Member Statistics
Similar Content
By Ange822
Good morning,
I'm wondering if there is an easier way to mass delete surfaces when trying to edit a symbol. This specific example was a light fixture I downloaded from 3D warehouse. When imported however I noticed the user had added an image beside the light fixture. So I went to try and edit the symbol / create a new symbol without that figure. Come to find out that the dress has a bunch of Polkadots on it and each dot will need to be deleted.
In conclusion, I wasn't sure if there was a way to delete this large area faster than clicking on each individual dot. I have run into this before with other symbols trying to edit them but I would just give up and not proceed as it would take forever to delete all surfaces.
By Ange822
Good afternoon,
I'm looking for a way to change a texture image. Not sure if there is a free photoshop type of program that can be used.
I would like to achieve the flagstone with a Natural Red / Brown Granite texture, and the fill between to be a Gravel texture.
thanks in advanced!
By COMSTOCKL35
Hello everyone,
having an issue getting x14 to report the information my estimator is asking for. we primarily focus on remodels, therefore a vast majority of our projects require demo work. we stick estimate and account for sf, lf, area, and each of items for removal. In a lot of cases this is not a across the board or entire area basis or even within complete room. My team has been inquiring if the program has the arability to produce a schedule i can put on layout so they don't have to physically do the calcs for the area of drywall being removed then reinstalled. i understand i have to run a material list to have the program run the total. i have figured out how to get the program to total Base, Casing, Flooring, Ceiling area, electrical and plumbing fixtures. im wanting to see if there is some way i can set this up to pull with the ease of a schedule without having to go in and create a material list for each room involved write down the area from that then say create a room list for every program. thining there might be a macro or some way to achieve this in a custom schedule and have ran into a wall every way ive tried to run it or set it up. i will attach the current project im working on for reference. the rooms im looking to complete said schedule or report are listed in the room area schedule to the right of the 1st floor plan23-6416-Newton-Existing.plan
23-6416-Newton-Existing.zip
By LCDesign
How do I change my architectural block defaults so that the "display bounding box" is off as my default? I currently go into each architectural block and turn off the "display bounding box" for each block I create. I've looked through Chief Help and can't find this answer. Premier X14.
By Tlcurtis2a
I've drawn the floorplan for the 7700 SF clubhouse of a development we are building. I need someone to actually do the finishes for the 3D and renderings. I also need someone to finish the terrain work and exterior areas including portico with circular driveway and parking areas, pickleball courts, pool, outdoor seating and firepits. Thank you! Please let me know if you are interested in taking this project and need price for your work.
