep this from happening? Thank you SusanAMBROSE LAYOUT FILE.layout Link to comment Share on other sites More sharing options...
sthieldesign Posted May 26, 2022 Author Share Posted May 26, 2022 I transferred to X-14 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 26, 2022 Share Posted May 26, 2022 Hi Susan, You need to check where those original images were located. Then you need to set the picture boxes in X14 to either use that location or copy them to the location that X14 is using. Link to comment Share on other sites More sharing options...
sthieldesign Posted May 26, 2022 Author Share Posted May 26, 2022 Thank you! I use two computers and go back and forth. Link to comment Share on other sites More sharing options...
Kiwideziner Posted May 26, 2022 Share Posted May 26, 2022 You will need to have the exact same file path on both computers, or CA wont find links. Link to comment Share on other sites More sharing options...
HumbleChief Posted May 26, 2022 Share Posted May 26, 2022 ..and see if the images have a 'save in plan' setting. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 26, 2022 Share Posted May 26, 2022 4 minutes ago, HumbleChief said: ..and see if the images have a 'save in plan' setting. The problem is the images are in the Layout, not the Plan. AFAIK, there's no "save in layout" for the images. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 26, 2022 Share Posted May 26, 2022 3 minutes ago, Joe_Carrick said: AFAIK, there's no "save in layout" for the images. There was in X13. Link to comment Share on other sites More sharing options...
HumbleChief Posted May 26, 2022 Share Posted May 26, 2022 6 minutes ago, Joe_Carrick said: The problem is the images are in the Layout, not the Plan. AFAIK, there's no "save in layout" for the images. Didn't think about that Joe, but I do see a 'save in plan' option in Layout, mis-worded obviously. Link to comment Share on other sites More sharing options...
robdyck Posted May 27, 2022 Share Posted May 27, 2022 I recommend copy / pasting images directly into the layout file. No path needed, simply double click the image and ensure Save in Plan is checked. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 27, 2022 Share Posted May 27, 2022 17 hours ago, robdyck said: I recommend copy / pasting images directly into the layout file. No path needed, simply double click the image and ensure Save in Plan is checked. Also what I do so the Layout can never "lose" the Image if for example a Folder is moved or deleted etc or I open it on my Laptop vs Desktop. M. Link to comment Share on other sites More sharing options...
lbuttery Posted May 28, 2022 Share Posted May 28, 2022 "and see if the images have a 'save in plan' setting" this works in plan and layout I have "moaned" about this problem since 2006 my partner also suffered from it we shared plans back and forth and invariably we would have to request the missing image(s) from each other I use layout to create my historic presentations and over time move folders/files around and then when accessing the presentation I get hit with the "missing image(s)" messages this should have been fixed decades ago images should automatically be "save in plan" with a preference or default to pop a warning if auto "save in plan" is turned off or even no warning if desired there is no reason that is "issue" can't be fixed Lew Link to comment Share on other sites More sharing options...
Dermot Posted May 28, 2022 Share Posted May 28, 2022 We have a tool to help with this: https://www.chiefarchitect.com/support/article/KB-00987/using-the-backup-entire-plan-project-tool-to-send-files-to-another-user.html Link to comment Share on other sites More sharing options...
lbuttery Posted May 29, 2022 Share Posted May 29, 2022 Dermot: please see my reply this "issue" is a real PITA and the fix is so simple ... Lew Link to comment Share on other sites More sharing options...
Kbird1 Posted May 29, 2022 Share Posted May 29, 2022 On 5/28/2022 at 8:02 AM, Dermot said: We have a tool to help with this: https://www.chiefarchitect.com/support/article/KB-00987/using-the-backup-entire-plan-project-tool-to-send-files-to-another-user.html Only if you are at the Original Computer AND the Images haven't gone missing there too? ( eg an accidental folder deletion or Folder moved ) , which doesn't help if you are at Home vs the Office or on the other side of the Country ...or even Planet..... Like Lew I'd prefer this Was a Preference , so the User can leave it Default ( have checkbox set on ) ie. As Is or we can Check a Box to ALWAYS Save in Plan/Layout , with an additional Checkbox for adding the Image to a Folder inside the Textures Folder ( as CA does with new Material Textures now ) so it can never be lost. ( Optional ) M. Link to comment Share on other sites More sharing options...
Smn842 Posted May 30, 2022 Share Posted May 30, 2022 I would like an easy way to review the file paths of all referenced content from plans and layouts to ensure there aren't any unexpected locations used as per my suggestion here: I take care with content locations but even so a few unexpected file locations have ended up referenced in plans due to some hurried changes. Using debugging tools show Chief can search a large number of locations for referenced content which is good to keep things working, but also makes it easier for missing file issues to crop up quite some time later. Link to comment Share on other sites More sharing options...
