McQueen3D Posted December 3, 2014 Share Posted December 3, 2014 Full parametric 3D modeling of chimneys/fireplaces with the ability to specify chimney cap, fire brick in firebox (or insert), hearth cap thickness and material, mantel type or thickness and material. It should be able to produce a technically accurate cross-section and floor plan view. The current tool dates back to before version 7 and is now visually pointless compared to the rest of the program. 1 Link to comment Share on other sites More sharing options...
Richard_Morrison Posted December 3, 2014 Share Posted December 3, 2014 While the stair issue is incredibly annoying, it can be worked around as Joey has shown. However, the "auto update" (or I should say the "non auto-update") issue in Layout needs to be corrected ASAP. You can send out incorrect elevations with no idea that they are not up to date, and this represents a serious liability issue from my standpoint. Luckily, I have only experienced serious embarrassment to date. Link to comment Share on other sites More sharing options...
Kelly_K Posted December 3, 2014 Share Posted December 3, 2014 Fix the high amplitude wire arcs, plus a couple of alternatives to wire with - which I have mentioned in the past under suggestions. Link to comment Share on other sites More sharing options...
ARCHIJEF2000 Posted December 4, 2014 Share Posted December 4, 2014 Bring out a "rest of the world version" Link to comment Share on other sites More sharing options...
chief58 Posted December 4, 2014 Share Posted December 4, 2014 Kelly I have suggested that also, wish we could have something like the arc tool so we can draw our own arc and a straight like that makes the connection also Link to comment Share on other sites More sharing options...
dshall Posted December 4, 2014 Share Posted December 4, 2014 Kelly I have suggested that also, wish we could have something like the arc tool so we can draw our own arc and a straight like that makes the connection also Alert! Stupid question coming up...... why can't we use the spline tool..... what happens? I assume if I then moved the light fixture the spline would not follow. Yeah, why can't we use an ELECTRICAL SPLINE TOOL? This way we could control the shape. Link to comment Share on other sites More sharing options...
chief58 Posted December 4, 2014 Share Posted December 4, 2014 Mr. Scott I think you are onto somrthing as long as the spline tool made the connection so as you stated if you move a light or switch it goes with it Link to comment Share on other sites More sharing options...
chief58 Posted December 4, 2014 Share Posted December 4, 2014 If you mean modernizing the code base and I have to learn computer codes I not for that, I think most of us come from a construction background or drafting background, I know building and I can build it and draw it I don't know computer codes, Scott this might be a studid statement worst then you ? Link to comment Share on other sites More sharing options...
lbuttery Posted December 4, 2014 Share Posted December 4, 2014 Raymond: with a macro recording feature you don't need to learn code 1. turn on recorder 2. click to perform your tasks 3. turn off recorder 4. save/name the recorded macro 5. run that macro whenever you need to repeat the recorded steps also, just like symbols you could also buy macros created by others also, many users would post macros for free on the forum basically, you would only need to use macros if you wanted to otherwise you would use Chief just like you do now macros just save time/effort - lots of time/effort macros are for the "lazy" Lew Link to comment Share on other sites More sharing options...
Electromen Posted December 4, 2014 Share Posted December 4, 2014 Electrical power and lighting/switches on two different layers. All large commercial projects have drawings for each. 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted December 4, 2014 Share Posted December 4, 2014 I would like to see many more options for elevation drawings especially more line weight control, shadows, colors, transparencies etc. 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted December 4, 2014 Share Posted December 4, 2014 A total rework of the painfully slow 'Undo' command. That has always bugged me. +1 Link to comment Share on other sites More sharing options...
ACADuser Posted December 4, 2014 Share Posted December 4, 2014 I'm a neophyte in CA so not sure yet which ONE thing to update. I have been making a list for the past month using CA of the problems I have encountered.The Stair on my current project is driving me nuts with a cable railing and 3 floors with stair over the other & floor height different.Thanks for the suggestion to turn them off & just work in CAD (I think the CAD sucks BTW).But the lack of Auto Update of layouts is an insidious monster waiting to bite you on the butt.The least I would want is a button for UPDATE ALL LAYOUTS!!!! Then you could turn the extra fan on the computer and go out for lunch while it works. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted December 4, 2014 Share Posted December 4, 2014 The problem with 'macros' is as the program evolves and the code is rewritten they no longer function... Microsoft Excel is a prime example. Also, as the program evolves, there is less and less need for macros. Take a trip down Memory Lane: http://www.chieftalk.com/showthread.php?34156-Keystroke-Macros . What people were using macros for back then seems ridiculously easy now. Link to comment Share on other sites More sharing options...
lbuttery Posted December 4, 2014 Share Posted December 4, 2014 The problem with 'macros' is as the program evolves and the code is rewritten they no longer function... Microsoft Excel is a prime example Bill: yet, millions use Excel macros everyday are we avoid all the "power" that macros can add because things might change ??? life changes - everything changes adjust - adapt - improve or don't use macros even while the rest of us are they would/should be optional to getting things done in chief Lew Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 4, 2014 Share Posted December 4, 2014 I think that there is more of a need for more macro's, many more and multi line macro's. every macro save time the more the better. I use lots of them Link to comment Share on other sites More sharing options...
HumbleChief Posted December 4, 2014 Share Posted December 4, 2014 Thanks for the suggestion to turn them off & just work in CAD (I think the CAD sucks BTW). I've never used AutoCAD but I tried it the other day and all I can tell you is that the CAD really sucks in that program. There's too much to learn and I already know one way to do things. [/sarcasm] Link to comment Share on other sites More sharing options...
ACADuser Posted December 4, 2014 Share Posted December 4, 2014 LOL, well said. Link to comment Share on other sites More sharing options...
Doug_Park Posted December 4, 2014 Share Posted December 4, 2014 Lot's of good input here. Keep them coming. Link to comment Share on other sites More sharing options...
chief58 Posted December 4, 2014 Share Posted December 4, 2014 Lew if what you say is for lazy people I am all for it LOL Link to comment Share on other sites More sharing options...
glennw Posted December 5, 2014 Share Posted December 5, 2014 Lew, I am at a bit of a loss imagining what I could use recorded macros for. Could you give 6 or so specific examples of how you think recorded macros could be used? Link to comment Share on other sites More sharing options...
lbuttery Posted December 5, 2014 Share Posted December 5, 2014 Glenn: will try when time allows very busy setting up my museum when CA first announced they were working on macros I sent Chris Tenabrink about 6 samples but have no idea where they are now since PC died in Jan Meanwhile, when working on a plan and you find yourself repeating a task think how it would be nice to record those steps and be able to repeat whenever needed Lew Link to comment Share on other sites More sharing options...
glennw Posted December 5, 2014 Share Posted December 5, 2014 That's just it Lew - I am having trouble thinking of a use for such a feature. Link to comment Share on other sites More sharing options...
lbuttery Posted December 5, 2014 Share Posted December 5, 2014 Glenn: don't think - observe as you work on your next projects pay attention to tasks that you are doing and might need to do again sometime Lew Link to comment Share on other sites More sharing options...
glennw Posted December 5, 2014 Share Posted December 5, 2014 Lew, Stop stalling. You have been going on about recordable macros for years. It shouldn't be that hard to come up with a couple of examples. I need to draw a wall on most projects and build an auto roof - how will recordable macros speed that up? There are things that are repetitive like typing text, taking views, etc, etc, but there are better ways to repeat those sorts of things than recording a macro. The library, cad blocks, etc, work quite well and are easier than macros. I'll wait for you to give me some examples - how about even 2 or 3? Link to comment Share on other sites More sharing options...
