Michael_Gia Posted December 21, 2020 Share Posted December 21, 2020 So, I often have this condition where the exterior wall above garage is inset as shown below. Then I will often/always lower the roof over the garage to reduce the distance from the top of the garage door to the soffit. (it looks nicer) (the plan is for demonstration purposes only, my actual plans are even uglier) haha. Anyway the plan is attached and the problem is those gaps above the garage roof created by the exterior wall above which won't extend down to cover the side of the floor. (I'm guessing) I've always just slapped on some p-solids to cover my shame, but there must be a more intelligent solution? Test from Template.planFetching info... Link to comment Share on other sites More sharing options...
SNestor Posted December 21, 2020 Share Posted December 21, 2020 @Michael_Gia - I recreated using my template and got the same thing. So..it's a Chief thing. I played with wall structure settings, floor settings...nothing worked. If time is money...P-Solid and get on with it might be the best answer. Maybe one of our really smart guru's will chime in with the way to go about this... 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted December 21, 2020 Author Share Posted December 21, 2020 The funny thing is that even dragging the wall down doesn’t fix it. Always leaves a gap. I’ve even tried, “extend wall past floor below” and that also doesn’t help. I thought there would be a way to add wall material to edge of floor, you know how we do with deck floors?... Nothing. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 21, 2020 Share Posted December 21, 2020 If you use a couple of extra attic walls as cad patches it is almost stable but it definitely could use a little help from the Chief. Link to comment Share on other sites More sharing options...
ShaneK Posted December 21, 2020 Share Posted December 21, 2020 I just copied plan and no gaps using my default template, auto build roofs. Nothing special,,, just helping you diagnose issues roof.plan Link to comment Share on other sites More sharing options...
ShaneK Posted December 21, 2020 Share Posted December 21, 2020 I just opened your plan, turned on auto roof build and it fixed itself,,,, are you sure you are rebuilding roofs after changes? 546720156_TestfromTemplate.plan Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted December 21, 2020 Share Posted December 21, 2020 On 12/21/2020 at 4:11 PM, ShaneK said: I just opened your plan, turned on auto roof build and it fixed itself,,,, are you sure you are rebuilding roofs after changes? 546720156_TestfromTemplate.planFetching info... Expand Not certain that is working according to the original plan. That roof should be lower, around 115". Move it down and the gaps show up. Link to comment Share on other sites More sharing options...
ShaneK Posted December 21, 2020 Share Posted December 21, 2020 I opened his plan and fixed. Many issues just helping Link to comment Share on other sites More sharing options...
DavidJames Posted December 21, 2020 Share Posted December 21, 2020 Shane, Unfortunately auto-building the roof raises up the roof planes over the garage which is a different scenario from what Michael has (lowered roof planes w/ an inset exterior wall). Link to comment Share on other sites More sharing options...
rgardner Posted December 21, 2020 Share Posted December 21, 2020 Played with it as well. With a roof cuts wall exterior wall on 1st layer changed to not show layer and having the floor hung on that floor instead of upstairs it gets it as close as I have seen but still have about a 3"x3" angled white gap there in the corner but get's it really close. Must be something we are not seeing or a glitch for that scenario. Based on Chief's principles it will auto-build attic walls up but not down so there needs to be a small wall on either side on floor 1 to get rid of it but not sure why it is giving a little triangle gap. Link to comment Share on other sites More sharing options...
Michael_Gia Posted December 21, 2020 Author Share Posted December 21, 2020 Auto build roofs puts the roof height back to default and fixes the gaps but now your roof is no longer at the desired lowered height of -24”, as David and Kitchen Abode pointed out. Once you drop the roof again the gaps return. I am able to “fix” this at the front end of the house by making the floor above the garage 24” thicker but that only works if I’m ok with dropping the ceiling inside the garage for the entire ceiling surface of the garage (which I’m not) but I just want to point that out to show that the problem is definitely coming from the fact that the roof is being lowered to expose the floor structure above. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 21, 2020 Share Posted December 21, 2020 It’s one of the side effects of Chief’s room based modeling paradigm. It’s not only a problem with the walls that need to extend below the room definition but also a problem with the outside corner that lands above the roof where the roof cuts those 2 exterior walls down. Aside from patching with Polyline Solids, the only other solution I can think of is to insert a short floor and use an Open Below room. 1 Link to comment Share on other sites More sharing options...
robdyck Posted December 21, 2020 Share Posted December 21, 2020 On 12/21/2020 at 2:57 AM, Michael_Gia said: I've always just slapped on some p-solids to cover my shame, but there must be a more intelligent solution? Expand I would say, no, there isn't. P solids are the fastest, simplest, most stable way to handle this. I have the same condition all the time, and there are other ways, but they suck. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted December 21, 2020 Author Share Posted December 21, 2020 On 12/21/2020 at 6:09 PM, robdyck said: I would say, no, there isn't. P solids are the fastest, simplest, most stable way to handle this. Expand Thanks guys. It actually helps to know that there isn’t a solution almost as much as a solution itself, if you know what I mean. On 12/21/2020 at 6:07 PM, Alaskan_Son said: Chief’s room based modeling paradigm Expand I guess slapping on some p-solids is a small price to pay for having automatic room, labels, floor finishes, paint, trim and moulding, floor structure, ceiling structure etc... Compared to other software where all this has to be added manually, and updated when room divisions change. I guess we’re lucky. My wish list for Christmas would be to have the ability to “explode/ungroup” the exterior finish layer and the interior finish layer of walls so we could modify those as we do p-solids. Is that too much to ask for? Link to comment Share on other sites More sharing options...
robdyck Posted December 21, 2020 Share Posted December 21, 2020 On 12/21/2020 at 8:25 PM, Michael_Gia said: My wish list for Christmas would be to have the ability to “explode/ungroup” the exterior finish layer and the interior finish layer of walls so we could modify those as we do p-solids. Is that too much to ask for? Expand I hear what you're saying, and while I don't necessarily disagree, my opinion (for now) is that p-solids are so much faster than jumping through the multiple clicks of a dialog box. My favorite thing about a p-solid, is that in an elevation view, it will blend with the exterior finish layer and erase unwanted lines. of course, it does need to join accurately. Link to comment Share on other sites More sharing options...
DavidJames Posted December 21, 2020 Share Posted December 21, 2020 Revit has this feature. You can essentially unlock the siding and the exterior plywood layers which then allows you extend just those items in either direction on the Z-axis. It would be great if Chief was able to adopt the same ability. Base Extension.webmFetching info... On 12/21/2020 at 8:25 PM, Michael_Gia said: ... My wish list for Christmas would be to have the ability to “explode/ungroup” the exterior finish layer and the interior finish layer of walls so we could modify those as we do p-solids. Is that too much to ask for? Expand 2 Link to comment Share on other sites More sharing options...
