GeneDavis Posted October 31, 2018 Share Posted October 31, 2018 I can get it to go away but it comes back, and when on screen at my preferred location (across bottom), won't let me do dialog work. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 31, 2018 Share Posted October 31, 2018 Gene, Can't you just resize the Chief Window so that it's above the Taskbar? If you set Chief to "Full Screen" it shouldn't cover the Taskbar and the Taskbar shouldn't cover any part of Chief. 1 Link to comment Share on other sites More sharing options...
CAmichael240114 Posted October 31, 2018 Share Posted October 31, 2018 In windows 10 settings, task bar settings, auto hide Link to comment Share on other sites More sharing options...
GeneDavis Posted October 31, 2018 Author Share Posted October 31, 2018 Thanks to both of you. I restarted Windows, and the problem seems to have gone away. I opened Chief, and to be safe, dragged its bottom edge up out of rage of the Windows taskbar. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 31, 2018 Share Posted October 31, 2018 34 minutes ago, GeneDavis said: Thanks to both of you. I restarted Windows, and the problem seems to have gone away. I opened Chief, and to be safe, dragged its bottom edge up out of rage of the Windows taskbar. Gene, Chief set to "Full Screen" - the little rectangle at the upper corner - should fill all space except the "Taskbar". If you have the little "double rectangle" showing then Chief is resizeable and could accidently interfere with the Taskbar. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted October 31, 2018 Share Posted October 31, 2018 I have the same Problem intermittently and end up dragging it above the Taskbar too , then try again at a later time , not sure if all these Win10 Updates resets something or not , or what else may cause it ...seems worse with X10 though...but again win10 has progressed too so...... M. Link to comment Share on other sites More sharing options...
AvoyeDesign Posted October 31, 2018 Share Posted October 31, 2018 I use a 32" as my primary and have never felt the need to hide it. I'd actually much rather it be visible because I am always switching windows, and opening a lot of pinned programs. There are many more benefits to a larger monitor. There is also a setting to lock the taskbar location, so you don't end up grabbing it unintentionally and dragging it around. Link to comment Share on other sites More sharing options...
JJohnson Posted November 1, 2018 Share Posted November 1, 2018 6 hours ago, KervinHomeDesign said: I use a 32" as my primary and have never felt the need to hide it. I'd actually much rather it be visible because I am always switching windows, and opening a lot of pinned programs. There are many more benefits to a larger monitor. I also pin my programs to the taskbar. That way you can right click on them and, with many programs, see a list of 12 recent files and pick the one to open with. This works with MS Word, Excel, and Notepad,Adobe Reader, and Paintshop as well as CA. This is a real time saver for me. Link to comment Share on other sites More sharing options...
AvoyeDesign Posted November 1, 2018 Share Posted November 1, 2018 10 hours ago, JJohnson said: I also pin my programs to the taskbar. That way you can right click on them and, with many programs, see a list of 12 recent files and pick the one to open with. This works with MS Word, Excel, and Notepad,Adobe Reader, and Paintshop as well as CA. This is a real time saver for me. I never knew that feature. I'll be using it a lot now, thanks. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 1, 2018 Share Posted November 1, 2018 A screen capture of my Windows Task Bar DJP Link to comment Share on other sites More sharing options...
JJohnson Posted November 2, 2018 Share Posted November 2, 2018 On 11/1/2018 at 9:28 AM, KervinHomeDesign said: I never knew that feature. I'll be using it a lot now, thanks. You're welcome. I think I learned that tip from Perry here on the forum. Link to comment Share on other sites More sharing options...
madcowscarnival Posted November 5, 2018 Share Posted November 5, 2018 Another screen sizing trick for folks who use keyboard more than mouse (I'm from command line AutoCad). This is valid in Windows 7, I would assume it translates in Windows 10. Hold the Windows Key and press arrow up for maximizing screen where it is currently located. Right/Left will shift to half-screen or the next monitor in multi setup. Down will return to original size, then minimize on second press. I find this easier/more intuitive than the drag and hold/snaps from the mouse, especially on laptops. 1 1 Link to comment Share on other sites More sharing options...
CharlesVolz Posted November 6, 2018 Share Posted November 6, 2018 One point for madcow. Link to comment Share on other sites More sharing options...
builtright3 Posted November 6, 2018 Share Posted November 6, 2018 With the screens being so wide these days I prefer to have the task bar on the right side of my screen. I have really gotten used to it and it works nicely! Also it does not obstruct Chief when I'm in full view as attached picture. Link to comment Share on other sites More sharing options...
