HumbleChief Posted January 29, 2022 Share Posted January 29, 2022 Simple deck. The 'deck beam' (and posts) locates itself at approx. 12" from the outside edge of deck. I would like the deck beam and support posts to be flush with the outside edge of deck. Is there a setting for same? Simple to move it of course but that turns off auto framing. Simple again to set up manually but was wondering if there's an 'offset deck beam' or posts from 'edge' similar to the post offset from 'end' setting somewhere? Thanks deck beam.plan Link to comment Share on other sites More sharing options...
robdyck Posted January 29, 2022 Share Posted January 29, 2022 Nope. You are SOL on that one. There are offsets for the posts, but no offsets for the beam, or an option for a flush beam. I never use Chief's deck framing because almost every deck I draw uses a flush beam because they are all covered decks and the roof beam and posts need to be at the outside corners. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted January 29, 2022 Share Posted January 29, 2022 Deck beam spacing you control in Deck Room Type Defaults I have my set to 14' feet for 16' decks (most common around here" and if I have a 14' deck I change the value to 12' spacing for a 2' setback Link to comment Share on other sites More sharing options...
SH_Canada Posted January 30, 2022 Share Posted January 30, 2022 i believe it is hardcode to a min cantilever of 12 or 16" (to center of beam) from my previous experimentation Link to comment Share on other sites More sharing options...
Kbird1 Posted January 30, 2022 Share Posted January 30, 2022 1 hour ago, SH_Canada said: i believe it is hardcode to a min cantilever of 12 or 16" (to center of beam) from my previous experimentation I think that is correct from previous posts on this issue ....... Link to comment Share on other sites More sharing options...
HumbleChief Posted January 30, 2022 Author Share Posted January 30, 2022 Thanks you guys. Appreciate the feedback. I also saw the deck beam spacing setting but couldn't get the beam out flush or any other location than the 12" hard coded distance. Thanks again. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted January 30, 2022 Share Posted January 30, 2022 13 hours ago, SH_Canada said: i believe it is hardcode to a min cantilever of 12 or 16" (to center of beam) from my previous experimentation It could be in Canada, in US maximum allowable overhang cannot exceed 1/4 of the actual main joist span. Link to comment Share on other sites More sharing options...
HumbleChief Posted January 30, 2022 Author Share Posted January 30, 2022 1 hour ago, Greg_NY61 said: It could be in Canada, in US maximum allowable overhang cannot exceed 1/4 of the actual main joist span. Interesting, did not know this. Link to comment Share on other sites More sharing options...
SH_Canada Posted January 30, 2022 Share Posted January 30, 2022 3 hours ago, Greg_NY61 said: It could be in Canada, in US maximum allowable overhang cannot exceed 1/4 of the actual main joist span. I'm saying CA is enforcing a min 12" (you cannot have a smaller cantilever through configuration) This CA harcoded limitation comes into play when I have a 3' or 3'6 landing/deck. CA puts the beam at 2/2'6 feet from the house, when in reality the cant should be less than 12" in order to observe the rule. in other words, CA is not observing the rule. And course, the other issue is it does not allow flush beams to be configured, in order to pick up columns Link to comment Share on other sites More sharing options...
parkwest Posted January 30, 2022 Share Posted January 30, 2022 Can you draw your beams in free-hand? Link to comment Share on other sites More sharing options...
MoeGia Posted January 31, 2022 Share Posted January 31, 2022 I set my deck beam to be 1/8" x 1/8". The posts build to the almost correct height. I then move them into the correct location. It solves half of the problem. Link to comment Share on other sites More sharing options...
rgardner Posted January 31, 2022 Share Posted January 31, 2022 56 minutes ago, MoeGia said: I set my deck beam to be 1/8" x 1/8". The posts build to the almost correct height. I then move them into the correct location. It solves half of the problem. Try playing with setting your posts using the post tool to see if they set to right height so you don't have to do it this way... Link to comment Share on other sites More sharing options...
HumbleChief Posted January 31, 2022 Author Share Posted January 31, 2022 20 hours ago, parkwest said: Can you draw your beams in free-hand? Yeah super easy to move once drawn, was just curious if I had missed a setting. Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 31, 2022 Share Posted January 31, 2022 1 hour ago, HumbleChief said: Yeah super easy to move once drawn, was just curious if I had missed a setting. Please add your support to these feature requests in Suggestions forum: Link to comment Share on other sites More sharing options...
