johnny Posted September 28, 2015 Share Posted September 28, 2015 I have an issue where my counter-top that i used a fill for is covered my upper cabinets. I've tried to make the upper cabinet moved to front group but that doesn't change its display from being "behind" the custom counter. I'm using the counter-tops of my concept work - not wanting to mess with cabinets etc....except I do want to show some uppers for graphical display. Any help is appreciated. Peterson_res_concept.plan Link to comment Share on other sites More sharing options...
glennw Posted September 28, 2015 Share Posted September 28, 2015 Johnny, Select the countertop and make it the Back Group. Or, use the transparency setting for the countertop fill. Another tip: You can do away with the guide lines you have for the Dining and Living room centres. Use the Centre Object tool to locate the windows and room text. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted September 28, 2015 Share Posted September 28, 2015 Played with this in the provided plan and one of my plans. It seems that your only option is to change the countertops fill transparency. Trying to move the upper cabinet to the front does not work, maybe Chief sees these items as being in the same group. I have experienced this before, just can't remember where. If memory serves me correctly you can only control the movement of one group over the another group but not the order of items within a specific group. Not sure if there is a function in Chief that allows you to define the group assignment of an object? Graham Link to comment Share on other sites More sharing options...
HumbleChief Posted September 28, 2015 Share Posted September 28, 2015 Select/open the counter top>Line Style>Drawing Group>Back Group - Thanks Glenn Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted September 28, 2015 Share Posted September 28, 2015 Thanks Larry, would have never thought it would be under "Line Style". Was always using the "Move to Front of Group" command. Many Thanks for that, Graham Link to comment Share on other sites More sharing options...
HumbleChief Posted September 28, 2015 Share Posted September 28, 2015 Thanks Larry, would have never thought it would be under "Line Style". Was always using the "Move to Front of Group" command. Many Thanks for that, Graham No problem, Glenn had it figured out but perhaps a not so clear path to get there. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted September 28, 2015 Share Posted September 28, 2015 The only problem I have now is that the countertop is showing as if it is below the base cabinet. Is there a way to now move the base cabinet to the back of the group? Upper on top Counter in the middle Base at the bottom Graham Link to comment Share on other sites More sharing options...
MarkMc Posted September 28, 2015 Share Posted September 28, 2015 Not for nothing but I use a single cabinet for massing- one corner cabinet stretched, one along the wall, one for the island, suppress labels. The big advantage is that then the countertop overhangs are correct so that work aisle dimension are also correct. NKBA suggested minimum is 42" (yours are a tad less before overhangs) I'm always getting plans from architects that don't account for counter overhang. There are times that losing 3" to two counters is an issue giving the client what they want. Link to comment Share on other sites More sharing options...
dshall Posted September 28, 2015 Share Posted September 28, 2015 The only problem I have now is that the countertop is showing as if it is below the base cabinet. Is there a way to now move the base cabinet to the back of the group? Upper on top Counter in the middle Base at the bottom Graham Great question..... in fact I posed this great question to Brian "soon to be a Father" Beck at the UGM...... I think it was Brian.... quick answer, no. This has been my bane for many years ago. Apparently the problem is based on the fact that prior to turning countertops of base cabinets into custom countertops, the countertops and base cabs are inexplicitly tied to each other. As soon as the base cabinet relies on a custom countertop, all goes to he** in a hand basket. This is what I have been doing... I put the counter top on ... I think it is default layer (base cabinet is hidden now), I then draw a CAD line where base cabinet is, put that CAD line on base cabinet layer, and put in front group. By doing this, you can identify extent of base cab, the countertop hides the floor fill, and base cab looks good. This scenario is very common with custom countertops for islands. A PIA, but doable relatively quickly, upper cabs is more trouble..... yep, another cad line to represent the now hidden upper cabinet and give it a fill. There should be a way to fix this. I have been sending this into Brian for about 4 years now. It has not been fixed yet. I think they think it is trouble to fix. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted September 28, 2015 Share Posted September 28, 2015 Great question..... in fact I posed this great question to Brian "soon to be a Father" Beck at the UGM...... I think it was Brian.... quick answer, no. This has been my bane for many years ago. Apparently the problem is based on the fact that prior to turning countertops of base cabinets into custom countertops, the countertops and base cabs are inexplicitly tied to each other. As soon as the base cabinet relies on a custom countertop, all goes to he** in a hand basket. This is what I have been doing... I put the counter top on ... I think it is default layer (base cabinet is hidden now), I then draw a CAD line where base cabinet is, put that CAD line on base cabinet layer, and put in front group. By doing this, you can identify extent of base cab, the countertop hides the floor fill, and base cab looks good. This scenario is very common with custom countertops for islands. A PIA, but doable relatively quickly, upper cabs is more trouble..... yep, another cad line to represent the now hidden upper cabinet and give it a fill. There should be a way to fix this. I have been sending this into Brian for about 4 years now. It has not been fixed yet. I think they think it is trouble to fix. Same issue if you use a Polyline Solid for a countertop versus the custom countertop tool. I'll just keep using the countertop fill transparency setting in order to see the underlying base cabinets and uppers above. Graham Link to comment Share on other sites More sharing options...
HumbleChief Posted September 28, 2015 Share Posted September 28, 2015 I'll just keep using the countertop fill transparency setting in order to see the underlying base cabinets and uppers above. That seems a great/better solution, is there a down side? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 28, 2015 Share Posted September 28, 2015 As I see it, currently there are 4 basic solutions... 1. Adjust the transparacy of the countertop and leave it at the front drawing group. This has the downside of affecting the way the upper cabinets visually display. If transparacy is adjusted all the way to 100% it defeats the purpose of using a fill though which brings me to option 2... 2. Give the countertop no fill. This has the obvious downside of giving the countertop...well...no fill. 3. Give the base cabinbets and countertop the same fill color and send the countertop to the back drawing group. 4. Adjust the transparency of the base cabinet fill or remove the fill entirely. I think the latter 2 options are equally good. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 28, 2015 Share Posted September 28, 2015 I think #3 is the default OOB. I don't mess with it. Link to comment Share on other sites More sharing options...
MarkMc Posted September 28, 2015 Share Posted September 28, 2015 I'm missing something. I couldn't even remember what fills I use so had to check. I do roughs/massing with countertops on the default cabinet for clarity of overhang. After that is settled I use custom tops exclusively so that the cabinet height reads correctly in the schedule. Most often I'm building them from the icon, not converting them. Looks like I have the same fill for cabinets and counters when they start as default, and no fill for the ones I usually build. Hasn't been a problem. Attached screenshot-?? Link to comment Share on other sites More sharing options...
joey_martin Posted September 28, 2015 Share Posted September 28, 2015 But you are using a cabinet...johnny is not. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 28, 2015 Share Posted September 28, 2015 I'm missing something. I couldn't even remember what fills I use so had to check. I do roughs/massing with countertops on the default cabinet for clarity of overhang. After that is settled I use custom tops exclusively so that the cabinet height reads correctly in the schedule. Most often I'm building them from the icon, not converting them. Looks like I have the same fill for cabinets and counters when they start as default, and no fill for the ones I usually build. Hasn't been a problem. Attached screenshot-?? In your middle example, try giving the countertop a fill. This is where some people start to perceive a problem. Link to comment Share on other sites More sharing options...
MarkMc Posted September 28, 2015 Share Posted September 28, 2015 I see, thanks Michael, guess that's why I use no fill for those :0 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 28, 2015 Share Posted September 28, 2015 I see, thanks Michael, guess that's why I use no fill for those :0 Yeah, I don't have a problem with it myself. I could see where some people might though if they like to give countertops a different fill style and/or color especially. In that case, I think the best solution is #4 in my post above... "4. Adjust the transparency of the base cabinet fill or remove the fill entirely." Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted September 28, 2015 Share Posted September 28, 2015 I think #3 is the default OOB. I don't mess with it. Just checked this out. You are correct #3 in Michael's list seems to be the default configuration. As you indicate no need to mess with it, unless there is a need to assign a different fill colour to the countertop. If this is the case then you either send it to the back or set a transparency level. Regardless of the chosen method, there will be some obscuring of objects below or colour blending where colours overlap. If it's worth while thinking about then how else could it be? I hate saying this but "it is what it is". Graham Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 28, 2015 Share Posted September 28, 2015 Sometimes I give the wall cabinets a xhatch fill - but I don't use a "solid" fill other than the defaults as mentioned above. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 28, 2015 Share Posted September 28, 2015 I'm not quite sure where I saw this method; I think Joey Martin. It uses a transparent hatch fill for the upper, which shows whatever is below. Much better for presentations and condocs IMO. Mike Link to comment Share on other sites More sharing options...
dshall Posted September 29, 2015 Share Posted September 29, 2015 I'm not quite sure where I saw this method; I think Joey Martin. It uses a transparent hatch fill for the upper, which shows whatever is below. Much better for presentations and condocs IMO. Mike cabinet fill.jpg I did the transparent cross hatching at one time, but now I leave the OBB white fill (I think that might be NKB norm), but I give the white fill a semi transparent fill..... I like it better than the crosshatching . Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 29, 2015 Share Posted September 29, 2015 I did the transparent cross hatching at one time, but now I leave the OBB white fill (I think that might be NKB norm), but I give the white fill a semi transparent fill..... I like it better than the crosshatching . I will try this method just to see how it looks and prints. I notice on my machine that when I do several solid white fills, especially for polyline shading, it begins to slow down my zooms and pans noticeably. I wouldn't call it "sluggish" so much as "annoying." Link to comment Share on other sites More sharing options...
dshall Posted September 29, 2015 Share Posted September 29, 2015 ...... I notice on my machine that when I do several solid white fills, especially for polyline shading, it begins to slow down my zooms and pans noticeably. I wouldn't call it "sluggish" so much as "annoying." Interesting, I had not noticed, I know that if I used a lot of CONCRETE FILLS, I did get the sluggishness, I don't notice it so much any more, I think my machine is faster than it was. But again, I had not noticed white fills slowing down the 'puter, in fact I would guess the white fill would be faster than a cross hatch....... maybe CA would not mind commenting on what kind of fills slow down the 'puter. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 29, 2015 Share Posted September 29, 2015 Some of my slow down is probably due to my video card; good for its day but it's not the fastest by any means now - 5-years old, which is a "dinosaur" by today's standards. Will upgrade at some point, but may wait and just replace workstation. [edit] If any of you guys have a better nVidia card than mine just lying around collecting dust let me know. Link to comment Share on other sites More sharing options...
