decorators3 Posted March 19 Share Posted March 19 HI Here is an image of a complex I'm doing .. I've been asked for a straight on shot where the doors and porches are not on angles.. I can't see anyway to really do that --is there? Link to comment Share on other sites More sharing options...
MPDesign Posted March 19 Share Posted March 19 Have you tried the elevation camera, watercolor-line overlay? Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 19 Share Posted March 19 On 3/19/2025 at 11:21 AM, decorators3 said: I've been asked for a straight on shot where the doors and porches are not on angles. Expand Cross Section/Elevation camera, shoot the front. Or, take an Orthographic Full Overview, then go to 3D > View Direction > Front View. This view can be rotated and manipulated. Either will give you the angle you want, and can be switched to Standard technique, but not Physically Based. Any true 3D perspective view is going to show foreshortening. Link to comment Share on other sites More sharing options...
decorators3 Posted March 19 Author Share Posted March 19 On 3/19/2025 at 12:55 PM, MPDesign said: Have you tried the elevation camera, watercolor-line overlay? Expand will try thanks Link to comment Share on other sites More sharing options...
decorators3 Posted March 19 Author Share Posted March 19 On 3/19/2025 at 12:56 PM, Chrisb222 said: Cross Section/Elevation camera, shoot the front. Or, take an Orthographic Full Overview, then go to 3D > View Direction > Front View. This view can be rotated and manipulated. Either will give you the angle you want, and can be switched to Standard technique, but not Physically Based. Any true 3D perspective view is going to show foreshortening. Expand l need it in PB for an MLS listing Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 19 Share Posted March 19 On 3/19/2025 at 1:45 PM, decorators3 said: l need it in PB for an MLS listing Expand Then the closest you'll get, since PB is not available in elevation camera, is: Open a Perspective Full Overview Go to 3D > View Direction > Front View Zoom out really far, until your model is tiny Activate Perspective Crop Mode* Zoom in to desired field of view *I don't know where this tool lives, I've had it on my custom toolbars too many years to remember Link to comment Share on other sites More sharing options...
decorators3 Posted March 19 Author Share Posted March 19 On 3/19/2025 at 1:56 PM, Chrisb222 said: Then the closest you'll get, since PB is not available in elevation camera, is: Open a Perspective Full Overview Go to 3D > View Direction > Front View Zoom out really far, until your model is tiny Activate Perspective Crop Mode* Zoom in to desired field of view *I don't know where this tool lives, I've had it on my custom toolbars too many years to remember Expand ok sounds good,, I'll try it Cheers Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 19 Share Posted March 19 On 3/19/2025 at 1:57 PM, decorators3 said: ok sounds good,, I'll try it Cheers Expand Perspective Crop Mode prevents the camera from foreshortening the view as you zoom in and out. So once you're really far out and foreshortening is decreased, Perspective Crop Mode will maintain that perspective when you zoom back in. It's not perfect, but it's close. Link to comment Share on other sites More sharing options...
decorators3 Posted March 19 Author Share Posted March 19 On 3/19/2025 at 1:58 PM, Chrisb222 said: Perspective Crop Mode prevents the camera from foreshortening the view as you zoom in and out. So once you're really far out and foreshortening is decreased, Perspective Crop Mode will maintain that perspective when you zoom back in. It's not perfect, but it's close. Expand will try immediately thanks Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 19 Share Posted March 19 On 3/19/2025 at 1:56 PM, Chrisb222 said: *I don't know where this tool lives, I've had it on my custom toolbars too many years to remember Expand @decorators3I've been curious about this all day because I couldn't find this tool anywhere in the menus or the default toolbars, so I went to Help to see what's going on: Perspective Crop Mode In Chief Architect X8 through X11, Perspective Crop Mode allowed older functionality governing zooming in cameras from Version X7 and prior to be preserved in saved cameras in legacy plans migrated forward. This deprecated tool has been removed from the program’s menu and toolbars in Version X12, although it can be migrated with legacy toolbars and hotkeys. Saved cameras in legacy plans with this behavior enabled may become distorted if you pan or zoom in the view. That's when I remembered that at one time Chief changed the functionality of how the perspective cameras dealt with perspective foreshortening. If you want to use Perspective Crop Mode, you have to go into Customize Toolbars and add the tool to your toolbar manually. It really shouldn't be a deprecated tool, it's a great and very useful tool for manipulating perspective views, I use it all the time. They don't even address how to use it in Help, only what is mentioned above. I just wanted to clarify this in case you were having problems finding the tool and making this work, because it will work fairly well for what you want to do. Let me know if you have any questions. Link to comment Share on other sites More sharing options...
decorators3 Posted March 19 Author Share Posted March 19 On 3/19/2025 at 9:39 PM, Chrisb222 said: @decorators3I've been curious about this all day because I couldn't find this tool anywhere in the menus or the default toolbars, so I went to Help to see what's going on: Perspective Crop Mode In Chief Architect X8 through X11, Perspective Crop Mode allowed older functionality governing zooming in cameras from Version X7 and prior to be preserved in saved cameras in legacy plans migrated forward. This deprecated tool has been removed from the program’s menu and toolbars in Version X12, although it can be migrated with legacy toolbars and hotkeys. Saved cameras in legacy plans with this behavior enabled may become distorted if you pan or zoom in the view. That's when I remembered that at one time Chief changed the functionality of how the perspective cameras dealt with perspective foreshortening. If you want to use Perspective Crop Mode, you have to go into Customize Toolbars and add the tool to your toolbar manually. It really shouldn't be a deprecated tool, it's a great and very useful tool for manipulating perspective views, I use it all the time. They don't even address how to use it in Help, only what is mentioned above. I just wanted to clarify this in case you were having problems finding the tool and making this work, because it will work fairly well for what you want to do. Let me know if you have any questions. Expand Thank you..not sure how to go about adding a tool that is not there now Link to comment Share on other sites More sharing options...
robdyck Posted March 19 Share Posted March 19 On 3/19/2025 at 9:39 PM, Chrisb222 said: Perspective Crop Mode Expand For an exterior rendered image, If I'm not mistaken that tool essentialy functions the same as: using the zoom tool which can be used for smaller details, or for exterior views, the camera can be positioned much further away and then 'cropped' using the Zoom tool for exterior views, positioning the camera much further away from the house and then reducing the camera view angle (NOT using the Zoom tool). Link to comment Share on other sites More sharing options...
decorators3 Posted Thursday at 07:01 PM Author Share Posted Thursday at 07:01 PM On 3/19/2025 at 11:11 PM, robdyck said: For an exterior rendered image, If I'm not mistaken that tool essentialy functions the same as: using the zoom tool which can be used for smaller details, or for exterior views, the camera can be positioned much further away and then 'cropped' using the Zoom tool for exterior views, positioning the camera much further away from the house and then reducing the camera view angle (NOT using the Zoom tool). Expand I think i'm ok, told client would not look same as PBR.( PBR does not show in perspective view) also asked me for a birds eye view.. would you consider these images BEV? or do i have to do something special with the camera Link to comment Share on other sites More sharing options...
Chrisb222 Posted Thursday at 11:03 PM Share Posted Thursday at 11:03 PM On 3/19/2025 at 11:11 PM, robdyck said: If I'm not mistaken that tool essentialy functions the same as Expand Not exactly the same. Both of those methods do funky things to the camera. Perspective Crop Mode can be activated and deactivated in ways that retain the other camera functions and settings making it much more useful. In my methodology, at least. Link to comment Share on other sites More sharing options...
Gawdzira Posted Friday at 12:14 AM Share Posted Friday at 12:14 AM A birds eye view tend to work better with the orthographic full overview. I try to position them at about 30 deg for a true isometric. Link to comment Share on other sites More sharing options...
robdyck Posted Friday at 01:59 PM Share Posted Friday at 01:59 PM On 3/20/2025 at 11:03 PM, Chrisb222 said: Not exactly the same. Expand Not trying to be argumentative, but it looks the same to me. Perspective crop mode is just a zoom function, no? Create a camera, select PCM, zoom in and then press F6 (Fill Window) which resets the camera view. Undo Zoom tool goes back to the PCM view. It's perhaps a more flexible way of zooming in using the scroll wheel, but I can't tell any difference. Zoom and PCM allow you to zoom in tight on a portion of a view without affecting the camera position. What other benefits do you find using PCM? Link to comment Share on other sites More sharing options...
SHCanada2 Posted Friday at 04:55 PM Share Posted Friday at 04:55 PM i tend to interpret birds eye view as not directly on top, but further away. As I question the value of mostly roof...but then again I am asked to do this mostly from a sales perspective, not a technical perspective Link to comment Share on other sites More sharing options...
Alaskan_Son Posted Friday at 05:49 PM Share Posted Friday at 05:49 PM On 3/19/2025 at 1:45 PM, decorators3 said: l need it in PB for an MLS listing Expand You can also optionally use a standard Orthographic Camera, 3D>View Direction>Front View, and Edit Active View>Camera>Options and set Field of View to 10 (the lowest it will go). This won't be perfect, but its close. This may be what Robert was alluding to when he said... On 3/19/2025 at 11:11 PM, robdyck said: ....for exterior views, positioning the camera much further away from the house and then reducing the camera view angle (NOT using the Zoom tool). Expand By the way, I think the real ticket was what Robert mentioned just before that... On 3/19/2025 at 11:11 PM, robdyck said: using the zoom tool which can be used for smaller details, or for exterior views, the camera can be positioned much further away and then 'cropped' using the Zoom tool Expand He seemed to be mostly responding to Chris' mention of the Perspective Crop tool. but it was also a very good option for creating a PBR of a nearly Orthographic View. You just need to be viewing front the front, Zoom way out, and then use the Zoom tool to crop your view (zoom back in again). Link to comment Share on other sites More sharing options...
Alaskan_Son Posted Friday at 06:00 PM Share Posted Friday at 06:00 PM On 3/21/2025 at 1:59 PM, robdyck said: Not trying to be argumentative, but it looks the same to me. Perspective crop mode is just a zoom function, no? Create a camera, select PCM, zoom in and then press F6 (Fill Window) which resets the camera view. Undo Zoom tool goes back to the PCM view. It's perhaps a more flexible way of zooming in using the scroll wheel, but I can't tell any difference. Zoom and PCM allow you to zoom in tight on a portion of a view without affecting the camera position. What other benefits do you find using PCM? Expand You're right that Perspective Crop Mode is very similar to the Zoom tool. I still use it when working with very small details though for some of the exact reasons you mention...it allows for infinite zoom while freely panning, orbiting, and scroll-wheel zooming with my mouse. The zoom tool is not nearly as fluid and easy to use. Link to comment Share on other sites More sharing options...
Chrisb222 Posted Friday at 09:03 PM Share Posted Friday at 09:03 PM On 3/21/2025 at 1:59 PM, robdyck said: Not trying to be argumentative, but it looks the same to me. Expand I didn't say they were totally different, I said they're not exactly the same. One of the main differences in MY workflow is being able to deactivate Perspective Crop Mode, which returns the camera to it's normal foreshortening behavior, allowing me to tailor perspective views in ways I can't using the more simple Zoom tool. For instance, activate PCM, zoom a little, orbit a little, deactivate and zoom in/out, orbit, reactivate. It gives me great flexibility in fine-tuning a view. You may operate differently, and that's ok. In fact, PCM completely eliminated my need for the Zoom tool, and I have none of them on my toolbar because PCM and the scroll wheel do all they do and more, in one tool. It really is a great tool that shouldn't be deprecated, IMO. On 3/21/2025 at 1:59 PM, robdyck said: Perspective crop mode is just a zoom function, no? Expand No. On 3/21/2025 at 1:59 PM, robdyck said: It's perhaps a more flexible way of zooming in using the scroll wheel Expand Thanks for agreeing they're not exactly the same. Link to comment Share on other sites More sharing options...
glennw Posted Saturday at 11:41 PM Share Posted Saturday at 11:41 PM On 3/19/2025 at 9:39 PM, Chrisb222 said: They don't even address how to use it in Help Expand By default, panning and zooming adjusts the position and direction of the camera. It does not, however, adjust the distances at which surfaces are clipped. This means that if you zoom in closely on an object, some of its surfaces may be removed from the view. One way to avoid this is to lower the camera’s Clip Surfaces Within value in the Camera Specification dialog. See Camera Panel. Another way to avoid this is using Perspective Crop Mode . When Perspective Crop Mode is active, panning and zooming do not adjust the position of the camera. As such, using it can result in inconsistencies between a camera’s position and what is actually shown in the view. For this reason, it should only be used to zoom in closely on small objects or details. Perspective Crop Mode is not used when a view is sent to layout. This means that a view on the layout page may not look the same as the original view. See Layout. To use Perspective Crop Mode 1. Zoom in on an object that you would like to examine closely. 2. If any of its surfaces disappear, zoom out until they are restored. 3. Select 3D> Camera View Options> Perspective Crop Mode . 4. Zoom in on the object, but try to limit any panning or other changes to the camera’s perspective. Once Perspective Crop Mode has been enabled in a camera view, it should remain toggled on and navigation in that view should be limited. Link to comment Share on other sites More sharing options...
