SNestor Posted August 2, 2021 Share Posted August 2, 2021 Is there some possible way to create a detailed footing plan with dimensions? Seems footings do not have any snaps...so, it appears the only way to create a footing plan that can be dimensioned is to create a cad detail...then paste that bsck onto the footing plan? Am I missing something simple here...or is this our only option? Using X13 Premier Link to comment Share on other sites More sharing options...
rgardner Posted August 2, 2021 Share Posted August 2, 2021 On 8/2/2021 at 1:57 PM, SNestor said: Is there some possible way to create a detailed footing plan with dimensions? Seems footings do not have any snaps...so, it appears the only way to create a footing plan that can be dimensioned is to create a cad detail...then paste that bsck onto the footing plan? Am I missing something simple here...or is this our only option? Using X13 Premier Expand I had the need to do this about a year ago and found no other way to do it at that time other than turning on footing turn off foundation walls and then place polylines over the footings (did allow me to place different hatches for different types and heights of footings which was a bonus). Then I was able to dimension to the footings. But it was not dynamic and also something that I would not normally do for a client but this was for a friend. Link to comment Share on other sites More sharing options...
SH_Canada Posted August 2, 2021 Share Posted August 2, 2021 I noticed I can add/alter the dimension(I used the auto exterior below) to dimension to the footing but only if the "walls, foundation" is displayed in ALDO. If you do not display it, it does not work as it will not snap. The 3'10 wall below is p2p and not adjusted when the wall is extended (bit that is probably more my ignorance of how to dimension probably), the 11'6 changes if I move the foundation walls, or the 3'10 wall) Link to comment Share on other sites More sharing options...
rgardner Posted August 2, 2021 Share Posted August 2, 2021 On 8/2/2021 at 6:32 PM, jasonN said: The 3'10 wall below is p2p and not adjusted when the wall is extended (bit that is probably more my ignorance of how to dimension probably) Expand p2p is exactly that not snapping to anything but rather going to the point you indicate with your cursor. Link to comment Share on other sites More sharing options...
SH_Canada Posted August 2, 2021 Share Posted August 2, 2021 On 8/2/2021 at 8:05 PM, rgardner said: p2p is exactly that not snapping to anything but rather going to the point you indicate with your cursor. Expand it seems to snap to objects... and the dimension changes if I move the wall that I drew the p2p between. see attached video i thought I read somewhere that if there was an object in the vicinity, it did snap, but if there is nothing, then it goes to wherever you click. bandicam 2021-08-02 14-17-20-231.mp4Fetching info... Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 2, 2021 Share Posted August 2, 2021 On 8/2/2021 at 8:21 PM, jasonN said: i thought I read somewhere that if there was an object in the vicinity, it did snap, but if there is nothing, then it goes to wherever you click. Expand You are correct, and if the p2p dim DID snap to something, it will move with the object like any other snapped dim Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 2, 2021 Share Posted August 2, 2021 On 8/2/2021 at 6:51 PM, solver said: Expand THIS. Link to comment Share on other sites More sharing options...
SNestor Posted August 3, 2021 Author Share Posted August 3, 2021 On 8/2/2021 at 6:51 PM, solver said: Expand At first I could not recreate what @solvershows in this video. I messed around with my "manual dimension" settings...and got things to work. I clicked a number of items on/off...so, now I'm not sure which item was the reason I got things to work. I think the item that may have done the trick for me was to click on "Wall Options"..."both wall sides"...and I unchecked "interior walls only". Here is a screen shot of my current "manual dimension" settings; Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 3, 2021 Share Posted August 3, 2021 No idea what you’re doing Steve. You shouldn’t have to mess with the Locate settings at all though. Those should only affect the behavior when dimensions are initially DRAWN. Your original post makes it sound like you don’t get snaps after the fact either. This just sounds wrong. Are you sure you’re not attempting to snap to footing in your reference display? Link to comment Share on other sites More sharing options...
GeneDavis Posted August 3, 2021 Share Posted August 3, 2021 Eric is clearly showing he has to edit the string after initial placement, to get the snaps to footings. Link to comment Share on other sites More sharing options...
SNestor Posted August 3, 2021 Author Share Posted August 3, 2021 On 8/3/2021 at 3:27 AM, Alaskan_Son said: Are you sure you’re not attempting to snap to footing in your reference display? Expand Definitely not trying to snap to reference display. As @GeneDavis stated…I have to draw a dimension that snaps to something- then sometimes I can edit that dim and drag it to the footing line to get a dimension. It’s a PIA… Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 3, 2021 Share Posted August 3, 2021 On 8/3/2021 at 11:40 PM, SNestor said: Definitely not trying to snap to reference display. As @GeneDavis stated…I have to draw a dimension that snaps to something- then sometimes I can edit that dim and drag it to the footing line to get a dimension. It’s a PIA… Expand That just sounds really weird. I have no problem snapping to the footing and don’t need to futz around with snap settings to do it either. Link to comment Share on other sites More sharing options...
DzinEye Posted August 4, 2021 Share Posted August 4, 2021 On 8/3/2021 at 11:50 PM, Alaskan_Son said: I have no problem snapping to the footing and don’t need to futz around with snap settings to do it either. Expand Seriously?...You can snap to the footing on the original dimension pull?? We need video proof Tape measure tool snaps to all parts of the footing, but dimension tool only snaps to the stemwall on the original pull... need to manually move it to the footing after placement. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 4, 2021 Share Posted August 4, 2021 On 8/4/2021 at 12:01 AM, DzinEye said: Seriously?...You can snap to the footing on the original dimension pull?? We need video proof Tape measure tool snaps to all parts of the footing, but dimension tool only snaps to the stemwall on the original pull... need to manually move it to the footing after placement. Expand I never claimed that. That’s not what we’re talking about though. The conversation has kinda shifted bit. That was the whole point of my second to last post. I believe Steve was originally saying he couldn’t snap to footings AT ALL. I was just saying snap settings shouldn’t have anything to do with that and that there must be something else going on. Link to comment Share on other sites More sharing options...
SNestor Posted August 4, 2021 Author Share Posted August 4, 2021 On 8/3/2021 at 11:50 PM, Alaskan_Son said: That just sounds really weird. I have no problem snapping to the footing and don’t need to futz around with snap settings to do it either. Expand I'm on a MAC...maybe there's a difference? Not sure... Link to comment Share on other sites More sharing options...
DG1949 Posted August 4, 2021 Share Posted August 4, 2021 On 8/4/2021 at 2:26 AM, SNestor said: I'm on a MAC...maybe there's a difference? Not sure... Expand I'm on Mac too and I find that if the layer "Walls, Foundation" is on, you can snap manual dimensions to the footings. When I'm done, I just turn off "Walls, Foundation", and have the result I want. Link to comment Share on other sites More sharing options...
SNestor Posted August 4, 2021 Author Share Posted August 4, 2021 @DG1949 - watch the attached loom video...let me know if this is the same experience you have with your MAC. Snapping Dimensions to footings - Example 21-0804 - Watch Video Link to comment Share on other sites More sharing options...
DG1949 Posted August 4, 2021 Share Posted August 4, 2021 Oops. Sorry Steve, I use point to point, not "manual" as I stated, and yes, I have exactly the same experience that you show in the video. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 4, 2021 Share Posted August 4, 2021 On 8/4/2021 at 2:24 PM, SNestor said: @DG1949 - watch the attached loom video...let me know if this is the same experience you have with your MAC. Snapping Dimensions to footings - Example 21-0804 - Watch Video Expand It seems like you moved the goalpost a little. In your original post you said.... On 8/2/2021 at 1:57 PM, SNestor said: Seems footings do not have any snaps...so, it appears the only way to create a footing plan that can be dimensioned is to create a cad detail...then paste that bsck onto the footing plan? Expand What you show in the video is what I get on my Windows machine as well. Footings do have snaps, and you don’t need to use a CAD Detail to dimension them. You just have to drag out new segments or move nodes after initial placement is all. I think you should send in a suggestion that footings be added to the Locate settings if this is something you really need. Link to comment Share on other sites More sharing options...
DzinEye Posted August 4, 2021 Share Posted August 4, 2021 On 8/4/2021 at 4:22 PM, Alaskan_Son said: It seems like you moved the goalpost a little. In your original post you said.... Expand On 8/2/2021 at 1:57 PM, SNestor said: Hmmm?... Did the goalpost move? I read Steve's post (goalpost?) with the emphasis on FOOTING. If he said FOUNDATION, then he'd of moved the goalpost.. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 4, 2021 Share Posted August 4, 2021 On 8/4/2021 at 5:06 PM, DzinEye said: Hmmm?... Did the goalpost move? Expand I think so. Yes. Read the post again. It clearly communicated that he couldn't get dimensions to snap to footings at all and that switching to a CAD Detail was the only solution. Steve even went on to further highlight this notion in a followup post when he said... On 8/3/2021 at 12:00 AM, SNestor said: At first I could not recreate what @solvershows in this video. I messed around with my "manual dimension" settings...and got things to work. Expand Bottom line though is this: Do footings have snaps? Yes Is a CAD Detail the only way we can dimension them? No Do Locate settings have any effect on the current behavior? No We can drag nodes after the fact as has been mentioned, we can use Point To Point Dimensions as has been mentioned (to effectively replace End to End Dimensions), and Locate settings have no effect on either of these operations. The only thing we can't do is use a running type dimension string like Manual Dimensions. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 4, 2021 Share Posted August 4, 2021 On 8/2/2021 at 8:31 PM, Chrisb222 said: You are correct, and if the p2p dim DID snap to something, it will move with the object like any other snapped dim Expand To be perfectly clear, Point to Point Dimensions will recognize and snap to footings running parallel to the wall, they just won't snap to or recognize the perpendicular footing lines that extend BEYOND the wall. Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 4, 2021 Share Posted August 4, 2021 On 8/4/2021 at 5:36 PM, Alaskan_Son said: To be perfectly clear, Point to Point Dimensions will recognize and snap to footings running parallel to the wall, they just won't snap to or recognize the perpendicular footing lines that extend BEYOND the wall. Expand that explains why I could not get my p2p to snap on my 3'10 footing above. seems like a bit of a bug to me, or at least it should be documented as such. I will log it with CA 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 4, 2021 Share Posted August 4, 2021 On 8/4/2021 at 9:00 PM, jasonn1234 said: I will log it with CA Expand Exactly the right thing to do. Link to comment Share on other sites More sharing options...
SNestor Posted August 5, 2021 Author Share Posted August 5, 2021 Thanks all for the helpful info... Dimensioning footings is not something I need on a regular basis...in fact almost never. Hardly worth the effort really. But - it's nice to know there are methods to accomplish this if needed. 1 Link to comment Share on other sites More sharing options...
