twnctyguy Posted June 26, 2023 Share Posted June 26, 2023 I changed the eave fascia from the standard 7 1/4" to 5" on the addition to the main house, but you can see what happened. I have no idea how to fix this. As always any help is appreciated.333 Lucy Street Plan.plan 333 Lucy Street Plan.plan Link to comment Share on other sites More sharing options...
Kiwideziner Posted June 26, 2023 Share Posted June 26, 2023 Reduce the gable sub fascia to lift the soffitt Link to comment Share on other sites More sharing options...
twnctyguy Posted June 26, 2023 Author Share Posted June 26, 2023 Tried that, it doesn't change anything. Further, I did a test plan setting the eave fascia default at 5", and it turned out fine, plus the settings under "structure" are identical to mine, ingluding the gable sub fascia. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted June 26, 2023 Share Posted June 26, 2023 What you are showing are the eaves. Try changing the sub-eave. If that doesn't work, send a screen shot of the "structure" dbx. for the roof plane. Link to comment Share on other sites More sharing options...
GeneDavis Posted June 26, 2023 Share Posted June 26, 2023 It's a roof framing spec thing. Reduce the height of the eave subfascia by 2.25" Link to comment Share on other sites More sharing options...
twnctyguy Posted June 26, 2023 Author Share Posted June 26, 2023 I've tried changing everything including the rafter size, and it doesn't help. Structure dbx attached. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 26, 2023 Share Posted June 26, 2023 30 minutes ago, twnctyguy said: I've tried changing everything including the rafter size, and it doesn't help. Structure dbx attached. The "Eave Sub Fascia" is what the Soffit attaches to so it must be less than the "Eave Fascia" by the thickness of the soffit and usually a bit more which creates a drip edge. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted June 26, 2023 Share Posted June 26, 2023 9 hours ago, Chopsaw said: The "Eave Sub Fascia" is what the Soffit attaches to so it must be less than the "Eave Fascia" I always make it 1 inch less. That seems to work. Although this dialogue box is one of the world's great unsolved mysteries. Thankfully Chief’s auto roof gets things mostly right, otherwise I’d still be working on my first plan. 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 26, 2023 Share Posted June 26, 2023 also is auto roof framing on? Link to comment Share on other sites More sharing options...
CAmichael240114 Posted June 26, 2023 Share Posted June 26, 2023 Sub Fascia Depth/Height Setup Top of rafter to top of soffit lining measured at the back of th fascia Link to comment Share on other sites More sharing options...
CharlesVolz Posted June 27, 2023 Share Posted June 27, 2023 Also, make sure it is re-framing, i.e., auto frame roofs is on or manually select roof plane(s) and select frame. Link to comment Share on other sites More sharing options...
