njeff3368 Posted August 25, 2017 Share Posted August 25, 2017 I just posed a question about collaboration with a tech support rep and she steered me here as she did not have and answer for me. Question: Is there an efficient way to collaborate with colleagues on a single drawing file? Ideally, we would like to store our Chief files on some sort of server that we can both access remotely without the ridiculous process we go through now (described below). Tech support says they have seen many issues/file corruption with this type of system. This seems crazy to me as team collaboration is commonplace in today's workplace. Note: We each have our own licenses on our own computers. We are a residential remodeling company and do a variety of projects (kitchens, baths, additions, decks, etc.) Scenario: In our office there are two of us who work on every project in Chief. One person is responsible for all the structural components and permit drawing sets. The other person is responsible for all the interior components including interior/electrical/cabinet drawing sets. We find our current workflow cumbersome and are looking for a more efficient way to collaborate on our Chief projects. Here's our current workflow: - Structural: Inputs the field measure info then has to export the file as backup, save to computer, send to shared drive. - Interior Designer: Downloads file from shared drive, opens file on her computer, designs concepts for client review. After a concept has been accepted by a client, and some detail work completed, the file is exported as back-up again, saved to computer, sent to shared folder. Structural: Downloads the file, refines structural drawings to send to engineer. Exports file as back-up yada yada yada........ This inefficient process continues back and forth multiple times until all the client requested revisions, structural revisions and details are done and the drawings are completed. BTW, we also have to do this with our layout file as we want all of the information in one layout. This method has lead to multiple files and back-up files on each of our computers making it confusing which one's is current and which ones are safe to delete. It got to a point where we just started using different files to complete each or our parts of the drawing sets. This obviously leads to discrepancies in the final drawings. So, we recently started doing the same program with the file saved to a physical thumb drive which we have to physically pass back and forth to each other (another inconvenience since we are not always working in the same office). Frustrated, please HELP!! We are eager to hear how others deal with this issue and appreciate any input. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 25, 2017 Share Posted August 25, 2017 I know some guys use Dropbox or a similar program for that. I do all the work myself so I'm just not a pro at multi-users drawing the same plan. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 25, 2017 Share Posted August 25, 2017 I use Dropbox for my projects. I have a shared Folder that other users have access to. The main problem is that only one user can be using the file at any given time in order to avoid over-writing another users work. As long as there's a check-out procedure used to enforce single user access it works seamlessly. Unfortunately, Chief doesn't have any file locking mechanism built-in so the procedure has to be manual. IOW, notify all other users that you will be using the file at x:xx for n hours - then notify them when you are finished. It might be possible to create a macro that would display "File in use by ______, Please wait until done". I'm not sure if that would work. It might require some really creative code. It would probably be easier for CA to include a "Lock Code" in the file header. Link to comment Share on other sites More sharing options...
lbuttery Posted August 25, 2017 Share Posted August 25, 2017 Chief has no auto process for sharing the same file My partner and I add our initials and date to the file name so we know who last worked on the file such as 123_Elm_MODEL_170825_1545_LB_X9.plan LB = my initials - his were JK MODEL = new build, REMOD = REMODEL MOD01 or REM01 were for versions clumsy but it worked we use "save as" and use it often we also save as 123_Elm.plan and 123_ELM.layout each time to keep plan in layout in sync there is 3rd party software for checking software in/out - but cost ??? Lew Link to comment Share on other sites More sharing options...
javatom Posted August 25, 2017 Share Posted August 25, 2017 Use Lews method for saving a backup copy. I never change the name of the active file. The file without a date is always the most recent version. That way you do not have to re-link the plan file to the layout file. The version number of the plan is put on the PDF file only. It is also a good idea to do the work on the plan from your C drive. At the end of your session, send it back to dropbox and overwrite the previous, now out of date, version. Chief can not have two people working on the plan AT THE SAME TIME. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 25, 2017 Share Posted August 25, 2017 I use Chief with two separate computers so I may have a few suggestions. 1. My primary suggestion would probably be the easiest for collaboration, though you will never be able to work on the same file at the same time in this manner. Run the application from a server workstation through a screensharing application. One computer, one file, one at a time. 2. work in layer sets tailored to set all changes to a specific layer and instruct the struc engineer to do all structural modifications with Cad lines until the final locations are put into place before modifying foundation etc. Joe carrick is an excellent resource for this, you can search his posts for relevant info. 3. if you setup your drawing page and show drawing page on the .plan file you can set off set reference points to the page sheet and snap new measurements using this cad point. Import measurements on a separate layer for better workflow. All in all I think layer set management is your best collaborative solution Link to comment Share on other sites More sharing options...
glennw Posted August 26, 2017 Share Posted August 26, 2017 6 hours ago, Joe_Carrick said: Unfortunately, Chief doesn't have any file locking mechanism built-in so the procedure has to be manual. Joe, Doesn't "Use File Locking" do that? Link to comment Share on other sites More sharing options...
lbuttery Posted August 26, 2017 Share Posted August 26, 2017 Doesn't "Use File Locking" do that? Glenn: probably does on your PC but if someone else is working on the same file on PC B especially if it is a copy of the plan I don't think it helps Lew Link to comment Share on other sites More sharing options...
Richard_Morrison Posted August 26, 2017 Share Posted August 26, 2017 Like Joe, I've been using Dropbox for years with no problem. I'm not sure that I would try it with any other program like OneDrive, though. Link to comment Share on other sites More sharing options...
glennw Posted August 27, 2017 Share Posted August 27, 2017 16 hours ago, lbuttery said: Doesn't "Use File Locking" do that? Glenn: probably does on your PC but if someone else is working on the same file on PC B especially if it is a copy of the plan I don't think it helps Lew Lew, File Locking prevents another copy of Chief from opening the same plan or layout file at the same time. So...if File Locking is checked, someone else on PC B wouldn't be able to open the plan if you already had it open on PC A. Link to comment Share on other sites More sharing options...
lbuttery Posted August 27, 2017 Share Posted August 27, 2017 Glenn: unless they already had a copy on PC B Lew Link to comment Share on other sites More sharing options...
glennw Posted August 27, 2017 Share Posted August 27, 2017 Quote unless they already had a copy on PC B Well Lew, Isn't that a different file? I thought we were talking about opening the SAME file on a different computer - not a different file (even if it contains the exact same data). Link to comment Share on other sites More sharing options...
jbaehmer Posted August 27, 2017 Share Posted August 27, 2017 File locking would not work with Dropbox or any other cloud services. It would only work if someone on PC B connected directly to PC A and opened the file from there and not a local copy on its own drive.... Assuming it was already opened by one of the computers. Link to comment Share on other sites More sharing options...
lbuttery Posted August 27, 2017 Share Posted August 27, 2017 Isn't that a different file? Glenn: of course it is but, just pointing out that doing file locking on PC A doesn't affect PC B so if both plans are worked on separately, there is no way to prevent that and there is no way to "merge" the two plans together either just clarifying the point I made in my first post my partner and I had to do the "baton carry" method of file sharing - since Chief has NO other method whoever had the "baton" could do the editing Lew Link to comment Share on other sites More sharing options...
jcaffee Posted August 28, 2017 Share Posted August 28, 2017 On 8/26/2017 at 11:11 AM, Richard_Morrison said: I'm not sure that I would try it with any other program like OneDrive, though. 19 hours ago, jbaehmer said: File locking would not work with Dropbox or any other cloud services Both Dropbox Business and OneDrive (via Office 365 Business and SharePoint) offer advanced file library features. Not sure about GoogleDrive, as it's been years since I've used them, but I would imagine their business service has similar offerings. That said, CA is not engineered for multi-user collaborative operations. Therefore, any efforts will always be a kludge. Backup early and often. Link to comment Share on other sites More sharing options...
dshall Posted August 28, 2017 Share Posted August 28, 2017 21 hours ago, jbaehmer said: File locking would not work with Dropbox or any other cloud services. It would only work if someone on PC B connected directly to PC A and opened the file from there and not a local copy on its own drive.... Assuming it was already opened by one of the computers. Jared, how do you respond to Jon Caffee's statement in regards to advanced features? Would file locking work? Link to comment Share on other sites More sharing options...
KirkClemons Posted August 28, 2017 Share Posted August 28, 2017 The biggest danger I've seen with file locking is that the copy in the cloud becomes locked, and no one can open it, forcing the user into opening a previous version. The safest method is a check-in, check-out process. Most cloud-based file sharing services have some sort of revision history (example attached). The complexity come in when you start importing external files such as PDF's, and images for new materials. This is where the '3D> Materials> Create Plan Materials Library' can come in handy. You can update and re-export a plan specific library file so that anyone who is checking out the project can import the latest version of the library. In the end, it all comes down to communication between team members. Link to comment Share on other sites More sharing options...
jbaehmer Posted August 28, 2017 Share Posted August 28, 2017 2 hours ago, jcaffee said: Both Dropbox Business and OneDrive (via Office 365 Business and SharePoint) offer advanced file library features. Not sure about GoogleDrive, as it's been years since I've used them, but I would imagine their business service has similar offerings. That said, CA is not engineered for multi-user collaborative operations. Therefore, any efforts will always be a kludge. Backup early and often. 1 I do not have Dropbox Business. Requires 5 users from my research and it is just me and another person. I don't believe it is possible, but since I don't have the "Business" version, I can be wrong. I do have Onedrive, and I don't see where I can lock the files. I would love to know how. If you are at the UGM, maybe you can show me. I do agree though that CA is not setup as a multi-user system. Link to comment Share on other sites More sharing options...
jcaffee Posted August 28, 2017 Share Posted August 28, 2017 Jared, sorry won't be at UGM--bad heart and all that it entails. DropBox Business now requires 3 users, not 5. OneDrive library features are only available through Office365 Business with SharePoint. (SharePoint Online may be available separately, but I haven't looked into that in quite awhile.) I'm fairly sure that https://chieftalk.chiefarchitect.com/profile/75-johnny/ 's firm is successfully using SharePoint, perhaps he will chime in. Link to comment Share on other sites More sharing options...
KirillP Posted December 24, 2023 Share Posted December 24, 2023 (edited) Sorry for the necroposting, but this post is the top google result for "chief architect two users sharing the same plan", so I'll record my observation for others so they don't need to try. I have two Macs, one running HD Pro 24 and another CA X15. CA is told to save HD-compatible .plan files and does so. The plan is in the iCloud shared folder, "Use File Locking" is turned on on both machines. Use File Locking does not prevent users from opening the same plan file and modifying it concurrently. iCloud (Dropbox or any other cloud service) is not "sharing", but "syncing" and these services use their own API for communication between simultaneous readers and writers. CA apparently uses old plain vanilla file locking which is suitable for single computer sharing or sharing via network server on the LAN. "The last writer wins" and the previous writer loses everything they did. So if 2 users start with the same plan, one did something and saved and then second saved, whatever first one saved is lost. CA doesn't have the capability to sync changes, at least on iCloud Drive. The nice little software for the amateurs (it's getting better, but nowhere even close to HD, not mentioning CA) Live Home 3D can do it easily. My wife was designing on her iPad and I immediately see what she does on my Mac, without even touching anything, the file updates and views are autoupdating (which is sometimes even annoying). Unfortunately, we grew out of it with our project. P.S. I've seen in other threads that CA "should just add this" to their products. It's actually a very challenging sofware engineering task, and for the old codebase such is CA, which was not designed initially for this, it's a major overhaul. Most such apps implement the MVC (Model-View-Controller) pattern unidirectionally. You have a model of your document in the computer memory, you have the view (the code that shows the model on the screen this way or another) and you have controllers (menu actions, mouse actions, keyboard shortcuts, etc). Model is loaded, View is shown, Controller makes a change, this change is shown in the view and reflected into the model. Then model is exported (saved) into external representation on disk. For this sync scheme to work, through iCloud or otherwise, the model has to be changed directly by the controller and view should be able to receive updates from the model and redraw only what was changed, then the changes should be sent to other apps and their models and views updated accordingly. And that doesn't deal with conflicting changes for which the whole computer science field was invented: https://en.wikipedia.org/wiki/Operational_transformation and then (not sure about the timeline tho) as an alternative https://en.wikipedia.org/wiki/Conflict-free_replicated_data_type It's a rabbit hole seven miles deep. Merry Christmas! Edited December 24, 2023 by KirillP added a software engineering rant 1 Link to comment Share on other sites More sharing options...
