BruceKC Posted February 8, 2021 Share Posted February 8, 2021 Is there a way in X12 to have segmented arrow lines rather than one straight line all the time? I know I can break the line and then make it do what I want, but I really don't want to do that to every single note on the plans when I'm pointing to something. I've included what I want to do. Link to comment Share on other sites More sharing options...
JJohnson Posted February 8, 2021 Share Posted February 8, 2021 Simply draw the horizontal segment, release the mouse button, hover over the arrow, click again and draw angled line, arrow will appear at end, just like your picture. Link to comment Share on other sites More sharing options...
Doug_N Posted February 8, 2021 Share Posted February 8, 2021 And if you don't have enough segments, after you do the text you can break the leader and add more segments. The "3" key is very useful. Link to comment Share on other sites More sharing options...
glennw Posted February 9, 2021 Share Posted February 9, 2021 There is a Leader Line default at Preferences>Appearance>Text>Leader Lines>Number of Segments. Or you can use a Text Line With Arrow and draw it in Continuous Mode (right mouse button) and draw as many segments as you want. Link to comment Share on other sites More sharing options...
SNestor Posted February 9, 2021 Share Posted February 9, 2021 Glenn beat me to it...but, it's defined in Preferences... Link to comment Share on other sites More sharing options...
Dermot Posted February 9, 2021 Share Posted February 9, 2021 There are lots of different ways to do what you want. - You can use the "Text Line with Arrow" tool to draw a segmented line the same way you can draw normal segmented lines. Just click near the endpoint of the arrow line and draw another segment that should automatically connect to the previous segment. Or you can right-click to draw multiple segments at one time. - You can select an arrow line and use the "Break" tool to add a break point the same way you can with normal lines. - You can select an arrow line and use the diamond shaped edit handle that appears off the end of the arrow to draw another connected line segment the same way you can with normal lines. - You can use the Leader Line tool to create a segmented arrow line along with the text object. The maximum number of segments that are created can be controlled in your preferences as well as whether or not the text object created is rich text or plain text. Please note that you can always create a leader line with less then the maximum number of segments by just clicking near the end point of the previous segment. More information about text and leader lines can also be found in this video: https://www.chiefarchitect.com/videos/watch/78/text-and-arrow-tools.html Link to comment Share on other sites More sharing options...
HumbleChief Posted February 9, 2021 Share Posted February 9, 2021 And wouldn't it be nice if we could add segments, as well and many other options (arrows, arrow types etc.) for Call Out Cross Section Lines? Something that would be used in EVERY plan on this desk and something that has been suggested for YEARS. Link to comment Share on other sites More sharing options...
GeneDavis Posted February 9, 2021 Share Posted February 9, 2021 Sometimes I like to do a whole plan in curves instead of segments. Draw the arrow horizontal, release mouse, then right away grab the arrowhead end and CRTL-ALT to curve it where needed. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 9, 2021 Share Posted February 9, 2021 4 minutes ago, GeneDavis said: Sometimes I like to do a whole plan in curves instead of segments. Draw the arrow horizontal, release mouse, then right away grab the arrowhead end and CRTL-ALT to curve it where needed. You could also be using the Arc with Arrow tool Link to comment Share on other sites More sharing options...
HumbleChief Posted February 9, 2021 Share Posted February 9, 2021 5 minutes ago, GeneDavis said: Sometimes I like to do a whole plan in curves instead of segments. Draw the arrow horizontal, release mouse, then right away grab the arrowhead end and CRTL-ALT to curve it where needed. Nice, What if we could do that with Call Out Cross Section Lines? Link to comment Share on other sites More sharing options...
rwdozier Posted February 9, 2021 Share Posted February 9, 2021 57 minutes ago, GeneDavis said: Sometimes I like to do a whole plan in curves instead of segments. Draw the arrow horizontal, release mouse, then right away grab the arrowhead end and CRTL-ALT to curve it where needed. That's awesome! Oh, the power of CA! Link to comment Share on other sites More sharing options...
HumbleChief Posted February 10, 2021 Share Posted February 10, 2021 I don't remember someone asking for a curved arrow added to a call out either but that's not the point of the posts above. Is it possible that you simply don't remember requests for segmented call out lines? Or custom arrows for same? Here's a couple posts from the suggestion forums. Not expecting anything to change in this regard and Chief (Dermot) obviously has no interest in the idea but it, again, is something I would use in every plan. Adding text lines to call outs should not be needed IMO, The options mentioned below should be (have been years ago) a part of any architectural program. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 10, 2021 Share Posted February 10, 2021 I really just wish that first part of the line could be locked at a horizontal angle regardless of how I move the text or the item I’m pointing to. Link to comment Share on other sites More sharing options...
Doug_N Posted February 10, 2021 Share Posted February 10, 2021 You can do that although the answer of how to do it is sort of counter intuitive. Also, the part that connects the arrow to the leader line is the part I am referring to, Link to comment Share on other sites More sharing options...
stephenbc Posted February 10, 2021 Share Posted February 10, 2021 It was the music that did it for me, Doug...so relaxing You are bringing support videos to a new level! Link to comment Share on other sites More sharing options...
Doug_N Posted February 10, 2021 Share Posted February 10, 2021 4 minutes ago, stephenbc said: It was the music that did it for me, Doug...so relaxing You are bringing support videos to a new level! LOL, i forgot it was on. Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 10, 2021 Share Posted February 10, 2021 54 minutes ago, Doug_N said: You can do that although the answer of how to do it is sort of counter intuitive. Also, the part that connects the arrow to the leader line is the part I am referring to, Unfortunately you are wrong sir. Scott Hall did a video about this a while ago. He exhausted all possibilities, and along with colourful language, he demonstrated that the horizontal aspect fails when you move the object you’re pointing to. You're demonstration only works if you are only moving the text box. (great video by the way, but please kill the music) Link to comment Share on other sites More sharing options...
Doug_N Posted February 10, 2021 Share Posted February 10, 2021 The demo only fails if you move the object vertically. If the object is moved horizontally, the relationship is maintained. The segment linked to the text box should be able to be linked horizontally or vertically. I think that should be a settable default option. As for the music we now are 50/50 on that topic. Link to comment Share on other sites More sharing options...
