neo2222 Posted February 8, 2021 Share Posted February 8, 2021 I am trying to draw a shipping container house where there are 2 containers on top of 1 container and pilings. Really having a difficult time. Im trying to put layer one as the base container, layer 2 has 2 containers. I tried putting layer one with the main house of 2 containers,.. then build foundation of pilings, ...then tried to add the foundation container, where one side of each main house container sits on top of the foundation container.. From the end, it looks like a T. Has any one actually been able to draw a shipping container house? I tried using the CA models, but you dont have workable walls. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 9, 2021 Share Posted February 9, 2021 Have you tried a scaled model in Lego? 2 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 9, 2021 Share Posted February 9, 2021 9 hours ago, neo2222 said: Has any one actually been able to draw a shipping container house? I tried using the CA models, but you dont have workable walls. In order to get workable walls you'll have to very carefully model the shipping containers using very custom wall types, room definitions, etc. You can also model your shipping containers without the parametric tools by just using solids, or you could do a combination of methods. You won't simply be able to use a shipping container symbol though and you won't be able to use your normal everyday modeling techniques. It's entirely doable but pretty difficult if you're not very proficient with the software. It's just not something Chief was specifically designed to do. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted February 9, 2021 Share Posted February 9, 2021 Do all the 3d in Sketchup if you need to have photorealistic rendering. Here is some of the work done already. https://3dwarehouse.sketchup.com/model/7103927bd6995f507e7c9f487eee4fdb/Shipping-Container?hl=en You can use Chief for plans and elevations, with appropriate wall definitions and roof plane specs. 1 Link to comment Share on other sites More sharing options...
Kenoeightspot Posted February 16, 2021 Share Posted February 16, 2021 Define your walls based on container wall corrugation thickness, insulation and finish material. Find images of Shipping Containers and convert to material and apply to your walls. 2 2 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted February 16, 2021 Share Posted February 16, 2021 Nice "outside the box" thinking William! Link to comment Share on other sites More sharing options...
neo2222 Posted February 16, 2021 Author Share Posted February 16, 2021 39 minutes ago, Kenoeightspot said: Define your walls based on container wall corrugation thickness, insulation and finish material. Find images of Shipping Containers and convert to material and apply to your walls. Link to comment Share on other sites More sharing options...
neo2222 Posted February 16, 2021 Author Share Posted February 16, 2021 Thanks, thats what I figured,..It takes a little to figure out the height, and stacking, and any supports needed... I was jut hoping CA had something premade. Link to comment Share on other sites More sharing options...
Kenoeightspot Posted February 16, 2021 Share Posted February 16, 2021 CA does have shipping containers but you can not add doors or windows unless you paste and image of a window on the symbol. I also attached a prelim. project I did in Kansas. 1 Link to comment Share on other sites More sharing options...
Pawlakk Posted February 22, 2021 Share Posted February 22, 2021 I heartily recommend container houses, it is really a great thing ! Link to comment Share on other sites More sharing options...
HumbleChief Posted February 22, 2021 Share Posted February 22, 2021 1 hour ago, Pawlakk said: I heartily recommend container houses, it is really a great thing ! Yes highly recommended unless you need to pass the structure through a city's engineering department because as soon as you cut a hole in any wall that wall becomes structurally compromised and another, separate, super structure needs to replace that compromised structure. In a back yard with no inspections? Golden. In a regulated city environment? A real challenge. 1 Link to comment Share on other sites More sharing options...
neo2222 Posted February 22, 2021 Author Share Posted February 22, 2021 3 hours ago, HumbleChief said: Yes highly recommended unless you need to pass the structure through a city's engineering department because as soon as you cut a hole in any wall that wall becomes structurally compromised and another, separate, super structure needs to replace that compromised structure. In a back yard with no inspections? Golden. In a regulated city environment? A real challenge. looks nice, but the company is in Poland Link to comment Share on other sites More sharing options...
LouisD Posted May 25, 2021 Share Posted May 25, 2021 Wonderfully portraited the figures of containers! which tool is used for these depictions?I'm planning to build a house using shipping containers. It would be great help for me if someone explains the tool for drawing. Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 25, 2021 Share Posted May 25, 2021 9 hours ago, LouisD said: I’m thinking to build a house using shipping containers. It’s really the dumbest idea ever. You need to build out furred walls on the interior to run wiring, piping etc. You need to add furring on the outside to add air space and insulation onto which you need to add exterior cladding. You still need a decent slab to place them on. Give me one advantage. And don’t say, because they look cute or they are a recycled product, they’re not as most municipalities will only accept new containers for residential use. So what’s the point? What did you save? Somewhere, somebody is laughing their ass off. I’d expect to see this idea get traction on a diy website normally focused on papier-mâché but here?! 2 3 Link to comment Share on other sites More sharing options...
HumbleChief Posted May 25, 2021 Share Posted May 25, 2021 I actually designed a shipping container building in La Jolla CA (San Diego) and got it passed through the city. The container itself lost ALL of its structural integrity as we cut doors and windows and required an exterior steel exoskeleton to replace that lost structural integrity. Expensive and all around a silly adventure (never mind down right ugly) other than the homeowner who loved the idea, but not the reality. Throw one in your back yard out in the country for a shop but build one in the city? Best of luck and would love to learn your experience. Link to comment Share on other sites More sharing options...
Alchemyjim Posted May 25, 2021 Share Posted May 25, 2021 The biggest downside to the shipping container house is the fact that your are making a conditioned space inside a steel box. It WILL sweat unless you add at least 4" of closed cell spray foam. 1 Link to comment Share on other sites More sharing options...
joey_martin Posted May 25, 2021 Share Posted May 25, 2021 FBI: "We must not have humans in shipping containers, it's dangerous, and immoral!!" HGTV: "Let's put humans in shipping containers. It's sooo cool!!" 1 2 Link to comment Share on other sites More sharing options...
Rich_Winsor Posted May 27, 2021 Share Posted May 27, 2021 15 hours ago, John_Charles said: ...Was a big undertaking and enormously expensive. Would I ever recommend it to anyone? No.... but it does have its place.... Holy Cow! The only place I've seen that style of construction is at the Colorado Supermax prison. Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 27, 2021 Share Posted May 27, 2021 Well, I live very close to the original shipping container model housing complex, Habitat 67 in Montreal. Originally conceived as a solution to affordable housing, was a complete failure in that respect because it cost a fortune to build. Still a neat design, though. Credit to the architect. This is what happens when architects and city officials get together to figure things out in a bubble. Had they just asked any of their contractors they would’ve first laughed off their chairs and then told them why it was a dumb idea. https://en.m.wikipedia.org/wiki/Habitat_67 1 1 Link to comment Share on other sites More sharing options...
kMoquin Posted May 27, 2021 Share Posted May 27, 2021 Habitat is not made from shipping containers. (Unless they were making containers from precast concrete in '67.) I cant imagine why anyone would want to live in a shipping container. The proportions are terrible for living spaces. To rectify that you must modify/customize them beyond what any reasonable logic would allow. Insulation? Windows? Doors? I guess if you get the freezer unit your AC in taken care of. To totally contradict myself, I have always liked Snake Ranch. It is a a shipping container cabin designed to be packed with everything needed to build it and air lifted to some remote location. https://thomortiz.tumblr.com/post/143108198216/jones-partners-architecture-wes-jones Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 27, 2021 Share Posted May 27, 2021 42 minutes ago, kMoquin said: Habitat is not made from shipping containers. I know they are not made from containers. I was referring to the concept of stacking prefabricated boxes. Link to comment Share on other sites More sharing options...
misterwiley Posted January 15, 2023 Share Posted January 15, 2023 On 2/15/2021 at 10:14 PM, Kenoeightspot said: Define your walls based on container wall corrugation thickness, insulation and finish material. Find images of Shipping Containers and convert to material and apply to your walls. Hey William, Would you mind sharing your shipping container materials or images? I can't seem to find a good quality free ones online. Thanks! Link to comment Share on other sites More sharing options...
Kenoeightspot Posted January 15, 2023 Share Posted January 15, 2023 Here is a project that was designed this year using the images in the calibz. Adjust scale as needed. SHIPPING CONTAINER IMAGES.calibz 1 Link to comment Share on other sites More sharing options...
misterwiley Posted January 17, 2023 Share Posted January 17, 2023 On 1/15/2023 at 5:00 PM, Kenoeightspot said: Here is a project that was designed this year using the images in the calibz. Adjust scale as needed. SHIPPING CONTAINER IMAGES.calibz 176.11 kB · 9 downloads Thanks! Link to comment Share on other sites More sharing options...
