cjanderson66 Posted May 12, 2023 Share Posted May 12, 2023 Has anybody got any idea of how to do a recessed Baseboard detail like the one shown here. I have a contemporary style home and the client wants this as the base. I have no idea of how to show this to him in my renderings. Link to comment Share on other sites More sharing options...
TeaTime Posted May 12, 2023 Share Posted May 12, 2023 Huh. Ponywalls would probably be the easiest...depending on what your walls look like. Though honestly that's such a small detail for renderings I'd probably just apply a low, thin Wall Covering a little darker than the wall color, then just mock up some detail elsewhere. 2 1 Link to comment Share on other sites More sharing options...
TeaTime Posted May 12, 2023 Share Posted May 12, 2023 Though the benefit of the ponywall is that the base attaches to the lower wall, so it essentially automatically recesses -- I set my lower wall to have 1/16" drywall, just to avoid seeing framing: 2 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted May 13, 2023 Share Posted May 13, 2023 This has always been hard to do in chief , and Pony walls are one option, but for a Single Render, to give the Client an Idea, I'd give a Material Region set to cut the parent object a go 1st. Their are Threads on the Forum about this with more Ideas , but maybe 1 or 2 versions ago , and there maybe newer methods too. M. 1 1 Link to comment Share on other sites More sharing options...
Ebb001 Posted August 17, 2023 Share Posted August 17, 2023 Yep, the developers should really figure this out. Probably wouldn't take much time and resource. I'm in silicon valley and details like this are very high end expensive and popular and have been for quite some time. And when you live in an area where starter homes with three bedrooms are $1.5 million and the average house is about $4.5 million people do spend the extra time and money for high end details like this. Almost every house I design has shadow reveal baseboards, window trim and door trim. Going at it one wall at a time is absurd. Link to comment Share on other sites More sharing options...
rlackore Posted August 18, 2023 Share Posted August 18, 2023 Material Regions: Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 18, 2023 Share Posted August 18, 2023 3 Link to comment Share on other sites More sharing options...
TeaTime Posted August 18, 2023 Share Posted August 18, 2023 A clever solution as always. I would add to that though a small c-channel nested into the base to be certain there's no chance of wall materials showing through. The biggest issue with this is that Cross Sections will show that inside wall line, as well as that wall covering line 1/16 off the wall. Not ideal, but manageable in a few ways. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 18, 2023 Share Posted August 18, 2023 43 minutes ago, TeaTime said: A clever solution as always. I would add to that though a small c-channel nested into the base to be certain there's no chance of wall materials showing through. The biggest issue with this is that Cross Sections will show that inside wall line, as well as that wall covering line 1/16 off the wall. Not ideal, but manageable in a few ways. in that case you can eliminate the step where I modify the wall types Link to comment Share on other sites More sharing options...
TeaTime Posted August 19, 2023 Share Posted August 19, 2023 3 hours ago, Renerabbitt said: in that case you can eliminate the step where I modify the wall types I'm not sure I understand how that would help - isn't that sort of the key trick here, setting the drywall to be 1/2" opening? Either way I'm not arguing against it, some people might not care - not every solution is perfect for everyone. FWIW though some of the concerns about the ponywall method that you mentioned in the video aren't really concerns at all - Framing should be fine since both wall types use the same framing specs, and while there are potentially some break lines in Vector views, they only tend to appear at odd angles and when zoomed out enough. Even in cross sections there's only a bit of weirdness where the external layers connect Ultimately though, it would be awesome if Moldings had an option to recess into the surface material so none of this was necessary! Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 19, 2023 Share Posted August 19, 2023 17 minutes ago, TeaTime said: I'm not sure I understand how that would help - isn't that sort of the key trick here, setting the drywall to be 1/2" opening? Either way I'm not arguing against it, some people might not care - not every solution is perfect for everyone. Not quite. The 0" drywall layer is so that it shows drywall where the wall covering doesnt cover, because otherwise it would show framing...but your molding takes care of that. So the method is simply a invisble material on your drywall with a wall covering down to the reglet in your molding. What did you discover, any other hiccups with the pony wall method? Exterior walls fine? door settings? etc. Link to comment Share on other sites More sharing options...
TeaTime Posted August 19, 2023 Share Posted August 19, 2023 1 minute ago, Renerabbitt said: So the method is simply a invisble material on your drywall with a wall covering down to the reglet in your molding. Oh I get what you mean, just means you don't need the 0" drywall AND the air gap, just the air gap + covering, right right. Your method definitely taught me that Wall Coverings are not 0" thick though, which is curious. I suppose I get why but it seems like it shouldn't be necessary. I doubt Wall Coverings have been updated in a long time, though. I personally never use the things, so this was a bit of an eye opener as far as creative uses for the things. 2 minutes ago, Renerabbitt said: What did you discover, any other hiccups with the pony wall method? Exterior walls fine? door settings? etc. I hadn't noticed any other anomalies, though I can't say I run it through a whole course yet. The obvious limiter is -- well what if you need a legit ponywall, too?? SOL. Wall Covering time! Link to comment Share on other sites More sharing options...
threeutes Posted October 4, 2024 Share Posted October 4, 2024 unless im missing something how does one achieve a "thickness " on a wall wall covering? Link to comment Share on other sites More sharing options...
DBCooper Posted October 4, 2024 Share Posted October 4, 2024 "Wall coverings" have no thickness and I have never found a way to set one. "Wall material regions" and "custom backsplashes can have whatever thickness you want. Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 4, 2024 Share Posted October 4, 2024 1 hour ago, DBCooper said: "Wall coverings" have no thickness and I have never found a way to set one. "Wall material regions" and "custom backsplashes can have whatever thickness you want. 4 hours ago, threeutes said: unless im missing something how does one achieve a "thickness " on a wall wall covering? I think the confusion is coming from my method. we are not generating a wall thickness with a wall covering but rather covering a wall layers thickess which is set to no display or insulation air gap material with a wall covering and then revealing that no display area which is perceived as a void Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 29, 2024 Share Posted November 29, 2024 On 8/18/2023 at 3:58 PM, Renerabbitt said: I tried this and all was good until I added a stairs opening. I made up this shadow molding to create the illusion of a gab. This is a matter of making up a room type with the Modern, Simple molding Link to comment Share on other sites More sharing options...
Adam_Gibson Posted Saturday at 04:31 PM Share Posted Saturday at 04:31 PM (edited) Rene's video prompted me to find a simpler way: Create a recessed baseboard like the one attached. Change the walls into pony walls, with the lower wall being a copy of the upper wall. Give the lower pony wall a 0” drywall thickness on both or one sides, depending on whether it's interior or exterior. Make the lower wall height the same as the baseboard plus the floor thickness (same color too, if that's the look). Align the main layers, if needed. Save the molding and wall types. You're done. Edited Saturday at 04:49 PM by Adam_Gibson 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted Sunday at 11:13 PM Share Posted Sunday at 11:13 PM I just use a wall cap on a pony wall and set the width to the reveal I want and adjust the proper height above floor. This works for interior walls, but for exterior walls I have to use a material region with insulation air gap as material. Here is an example for a typical interior 2x4 division. Link to comment Share on other sites More sharing options...
Adam_Gibson Posted Monday at 01:33 PM Share Posted Monday at 01:33 PM That is a drawback because you have to address each exterior wall. The version I suggested is one and done. Link to comment Share on other sites More sharing options...
Renerabbitt Posted Tuesday at 02:58 AM Share Posted Tuesday at 02:58 AM (edited) On 8/16/2025 at 9:31 AM, Adam_Gibson said: Change the walls into pony walls, with the lower wall being a copy of the upper wall. The reason I don't do a pony wall method is because often times I need to use a pony wall for other reasons, such as a brick pony wall Otherwise yes this works Edited Tuesday at 02:59 AM by Renerabbitt Link to comment Share on other sites More sharing options...
mthd97 Posted Tuesday at 05:21 AM Share Posted Tuesday at 05:21 AM (edited) Hi all, I did a test with X15 to try a negative offset for the dry wall layers for internal walls. I couldn’t get it to work so I would recommend using the @Renerabbitt method so that your ML stays accurate. Don’t need extra pony walls messing up the 3D model or the ML. Edited Tuesday at 07:53 AM by mthd97 Link to comment Share on other sites More sharing options...
Adam_Gibson Posted Tuesday at 10:28 AM Share Posted Tuesday at 10:28 AM 7 hours ago, Renerabbitt said: The reason I don't do a pony wall method is because often times I need to use a pony wall for other reasons, such as a brick pony wall Otherwise yes this works That's a good point. Wouldn't it be great if ponies could have more than two walls? Link to comment Share on other sites More sharing options...
Renerabbitt Posted Tuesday at 03:01 PM Share Posted Tuesday at 03:01 PM 4 hours ago, Adam_Gibson said: That's a good point. Wouldn't it be great if ponies could have more than two walls? Yes completely agree..you were there last year when dan baumann asked for that in class. Specifically for wall stepping. Also would be great if we could just set any object to cut finish layer including default room moldings. Then your custom molding would be perfect Link to comment Share on other sites More sharing options...
Adam_Gibson Posted Tuesday at 05:37 PM Share Posted Tuesday at 05:37 PM Yes. You're so right. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Tuesday at 06:42 PM Share Posted Tuesday at 06:42 PM 3 hours ago, Renerabbitt said: Also would be great if we could just set any object to cut finish layer including default room moldings. Then your custom molding would be perfect I just posted a suggestion for exactly that capability. 1 Link to comment Share on other sites More sharing options...
