JECORMIER Posted January 2, 2020 Share Posted January 2, 2020 Ok, so I've been working on the plan now for the last 2 days and each day I save it as a new plan. Within an hour of saving it again this morning I started getting some slowdown in the commands. It didn't take but 5 minutes to then get to the point where it was not going to let me move a wall, adjust a sink or delete some hanging shelves in the master closet area. I have no idea what's going on. It's slowest and actually locks up when viewing the main level but is still very slow on second and basement levels. Things to note: Ran a virus check - nope (this file and whole computer). ANY other plan I open up through Chief 11 works just fine. I rebooted the computer several times. Any suggestions and or a way to clean the plan for unused files etc would be helpful. I don't even know if that's the answer. If, at the end of the day, I cannot get this cleared up is there a way to transfer to a new file without bringing the lockup issue with it? Gotta get this out today. Sheesh! Thank you all in advance for your suggestions. Justin CHAMPION_1-2-20.plan Link to comment Share on other sites More sharing options...
rgardner Posted January 2, 2020 Share Posted January 2, 2020 Do you have a survey dwg file imported in there? I am seeing some exterior elevation cameras off to the right which show a structure when opened (takes forever for them to open)... My guess is it is that imported item that you have there (file says it is missing when I turned on all layers. Also you have ALL of your labels on which sped things up slightly when I turned them off. Food for thought on what it might be. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 2, 2020 Share Posted January 2, 2020 Have not looked at the Plan but someone experiencing similar issues recently had accidentally turned on all his Labels eg Walls , Framing etc and Chief was struggling to update them all constantly. 1 Link to comment Share on other sites More sharing options...
DG1949 Posted January 2, 2020 Share Posted January 2, 2020 I would try to get the survey PDF out of the picture, maybe. I gave up on including PDFs in plan files because of slow down issues. Also, the SUV parked at the door. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 2, 2020 Share Posted January 2, 2020 Another known Issue is bad Symbols or Symbols with huge Polygon Counts (faces) eg from something off 3D Warehouse for example. M. 1 Link to comment Share on other sites More sharing options...
JECORMIER Posted January 2, 2020 Author Share Posted January 2, 2020 Ok, so I removed the pdf survey from the plan. Turned off roof planes. Turned off any labels that didn't need to show. Deleted the suv. ....And it still crashes. Hmmm Are there other layers that need to be turned off or could there be something with the staircase? I don't know, I'm grasping at straws here. ha Link to comment Share on other sites More sharing options...
JECORMIER Posted January 2, 2020 Author Share Posted January 2, 2020 I also went through and turned off any other layer that was not necessary. A blip faster but still crashes when I move a wall in the master bathroom area that I'm working on. Hmmm. Any other suggestions? Link to comment Share on other sites More sharing options...
JECORMIER Posted January 2, 2020 Author Share Posted January 2, 2020 Also, I'm sure there is a way to purge unused walls / layers / files associated with the plan? Any suggestions? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 2, 2020 Share Posted January 2, 2020 Justin, In your 1st post you mentioned that you had been saving as a "New Plan" each day. It could be that you are getting a lot of disk memory being use by multiple copies, backups auto-saved copies. Not knowing what your disk size is or what is available for swap space you may have inadvertently caused the problem completely external to Chief. Otherwise, you could contact customer support and see if they can solve the problem. Link to comment Share on other sites More sharing options...
JECORMIER Posted January 2, 2020 Author Share Posted January 2, 2020 Joe- Yeah, I looked at the disk space remaining and I've got plenty of space. Less than 40% taken up so far. Thanks for the help. J Link to comment Share on other sites More sharing options...
DG1949 Posted January 2, 2020 Share Posted January 2, 2020 On 1/2/2020 at 7:26 PM, JECORMIER said: still crashes when I move a wall in the master bathroom area that I'm working on. Expand It's probably just a fluke, but every time I tried to do anything to the wall between the Master Bedroom and the chimney > crash and burn. I deleted that wall and rebuilt and all seemed right again. Worth looking at all the interior walls in that location, or maybe even deleting them all and re-doing. 1 Link to comment Share on other sites More sharing options...
JECORMIER Posted January 2, 2020 Author Share Posted January 2, 2020 Ummmmm WINNER WINNER CHICKEN DINNER!!!!!!!!!!!!!!! That stupid wall between the master and great room was the issue. Deleted it and the rest of the master wing inside walls and presto, all's well with the world again. OMG. That was breaking my spirits over the last few hours. THANK YOU VERY MUCH! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 2, 2020 Share Posted January 2, 2020 On 1/2/2020 at 8:52 PM, JECORMIER said: That stupid wall between the master and great room was the issue. Expand Your problem is not the wall, its that you somehow managed to put 1,024 (one-thousand-twenty-four) doors in that wall instead of just the one that you actually need. Not sure how that happened, but group select and delete those doors from the wall and you should be good to go. I think you owe that wall an apology. 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 2, 2020 Share Posted January 2, 2020 On 1/2/2020 at 10:14 PM, Alaskan_Son said: you somehow managed to put 1,024 (one-thousand-twenty-four) doors in that wall Expand On 1/2/2020 at 10:14 PM, Alaskan_Son said: I think you owe that wall an apology. Expand That made me Smile ...thanks.... 2 Link to comment Share on other sites More sharing options...
JECORMIER Posted January 2, 2020 Author Share Posted January 2, 2020 I have NO earthly idea how those doors got there. Oh my! That last comment from Alaskan Son was AWESOME! Brahahaha Link to comment Share on other sites More sharing options...
Ridge_Runner Posted January 2, 2020 Share Posted January 2, 2020 In the PC world we unfortunately live in today you had better apologize to that wall or it may sue... Link to comment Share on other sites More sharing options...
Dermot Posted January 6, 2020 Share Posted January 6, 2020 Quote I have NO earthly idea how those doors got there. Expand Duplicate doors and windows are bad. I know, captain obvious here, but they can cause a lot more problems than just slow downs. There are a number of ways that you could have done this accidentally. It's pretty unlikely that you clicked on the Copy Paste in Place tool over a thousand times (or used the hotkeys to do the same thing). It's also very easy to create this many copies using the Transform Replicate dialog but I am guessing that this was unlikely as well. There may be a number of other ways that I am probably not thinking of at the moment. But all of this leads to me to the unfortunate suspicion that the program somehow did this. If you can somehow catch the program doing this again, then please report this to our tech support team along with the plan and steps to reproduce the problem. We absolutely need the steps to reproduce the problem because just sending us a plan with lots of duplicate doors won't help us very much. If this was the result of a program bug, we would certainly make it a high priority to fix. BTW, an easy way to figure out that you have duplicate doors is to use the marquee select method to select a door. The status bar should then show you how many you have when there are duplicates. On a side note, your plan posted above has a number of things that don't really make sense to me. For example, if you switch to the all on layer set, fill screen (F6), and use select all (control-a), you will see a rather strange railing about 500' off to the right. You also have some joist direction lines and cameras that are out in the middle of nowhere. You might want to clean up some of these things and you may have less problems in the future. Unlike some other cad programs, Chief's "smart" objects can actually cause negative side effects when they are used in ways that don't make sense to the program. For example, drawing two simple cad lines crossing each other should never be a problem but if you draw two elevation lines with different heights crossing each other you will probably blow up the terrain. 1 Link to comment Share on other sites More sharing options...
DG1949 Posted January 6, 2020 Share Posted January 6, 2020 On 1/2/2020 at 11:37 PM, Ridge_Runner said: you had better apologize to that wall or it may sue... Expand Are we sure the wall didn't create the doors while no one was looking? Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 6, 2020 Share Posted January 6, 2020 On 1/6/2020 at 4:50 PM, Dermot said: But all of this leads to me to the unfortunate suspicion that the program somehow did this. Expand Especially suspicious considering the number of doors is a result of "doubling" the number 1 ten times. Link to comment Share on other sites More sharing options...
Michael_Gia Posted January 7, 2020 Share Posted January 7, 2020 I remember once I had a hot key for “copy in place” but over time I thought it was simply “copy”. I eventually discovered that I had multiple everything in my plans. I caught it and corrected it. Check your hot keys. Link to comment Share on other sites More sharing options...
