Adrean
Time to Show YOUR GOODIES!
Jeff, That is great.  I am hoping that @Adrean is following along with us here, and if you did upload to the Chief Viewer for testing purposes, then maybe you could also provide that link for comparison purposes in the hope that Chief will eventually catch up to this quality of rendering in High Definition without distortion.  Thanks Again. Great Work.
Here is the same 360 pano in the Chief 360 Panoramic Viewer.
View in Chief Architect’s 360° Panorama Viewer.
  • Upvote 2
Here are some non-360 pano shots of the same room using the same Physically Based Rendering settings as above.  They are saved at 3000 x 1534 at 600 dpi as a .png file just using the export command.  When I did a raytrace on these before, it took about 8 hours to get about 15 passes due to the details and lights.  These took about 90 seconds to save.  Huge time savings, especially if you want to show clients a few different options quickly.
5a77f0402854f_Office7.thumb.png.fbead19c6e95ff9672d95272679c948b.png  5a77f04f6218e_Office8.thumb.png.07ed1baf593a8eefe35bc35622b88e0c.png
On 7/9/2014 at 2:37 AM, Rich_Winsor said:
Here is my latest entry in CA's Pool design contest.
In paying homage to the great M. C. Escher I have
created a self-filling pool. The secret is all in your
point of view. B)
 Nicely Done!
Well, I can honestly say your work is the first  living proof “I have seen” that in the right hands quality results are achievable in Chief X10. Not that others have not shown us some good stuff, you Sir, have backed up your work up with “How it is done in the real world” example of what X10 can produce.
This harkens back to a thread I started over a year ago (will send you the link) where “Chief Only” RT work could be shared so the “Rest of Us” could learn how to master RT without the aide of third party post production. The intent, which never took root, was for user to produce simple yet thorough video of their process. Showcasing ones work is nothing more than grandstanding but to share your fndngs shows the mark of a true gentlemen and professional.
Absolutely stunning work. Thank you for sharing,
On 11/17/2017 at 4:25 AM, Rich_Winsor said:
Who says that you can't achieve "photo quality" Ray Traces with Chief?
I would be willing to wager that the creator's of Chief never imagined that
this image would be generated with their software. B)
Rick,
This is the best example of RT ever...amazing results produced completely inside of Chief...I gave you thumbs up for this one too.
I just posted to DesignerInk’s beautiful work and step to reproduce. Would you do the same for with your image? Again, absolutely stunning.
Thanks for sharing,
Very nicely done! Please keep posting your PBR results so we can see the potential of this new feature. I've been on the fence about this feature but your example will most likely encourage me to revisit the PBR camera and explore it more. One thing about PBRing I'm not so pleased about is how it handles objects with Glass such as in light fixtures, the glass comes out flat looking and lackluster. Hopefully CA will address this or someone will find another material property setting that will do a better job.
Thanks for sharing.
Very well done!
Just a note concerning your Ray Trace time. Here is an example of a Ray Trace I just ran, it has about 30 active lights and the size is 3000 X 1565. 15 passes took 11 minutes.
I believe there must be something about your lighting or Ray Trace settings that is resulting in such long Ray Trace times.
Here is the same scene Ray Traced at my usual 1200 X 626. It took only 2 minutes for 15 passes.
Could maybe post your light settings for the lights and overall ray trace settings ? In my case I tend to you many furniture pieces from sketchup and realize the polygon count slows down the ray trace. So if you find the time let us all know your settings for such a nicely lit up scene.
Just heading out the door but will post my settings later this afternoon. However, there is nothing special in here, they are just standard pot (spot) lights. Everything in this scene is CA, it's the Grandview sample plan, just happen to be playing with it for some other things.
Here are some renderings I did for a developer who is rehabbing a property in Los Angeles. Everything was drawn and rendered in X9 and with the exception of a few minor items, all icons came from the Chief library.
 Here are the Ray Trace settings for the Grandview scene I posted(#709) this morning. The sun was set very low for this at 100 Lux in the Sun Angle Specification DBX.
5a78cd38a76f7_CaptureRT1.thumb.JPG.895777e0bcb941e715046d8db972e6a6.JPG5a78cd3984741_CaptureRT2.thumb.JPG.34adbacc0571d8c5f5aa5f57814d6d99.JPG5a78cd3ad2340_CaptureRT4.thumb.JPG.3f63a2b49ca7010f5b2d8b615b640f55.JPG5a78cd3a298c2_CaptureRT3.thumb.JPG.febde41cb2306cf2db6ff567783bff64.JPG
Just out of interest I took the same scene and ran it through the PBR. Nothing was changed other than the Camera Exposure and Brightness in the PBR DBX. Interesting to note that the PBR interpreted the lights and shadows differently as well as many of the materials. You may also notice that the PBR did not render the under-cabinet lighting at all. Also note the differences in the glass elements, especially the glass flower vases. What's likely most important here is that when setting your lights and materials you will probably need to decide at the very beginning as to which rendering method you are going to use. For myself this is a bit disconcerting as I was hoping that the PBR could be used in support of Ray Trace by providing one with a better insight as to how lights and materials would look prior to Ray Tracing. At this time that does not appear to be the case, it's one or the other.
PBR Version
Ray Trace Version
Some may find this to be of interest. Both the Ray Trace and PBR have their pro's and con's. I have done this a few time which is to blend the two together. In this sample the PBR version is placed overtop of the Ray Trace version with it's opacity 25%.
Ray Trace PBR Blend
5a78dc2bc2493_Untitled13000X1565RayandPBR.thumb.png.a8bbefa5a079186db615824ca5835506.png
Interesting insights, never tried pbr. As for the settings thank you, I swear sometimes I use the same settings but chief gives me different results.
Hell once I was finishing a house and when I got to the last room, the kids room, every ray trace I ran was filled with dots and black even.though all.settings remained the same and only chief objects were in the room. Out of curiosity ran new ray traces of other rooms and all was well but the kids room was black and spot filled....checked everything over.and over nothing helped.
Ray Trace PBR Blend
Nice Graham , all we need to do now is convince CA to give use that Mode :)
I am still seeing ALOT of black in PBR views and have given up on it at the moment, though others seem to produce some nice Images , I have not tried the Grandview Plan though.
It would be great if “those seeing success” would share their setup or if Chief would chime in with why your results are what they and others have no issues, we might all move beyond this “Easter Egg hunt”. I get trial and error makes for a better understanding of the program and Concepts but REALLY! Enough is enough already. Is it what companies want their customers to do and go through? I certainly hope not! Some folks are blessed with the talent to figure all this out, and more power to them! No one should ya e to be a slave to their tools but that sure seems to be what is happening here.
Ray Trace PBR Blend
Thanks again for your input, I am sure every user here appreciates the time you put in to help others and give advice!
After having gone through the thread a few more times, and played around with lighting/ray trace settings/ and the whole shabang, decided to share two results I got yesterday over night of an apartment kitchen.
Since "blends" showed up, here is PBR with a line drawing on top, stacked them in Bluebeam and exported. And the original PDB.
For some reason I've been undable to make that work again with the Z images.... have no idea what is. I showed the PBR with line on top to CA in Orlando -who knows if that arrives.
The second set shows the undercabinet lights (these are Graham's lights but I may have adjusted something), and through one more in for luck. All are from X9 plans of jobs this last year. The first (T) and last (Z) were done pre-public beta, middle one was in the current release. All have extra light sources placed in them-dragged to be directional and almost all pointing up at some angle. None of these have updated materials. I know I had to reduce the reflection of the floor in T and maybe did that in Z, ceiling in Green is also matte. Green was the most challenging, there are lights inside the glass cabinets and a couple to show the ceiling beams.
Follows are the settings  Note that P settings are for T (don't ask) Z settings are for the Z images. I'd expect the settings will change with final release so wouldn't get too excited about those. What I'm finding is the rest of the lighting, makes big difference as does the backdrop and moving a camera more than about 110 degrees requires changes.
You may or may not know that I've never posted (AFAIR) to this thead IOW you really don't want to see my RT's.
1 hour ago, DavidJames said:
Just a sample render. House still isn't complete.
Nice.
Twinmotion?
16 minutes ago, Chiefer said:
Nice.
Twinmotion?
Lumion :P  - I figured it was a better value.
Use all appropriate effects for the best result.
Also, right-click mouse to frame your scenes :)
Stunning, Jintu.
Also, appreciate the tips. I’m still learning the software so I’ll take all the help I can get. Expect a few messages from me in the very near future :lol:
    27848
    GeorgeDosil
    GeorgeDosil
  • Similar Content
    • By pgjacob
      HI All
      I am ray tracing a scene with a 3D plant (from sketchup) and the shadows are showing squares rather than the actual shadow of the plant (1 pass image shown below).  I have purposely moved the sun around to cast shadows to the back of the image as I have found manually manipulating the sun gives much better RTs than using natural sun angles (at least for me).  I attach the skp file and what the plant looks like in the object info window of CA.  Any ideas how to get rid of this square shadow?  I uncheck the ray casted shadows in camera tool pre-ray trace, and it looks better but still ray traces with the square shadow.
      Thanks in advance,
      melissa
      Blue Flax Lily.skp
    • By kingsgate
      Hello,
      I have the HTC vive, steam set up and am able to tour my projects, but it renders with weird flashes of black, sometimes a rainbow effect, usually fairly blurry. I have all lights, shadows and reflections turned off. Any suggetions on how to fix this?
    • By Renerabbitt
      Open to new work. I've been working remotely for clients for years and can easily navigate the issues that present themselves from remote work. I have plenty of references and videos demonstrating my various services. The following images are snippets from my site at www.RabbittDesign.net
      I offer training-while-drafting services in Chief Architect as well as training in Sketchup, Thea Render, Photoshop, Premiere Pro and Procreate.
      I tend to cater to experienced designers and drafters in Chief Architect, many of which benefit from and are quite pleased with anno/layer sets, library items, toolbars, and a more cohesive folder structure and .plan and .layout files.
      A few hours of my service may cut hours off of every project you have going forward.
      Feel free to check out my YouTube channel dedicated to all things drafting, designing, modeling and rendering in my signature below.
      Take a look at some of my recent design work in the Gallery
      Also, take a look at the extensive Free Content Thread and continued free content YouTube Series:
    • By chrisped
      I have a home design that I am working on in home designer professional 2020.  Would eventually like to get it completed and then a set of construction prints for Nashville, Tennessee.  whidh means I will need floor plans and elevation views as well as a plot plan.  I have the plot drawn with some contour lines in the drawing I have developed.  The house faces about due west (not the best but that is the lot I have.    I have attached a picture of what I want the exterior rendering to look like.  Looking for job bid.  The plan file is zipped and attached.  Following needs to get done and then a front rendering and the file returned with the updates.  (Can pay via paypal etc)
      1. Master bedroom vaulted ceiling following rafters up to height of 12 feet then flat across.  House rafters will be 2x8 or 2x6 depending on span.
      2. Fix the roof planes
      3. Shed roof with 2 in 12 slope over the back deck.  Extends out about even with the master.  This is asphalt shingles.  Ceiling will follow the rafters
      4. The peaks (side and front larger dormer) should be board and batten not sided, the rest of the house sided, the foundation walls are stone
      5. Make sure chimney carries through to the roof from fireplace in family room.  Chimney is stone where it can be seen outside of house.
      6. The basement foundation walls connecting to the crawl space (unfinished area) should be only 5' tall (it would just be in one area)
      7. Front porch is to have a metal roof, rest of house is asphalt shingles (charcoal color but not black)
      8. Stairs should be 42" wide and should be fixed . Want them closed underneath. Somehow I cant get this to look right
      9. Need a front rendering showing view of the house for presentation to client
      10. Need file updated to reflect these changes and has to be readable with Home Designer Pro 2020
      11. Floor deck for both the first and second floor are 11-7/8 TJI with 3/4 subfloor (I think I have this right).
      At any rate, looking for quote to get this done.  Thanks for looking.
      House Design Front Walkout.zip
    • By Texas_Chief_Pros
      Tutoring Services Architectural Drafting and Detailing Reinforced Concrete Drafting and Design Structural Drafting Services Architectural Presentation Drawings Floor Plan Drafting Services Landscape CAD Drawings Services CAD Conversion Services Kitchen and Bath Remodels 3D Design Services Rendering Services Tiny Home Design
