cjanderson66 18 Posted December 23, 2020 I am not sure what has happened but when I create a trey ceiling my vertical sides of the depth that I have called out are not showing. Am I missing something? I have tried turning on all the layers but that still does not fix it. I am having to create a molding around the perimeter of the trey celling to cover it up. Any thoughts? Share this post Link to post Share on other sites
robdyck 497 Posted December 23, 2020 18 minutes ago, cjanderson66 said: I am not sure what has happened but when I create a trey ceiling my vertical sides of the depth that I have called out are not showing. Am I missing something? I have tried turning on all the layers but that still does not fix it. I am having to create a molding around the perimeter of the trey celling to cover it up. Any thoughts? Can you post the plan? Share this post Link to post Share on other sites
Kiwideziner 39 Posted December 23, 2020 I had that a couple of months ago, was in a hurry so just did cad work on the xsect to cover it up. Was meaning to get to the bottom of it but have not had time, probably should have sent to CA as it seemed like a bug. Share this post Link to post Share on other sites
GeneDavis 144 Posted December 23, 2020 What's a trey ceiling? I know what trey is in basketball and card games, but in architecture and building, no. 1 Share this post Link to post Share on other sites
Chrisb222 233 Posted December 23, 2020 I knew a kid once they called Trey. We used to tie him up to the ceiling. Is that what we're talking about?? Share this post Link to post Share on other sites
Ridge_Runner 131 Posted December 24, 2020 Good one, Rich, but should have been recessed! Share this post Link to post Share on other sites
Kbird1 822 Posted December 25, 2020 On 12/23/2020 at 11:22 AM, cjanderson66 said: I am not sure what has happened but when I create a trey ceiling my vertical sides of the depth that I have called out are not showing. Am I missing something? I have tried turning on all the layers but that still does not fix it. I am having to create a molding around the perimeter of the trey celling to cover it up. Any thoughts? Chief's Trey Ceiling does not play well with invisible walls , so you are best to use other methods for that , eg a Polyline Solid and A P.Solid Hole for the trey. Ceiling_Creating-a-trey-or-coffered-ceiling-using-polyline-solids.pdf M. Share this post Link to post Share on other sites
Rich_Winsor 200 Posted December 27, 2020 On 12/24/2020 at 12:14 PM, Ridge_Runner said: Good one, Rich, but should have been recessed! You know, I considered that but when I thought about it if I recess the trey, then what I am in effect making is a tray ceiling. No matter how you spell it, the usage of trey/tray can have grey/gray blurry areas of interpretation. In any event, in an attempt to offer some help to the OP, I went ahead and had a play with recessing the trey. FWIW, Chief's tools seem to be functioning as expected for me but this case is very uncomplicated . Funny thing is If you tilt your head just right, the ceiling bears an uncanny resemblance to a certain "Wings Joint" logo. BTW, God bless those nice young ladies. 1 Share this post Link to post Share on other sites
MoeGia 51 Posted December 27, 2020 Rich, you're a hoot! Can you raise the tray portion to be higher than the ceiling joist height and still have it work? Maybe 12" high with 2x8 jsts. 1 Share this post Link to post Share on other sites
Rich_Winsor 200 Posted December 28, 2020 Moe, you're giving me too much credit. I'm basically an image guy. I'm just using Chief's tools to get the image results I want regardless of how it would be built. Are you talking about increasing the depth the tray ceiling is recessed into the ceiling? If so, sure, I can make it look like that. 1 Share this post Link to post Share on other sites
