better looking grass?
SH_Canada
doing a mini subdivision and well the grass leaves something to be desired
Looking through the forums I saw something a few years ago on bump maps but no details and nothing in  the doc
I see one of the finmalists has some fairly good looking terrain. I think maybe he/she spread lots of short shrubs or something
2021 Chief Architect Design of the Year Contest Finalists | ChiefBlog
this is what I have so far ...needs some work
This image shows Chief's "Grass 7" which is one I often use with minor adjustments.  It is in the core catalogs/ materials/ landscaping/ grass.   I enlarged the grass area around the house to show an area more similar to the size you are working on, and then set the x/y scale in the Define Materials dbx under the Texture tab, at 200 each.  The rectangle of grass to the right is the same Grass 7 material, but at the library default of x/y scale at 56 and no blended color.  Depending on how zoomed in or out the view is, it can be helpful to adjust the x/y scale.  More zoomed out, the larger the scale.
Then the second thing I change, which you can see in the second image, is to adjust the Material Color by blending in a slightly darker shade of green.  I find the darker green adds to the realism. This view does not have any bump maps.  Those can help too, but you might first try adjusting the scaling and material color.
Expand
thanks. this is an improvement
  On 12/7/2021 at 5:15 AM, jasonN said:
thats what I figure the finalist may have used.
Expand
They used twinmotion :) , that background cityscape is twinmotions native cityscape.
Here. one of my best grasses, just throw my name out there if someone ever needs work please(shameless plug), I don't often give my best stuff out:
Rabs Mowed Lawn
MAKE SURE TO ADJUST BUMP HEIGHT DOWN FOR RAYTRACE
  • Like 3
  • Upvote 2
Expand
Grass 7 is the one I also prefer too but usually darken it some....
I also use this one which if I remember correctly was posted here on the Forum a few years ago ( sorry forget name now)
MHD_Grass - Rich Green.calibzFetching info...
thanks guys. Normally I do not care but they decided to print it on 24x36, so it looked very very "basic". I have it at the grass 7 with the x y changed, which actually looks not bad. But I'll try the above two. i tried the high def grass but it looks too perfect. I need some variance, and ideally more like wild grass as this is not a city suburb, but in the middle of nowhere on the prairie.
I downloaded twin motion last night, havent figured out to export from twinmotion yet, just playing around with it in twinmotion. probably cant export it because I haven't purchased it...
Expand
Have you tried the CA Bonus catalog for High-Resolution Grass?
https://hometalk.chiefarchitect.com/gallery/image/948-materials-high-resolution-grass/
You might also want to look into seamless textures. Grass is one that benefits but not as much as shingles, stone, that type of thing. The repeating pattern is what looks bad, IMO, and seamless textures really reduce the problem. Just search online, there are tons of free ones.
Yes I find that turning down the Diffuse is the key to getting things to look a lot better. It's always set to 100% and that's almost never correct - I ususally bounce between 75-85% on most things as it looks better.
  On 12/8/2021 at 5:01 AM, Christina_Girerd said:
es, helpful detail to make sure the grass is "matte" and adjust diffuse.  I do this too, forgot to mention it.
Expand
