HumbleChief Posted February 4, 2021 Share Posted February 4, 2021 Is there a way to draw a complete circle with the curved wall tool? I can get close but then have to draw a supplemental wall to complete the circle. Trying to create a turret entry about 20 feet high but am stymied at this point and the 2 walls for the circle seem to be messing me up. Can't post the proprietary plan at this time but thought maybe others had experience with same? EDIT: Changed the title as I am having no luck with a turret entry. Is it doable? Also wondering if you would use a second floor for the higher turret or just raise the ceiling of the first floor within the turret? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 4, 2021 Share Posted February 4, 2021 On 2/4/2021 at 2:32 PM, HumbleChief said: Is there a way to draw a complete circle with the curved wall tool? I can get close but then have to draw a supplemental wall to complete the circle. Trying to create a turret entry about 20 feet high but am stymied at this point and the 2 walls for the circle seem to be messing me up. Can't post the proprietary plan at this time but thought maybe others had experience with same? EDIT: Also wondering if you would use a second floor for the higher turret or just raise the ceiling of the first floor within the turret? Expand Obviously, you can use (2) 180 degree curverd walls to complete the circle. Can you explain how they are "messing you up"? Link to comment Share on other sites More sharing options...
HumbleChief Posted February 4, 2021 Author Share Posted February 4, 2021 On 2/4/2021 at 2:49 PM, Joe_Carrick said: Obviously, you can use (2) 180 degree curverd walls to complete the circle. Can you explain how they are "messing you up"? Expand Thanks Joe, my skills are 'obviously' lacking in some regards and that worked great. I've attached a simple plan that shows the framing and the 'messed up' framing or roof connection in a turret entry. This plan is with a first floor higher ceiling and am just a bit lost as I've never tackled a turret entry before. TURRET PLAN 1.planFetching info... Link to comment Share on other sites More sharing options...
HumbleChief Posted February 4, 2021 Author Share Posted February 4, 2021 Looks like a second floor is the better option...but? There's a bit of roof interaction that I have not been able to resolve no matter the settings I've chosen. Curious about other and or more accepted practices for a turret roof/entry? Is it even feasible in Chief? Thanks TURRET PLAN 2.plan Link to comment Share on other sites More sharing options...
HumbleChief Posted February 4, 2021 Author Share Posted February 4, 2021 Here's the best I can do on the house plan with a second floor. Is this even doable in Chief? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 4, 2021 Share Posted February 4, 2021 I think it's a setting "Roof Cuts Wall at Bottom" or similar. You will likely need to frame the walls also to get it to work correctly. I don't have time to study it right now but maybe someone else will chime in. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 4, 2021 Author Share Posted February 4, 2021 On 2/4/2021 at 3:58 PM, Joe_Carrick said: I think it's a setting "Roof Cuts Wall at Bottom" or similar. You will likely need to frame the walls also to get it to work correctly. I don't have time to study it right now but maybe someone else will chime in. Expand Thank you Joe. I'm getting closer with some searching. Found the "Segment Angle at Curved Wall:" setting and the "Min Alcove Size" setting which has helped in a couple of areas. Still not great and see a lot of work ahead to reproduce something like the attached pics. Link to comment Share on other sites More sharing options...
SNestor Posted February 4, 2021 Share Posted February 4, 2021 @HumbleChief - I attempted to get your plan to work...but, no luck. However, I opened my template and I was able with auto rebuild roofs to achieve what you are attempting...so, might be something with your plan/template? Link to comment Share on other sites More sharing options...
HumbleChief Posted February 4, 2021 Author Share Posted February 4, 2021 On 2/4/2021 at 6:19 PM, SNestor said: @HumbleChief - I attempted to get your plan to work...but, no luck. However, I opened my template and I was able with auto rebuild roofs to achieve what you are attempting...so, might be something with your plan/template? Expand THANK YOU Steve. VERY interesting. I've messed with wall defs in defaults and other things that might be messing things up in my template. I'll check. Curious did you use a second floor? Are the walls on the first floor invisible or did you check the interior view? Or is that a single floor with a higher ceiling? Does the interior open only to above? Perhaps I could check your plan? Thank you again. Link to comment Share on other sites More sharing options...
SNestor Posted February 4, 2021 Share Posted February 4, 2021 @HumbleChief - my plan attached. Round Room - Auto Roof Ex Plan 21-0204 ver-02.planFetching info... Link to comment Share on other sites More sharing options...
HumbleChief Posted February 4, 2021 Author Share Posted February 4, 2021 THANKS. Second floor seems to be the only real option and got it to work but changed so many things that I don't know what was wrong Now the fun begins....Thanks again. Link to comment Share on other sites More sharing options...
DzinEye Posted February 4, 2021 Share Posted February 4, 2021 I'm watching this thread with interest as there are a few ongoing issues with this turreted room. I used auto-build roofs to get the turret roof, but lots of niggling issues after all the necessary manual operations. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 4, 2021 Author Share Posted February 4, 2021 I'm ready for a few niggling issues myself.... Link to comment Share on other sites More sharing options...
rgardner Posted February 4, 2021 Share Posted February 4, 2021 On 2/4/2021 at 6:52 PM, HumbleChief said: Second floor seems to be the only real option Expand Didn't mess around with this but I believe from a similar situation that the key would be to not use attic walls between so thus having a balloon framed wall if not the second story or the walls around the first floor main roof get messed up with the faceting. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 4, 2021 Author Share Posted February 4, 2021 On 2/4/2021 at 10:42 PM, rgardner said: Didn't mess around with this but I believe from a similar situation that the key would be to not use attic walls between so thus having a balloon framed wall if not the second story or the walls around the first floor main roof get messed up with the faceting. Expand Thanks Ryan will keep that in mind. Link to comment Share on other sites More sharing options...
glennw Posted February 4, 2021 Share Posted February 4, 2021 Larry, i think the reason for the messed up walls in your original plan is the different faceting between the curved roof edge and the curved wall. The curved wall is a lot smoother curve than the curved roof edge. This is causing the curved roof edge (made up of straight sections) to cut into the wall layers. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted February 5, 2021 Share Posted February 5, 2021 Hey Larry, maybe you need to downgrade your software. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 5, 2021 Author Share Posted February 5, 2021 On 2/4/2021 at 10:57 PM, glennw said: Larry, i think the reason for the messed up walls in your original plan is the different faceting between the curved roof edge and the curved wall. The curved wall is a lot smoother curve than the curved roof edge. This is causing the curved roof edge (made up of straight sections) to cut into the wall layers. Expand Thanks Glenn, AND the roof frames to inside of the wall above roof plane instead of the outside edge when a single floor is used. A second floor solves that and the roof frames completely differently. Here's a shot of a roof plane framing to the inside wall of the wall above the roof plane. Seems like it simply cannot be done with a single floor. The turret in the background has a second floor. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 5, 2021 Author Share Posted February 5, 2021 On 2/5/2021 at 8:08 AM, Rich_Winsor said: Hey Larry, maybe you need to downgrade your software. Expand Funny - but wait it is possible to create the illustrated structure in Chief Home Designer but.... Link to comment Share on other sites More sharing options...
dshall Posted February 5, 2021 Share Posted February 5, 2021 Larry, try using a true curved polyline to create a true curve to that roof plane. Do not use the segmented curve for roof plane. just a guess. 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted February 5, 2021 Author Share Posted February 5, 2021 On 2/5/2021 at 8:50 PM, dshall said: Larry, try using a true curved polyline to create a true curve to that roof plane. Do not use the segmented curve for roof plane. just a guess. Expand Thanks Scott, the second floor option works great and not going to mess with the only one floor option. Have you ever tackled a tall turret like shown? Link to comment Share on other sites More sharing options...
HumbleChief Posted February 6, 2021 Author Share Posted February 6, 2021 On 2/5/2021 at 8:50 PM, dshall said: Larry, try using a true curved polyline to create a true curve to that roof plane. Do not use the segmented curve for roof plane. just a guess. Expand Fascinated by this idea as it might solve another challenge but can't find a way to "us(e) a true curved polyline to create a true curve to that roof plane." Is this possible? Link to comment Share on other sites More sharing options...
HumbleChief Posted February 6, 2021 Author Share Posted February 6, 2021 WOW, this is proving to be an absolute nightmare. Maybe I can download the house plans for the image shown above advertising the Home Designer Suite? Clearly it shows that this type of building can be created in the software? Or can it? And mad props to you Mark for getting as far as you did with your design... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2021 Share Posted February 6, 2021 On 2/6/2021 at 1:50 PM, HumbleChief said: Fascinated by this idea as it might solve another challenge but can't find a way to "us(e) a true curved polyline to create a true curve to that roof plane." Is this possible? Expand Sort of. You have to use boolean operations (usually subtraction) to get a true arc onto a roof plane. They don't behave when they're true arcs though and you still need to Convert Curve to Polyline. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2021 Share Posted February 6, 2021 By the way, Glenn hinted at it earlier, but it would really help if you were to adjust your Segment Angle at Curved Wall in your Build Roof dialog. Turn it all the way down. I think you can only set it to 6 but that will likely be enough. Using the method I mentioned above you can go even lower but that would mean switching to manual roofs. Link to comment Share on other sites More sharing options...
