BnCKelley Posted February 27, 2021 Share Posted February 27, 2021 Can someone please tell me why all these dimensions pop up when I click a wall? It didn't do this originally and I've noticed in other areas it's the same. Anyone know why and how to prevent or fix this? Also, is there a way to control what temporary dimensions will measure to? Thanks I'm also not getting temporary dimensions when I click on a wall like I would normally get to relocate or move the wall. Link to comment Share on other sites More sharing options...
joey_martin Posted February 27, 2021 Share Posted February 27, 2021 Looks like you accidently hit the AUTO INTERIOR DIMENSION tool. Link to comment Share on other sites More sharing options...
KTransue Posted February 27, 2021 Share Posted February 27, 2021 What does it look like before you click on that wall? There are three possibilities that come to mind: (1) You've been dimensioning on quite a few layers and they're all being displayed on top of each other (though clicking on the wall wouldn't affect that), (2), as @joey_martin suggested, you've used the Auto Interior Dimension tool and it has overlapped your manual dimensions, or (3) ... I'll await your reply regarding the appearance of dimensions before you click on that wall. Link to comment Share on other sites More sharing options...
SNestor Posted February 27, 2021 Share Posted February 27, 2021 1 hour ago, BnCKelley said: Can someone please tell me why all these dimensions pop up when I click a wall? It didn't do this originally and I've noticed in other areas it's the same. Anyone know why and how to prevent or fix this? Also, is there a way to control what temporary dimensions will measure to? Thanks I'm also not getting temporary dimensions when I click on a wall like I would normally get to relocate or move the wall. If you post your plan we can look at and compare the setup of your dimension defaults.... So...post a plan. Thanks! Link to comment Share on other sites More sharing options...
Nicu101268 Posted February 27, 2021 Share Posted February 27, 2021 How to Show/Hide Temporary Dimensions: Menu Tools->Toolbars and Hotkeys->Customize Toolbars Now in Search box type Temp Find Temporary Dimensions, click on it and drag it on your toolbar Now you can check/uncheck Temporary Dimensions anytime as you wish Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 27, 2021 Share Posted February 27, 2021 10 minutes ago, Nicu101268 said: How to Show/Hide Temporary Dimensions: Menu Tools->Toolbars and Hotkeys->Customize Toolbars Now in Search box type Temp Find Temporary Dimensions, click on it and drag it on your toolbar Now you can check/uncheck Temporary Dimensions anytime as you wish You shouldn't need to do that if you have Chief's out of the box Toggle Modes toolbar turned on... 2 Link to comment Share on other sites More sharing options...
GeneDavis Posted February 27, 2021 Share Posted February 27, 2021 He cannot post plans. No internet, just a guy and his cell phone. Maybe he takes his laptop to a McDonalds once a week to keep Chief going. Link to comment Share on other sites More sharing options...
Nicu101268 Posted February 27, 2021 Share Posted February 27, 2021 @Alaskan_Son, you are perfectly right! 1 Link to comment Share on other sites More sharing options...
RookiePete Posted March 6, 2021 Share Posted March 6, 2021 I am having the same problem with one of my plans as well. While it is related to temp dim's, the problem is not that they appear, but rather that the number of dimensions that appear is overwhelming and largely useless. In my case, I click on one interior wall with no features on it, I get nearly 100 different dim's that are completely unrelated. I get a center dim on a toilet 2 rooms over for example. Here's what it looks like... Yellow is the selected wall, red stuff is "garbage." In another test plan, I click that and get 5 dim's that locate the adjacent walls - what I expect. In the test plan, all the temp dim's are "usable", that is to say if I select a wall, the temps that area can each be selected ans edited to determine the wall placement and dimensions. In the problem plan, most of the temps that appear are not editable. The toilet center line as my example, is not going to help me dimension the selected wall. In this example, the yellow is selected, but the red are all relivant and editable. Note I stuck a door and toilets in to compare if they were dim'ed like they were in the problem file. SNestor's file from the original question seems to me to be demonstrating the same issues. I don't want to turn temps off, they are very usefull in sizing, But if I can't hardly find the correct dim to edit because it's buried under garbage, they do no good. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 7, 2021 Share Posted March 7, 2021 On 3/6/2021 at 2:58 PM, RookiePete said: I am having the same problem with one of my plans as well. While it is related to temp dim's, the problem is not that they appear, but rather that the number of dimensions that appear is overwhelming and largely useless. In my case, I click on one interior wall with no features on it, I get nearly 100 different dim's that are completely unrelated. I get a center dim on a toilet 2 rooms over for example. Here's what it looks like... Yellow is the selected wall, red stuff is "garbage." In another test plan, I click that and get 5 dim's that locate the adjacent walls - what I expect. In the test plan, all the temp dim's are "usable", that is to say if I select a wall, the temps that area can each be selected ans edited to determine the wall placement and dimensions. In the problem plan, most of the temps that appear are not editable. The toilet center line as my example, is not going to help me dimension the selected wall. In this example, the yellow is selected, but the red are all relivant and editable. Note I stuck a door and toilets in to compare if they were dim'ed like they were in the problem file. SNestor's file from the original question seems to me to be demonstrating the same issues. I don't want to turn temps off, they are very usefull in sizing, But if I can't hardly find the correct dim to edit because it's buried under garbage, they do no good. Whether its desirable or not is another story, but the way Chief currently works is that Chief's generic temp dimensions only show up if there are no other dimensions in the plan that are referencing the same thing. In your particular example you have placed all those other dimensions onto their various layers. Each dimension string that is being displayed has one segment or another that can indeed be used to resize or relocate the selected wall... Link to comment Share on other sites More sharing options...
CodeKata Posted May 8, 2021 Share Posted May 8, 2021 I had the same issue. "Edit->Delete Objects...", then select "Dimensions, Automatic" under the CAD section. Now I get just the useful dimensions for the thing I click on. Kudos to this thread, https://hometalk.chiefarchitect.com/topic/3029-suddenly-too-many-dimensions-appear-when-selecting-a-wall/ Link to comment Share on other sites More sharing options...
BnCKelley Posted May 8, 2021 Author Share Posted May 8, 2021 Yes! I just found this out a few days ago from another tech support call to Chief. I've tried a couple of times before but wasn't really getting anywhere with my answers. A guy named Cameron nailed it in the first 20 seconds of the call and that was what he said to do. Thank you for reaching out CodeKata. I'd forgot about posting it on the forum. When did you figure this out and did you just search topics for solvers answer? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 8, 2021 Share Posted May 8, 2021 10 minutes ago, BnCKelley said: I just found this out a few days ago from another tech support call to Chief. I've tried a couple of times before but wasn't really getting anywhere with my answers. Had you read and perhaps responded to Kevin's post in this thread, you would have had your answer a long time ago. Link to comment Share on other sites More sharing options...
kylejmarsh Posted December 2, 2021 Share Posted December 2, 2021 On 2/27/2021 at 2:45 PM, Alaskan_Son said: You shouldn't need to do that if you have Chief's out of the box Toggle Modes toolbar turned on... I did not realize that changing those snaps has an effect on the temp dimensions. I turn them off usually but that's becaune I find them too busy - this may be a solution. Thanks Link to comment Share on other sites More sharing options...
MAINEWOOD59 Posted Saturday at 03:39 PM Share Posted Saturday at 03:39 PM I have been having similar problems... I cannot seem to clean up the auto dimensions in my plan? I have tried the solutions in this forum without success. Obviously, I am missing something. I would welcome help, thanks. Chief Architect forum.plan Link to comment Share on other sites More sharing options...
MAINEWOOD59 Posted Wednesday at 06:29 PM Share Posted Wednesday at 06:29 PM I see 10 downloads... you guys are working on it... Any thoughts, observations? Link to comment Share on other sites More sharing options...
Chrisb222 Posted Wednesday at 07:07 PM Share Posted Wednesday at 07:07 PM 28 minutes ago, MAINEWOOD59 said: I see 10 downloads... you guys are working on it... Any thoughts, observations? What's the problem? Your plan appears to be working correctly. On 12/6/2025 at 10:39 AM, MAINEWOOD59 said: I have been having similar problems... I cannot seem to clean up the auto dimensions in my plan? The original post was is regards to temporary dimensions, yet your question references auto dimensions. So it doesn't seem like the problem is similar? Or is it? What do you mean by "clean up"? And the thread is five years old, so it's dealing with a much older version than we have now, with radically different features and controls. And your signature reports that X7 is your newest version. Are you having an issue with temporary dimensions, or auto dimensions, in X17? Or what exactly is the problem you're having? You might get better response by posting a new thread with a better explanation of your issue. Link to comment Share on other sites More sharing options...
DBCooper Posted Wednesday at 07:14 PM Share Posted Wednesday at 07:14 PM (edited) It looks like your plan is from X7 and most people here are using something much newer. You are not clear about what your problem is. Are you having too many temp dimensions show up when you select a wall like the original poster? Or are you just trying to cleanup your interior dimensions? If all you want to do is cleanup up your interior dimensions, you can either start with the automatic ones and delete all the ones you don't want or delete them all and manually draw the ones you do want. I'm not even sure if there is a good way to tweak the auto ones in X7 to get what you want since I don't have it installed anymore. Edited Wednesday at 11:10 PM by DBCooper Link to comment Share on other sites More sharing options...
