Dennis_Gavin Posted January 14, 2016 Share Posted January 14, 2016 just starting X8. Having trouble naming a new wall type. I can only get chiefs supplied name. Anyone else haveing this problem or know what the heck I might be doing wrong? Link to comment Share on other sites More sharing options...
BenPalmer Posted January 14, 2016 Share Posted January 14, 2016 yes, i think same problem i'm seeing?? I can copy a new wall and make changes, but I can't rename it no matter what I do. But i can still function with the wall, just can't rename it. i just sent a support request in on that and another item I found. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 14, 2016 Share Posted January 14, 2016 This is a very bad bug. I use the Wall Type name for Labels on Exterior Elevations. Link to comment Share on other sites More sharing options...
BenPalmer Posted January 14, 2016 Share Posted January 14, 2016 If confirmed, perhaps the Beta Testers can submit a report through there process to ensure it gets taken care of before the next release. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 14, 2016 Share Posted January 14, 2016 If confirmed, perhaps the Beta Testers can submit a report through there process to ensure it gets taken care of before the next release. Done! Link to comment Share on other sites More sharing options...
facer_03 Posted January 14, 2016 Share Posted January 14, 2016 I confirm same problem, thank you Joe_Carrick for reporting bug. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 15, 2016 Author Share Posted January 15, 2016 Also when I created a new wall type and assigned the outer layer to be stucco it was shown as siding in 3D, the default setting for an exterior wall. Link to comment Share on other sites More sharing options...
TimSchrock Posted February 3, 2016 Share Posted February 3, 2016 Same here...reporting. Link to comment Share on other sites More sharing options...
LevisL Posted February 4, 2016 Share Posted February 4, 2016 I found this bug last week and reported it. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 4, 2016 Share Posted February 4, 2016 This bug should have been fixed as soon as it was discovered IMO, which is now quite some time. It kills new wall type names which is crucial in almost any custom wall set-up. I also just did a presentation showing off CA to a kitchen design firm that I want to adopt Chief so we can work together more seamlessly. They bought Chief, with this bug, and can't create custom wall definitions. Not good. Needs fixing now. Link to comment Share on other sites More sharing options...
Kiwideziner Posted February 4, 2016 Share Posted February 4, 2016 This bug has been confirmed by CA and they are working on it. Link to comment Share on other sites More sharing options...
raltd9245 Posted February 4, 2016 Share Posted February 4, 2016 yes, i think same problem i'm seeing?? I can copy a new wall and make changes, but I can't rename it no matter what I do. But i can still function with the wall, just can't rename it. i just sent a support request in on that and another item I found. Thanks Ben IO thought it was only me Link to comment Share on other sites More sharing options...
BenPalmer Posted February 4, 2016 Share Posted February 4, 2016 Would definitely like a fix on this soon. This and another bug that effects how plans look visually are hindering my progress. However, I realize this is 'beta', and therefore will be risks involved with going totally X8. 1 Link to comment Share on other sites More sharing options...
Kiwideziner Posted February 4, 2016 Share Posted February 4, 2016 Ben what is the visual bug I have not seen it anywhere. Link to comment Share on other sites More sharing options...
BenPalmer Posted February 5, 2016 Share Posted February 5, 2016 Ben what is the visual bug I have not seen it anywhere. Graeme, for me it occurs when using openings that butts up against a 90 degree wall and it doesn't draw the line where they meet, and produces artifact lines in elevations as well. I haven't seen it discussed on this forum, so perhaps it is the way I work, but I have reported it to Chief. It shows up in new plans and plans brought forward from X7 and before that didn't show the problem. I sure hope they fix it in the next update. In attached screen shot, i've circled where lines aren't being produced, it's leaving it blank or white where the opening is meeting the adjacent wall. If i pull it back an inch, the line will show up. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 8, 2016 Share Posted February 8, 2016 To fix you can use the "Edit wall intersection" tool b/c a footing is also a wall Link to comment Share on other sites More sharing options...
BenPalmer Posted February 8, 2016 Share Posted February 8, 2016 Did that with no joy. Sometimes it works and sometimes it doesn't. It has more to do with the door jamb settings, but even that isn't consistent. Chief tells me they are working on it. Thanks for the suggestion. Link to comment Share on other sites More sharing options...
