dshall Posted December 14, 2020 Share Posted December 14, 2020 Hey guys, I thought we could have a plan view in layout displaying single line framing and then another view in layout displaying double line framing. Is this true or not? Again late to the party on this, but can it be done? 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 14, 2020 Share Posted December 14, 2020 6 hours ago, dshall said: Hey guys, I thought we could have a plan view in layout displaying single line framing and then another view in layout displaying double line framing. Is this true or not? Again late to the party on this, but can it be done? Sorry bud, this isn't a view specific setting. It's all one way or all the other. Link to comment Share on other sites More sharing options...
dshall Posted December 15, 2020 Author Share Posted December 15, 2020 19 hours ago, Alaskan_Son said: Sorry bud, this isn't a view specific setting. It's all one way or all the other. Thanks Michael, that is what I thought. I sure wish it was view specific. Link to comment Share on other sites More sharing options...
dshall Posted December 15, 2020 Author Share Posted December 15, 2020 To follow up on that, we can use single line for the first floor and double line for the second floor. Hmmmm, I wonder if I can use ref layers..... probably too much trouble at this time. Link to comment Share on other sites More sharing options...
rgardner Posted December 15, 2020 Share Posted December 15, 2020 1 hour ago, dshall said: To follow up on that, we can use single line for the first floor and double line for the second floor. Hmmmm, I wonder if I can use ref layers..... probably too much trouble at this time. Good thought but the likelihood of your upper joists lining 100% with lower is doubtful... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 15, 2020 Share Posted December 15, 2020 Scott, you could create a copy of the Plan File with the opposite framing display preference. Then send to layout from each Plan. Might be a pain to keetp coordinated when changes are made - since the identical changes would have to be made to each plan. OTOH, if the copy is only created when the project is completed it wouldn't be a problem. 2 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 15, 2020 Share Posted December 15, 2020 Just now, Joe_Carrick said: Scott, you could create a copy of the Plan File with the opposite framing display preference. Then send to layout from each Plan. Might be a pain to keetp coordinated when changes are made - since the identical changes would have to be made to each plan. OTOH, if the copy is only created when the project is completed it wouldn't be a problem. I agree with Joe. This is probably the most efficient solution. Just add a quick Save As to part of your workflow before printing your layouts. Link to comment Share on other sites More sharing options...
glennw Posted December 16, 2020 Share Posted December 16, 2020 I think I would rather keep things in the one plan to ensure consistency. You could create a Cad Detail From View of just the floor joists displaying (either single or double lines), copy into plan, turn off the framing display and then just use Cad detail to display one or both of the joist display types. You would probably only need 1 cad detail of the joists as an alternative to the dynamic display type (single or double lines - whichever one you prefer), controlled by layer display/saved plan view. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 16, 2020 Share Posted December 16, 2020 4 hours ago, glennw said: I think I would rather keep things in the one plan to ensure consistency. You could create a Cad Detail From View of just the floor joists displaying (either single or double lines), copy into plan, turn off the framing display and then just use Cad detail to display one or both of the joist display types. You would probably only need 1 cad detail of the joists as an alternative to the dynamic display type (single or double lines - whichever one you prefer), controlled by layer display/saved plan view. CAD was my first thought too, but ultimately, I see the Referenced Plan as being way faster and far less error prone. If you make any changes to the Plan... With the CAD method you have to delete the old CAD, switch Layer Set, create new CAD Detail, switch Layer Set back, copy and Paste CAD, and Delete extra CAD Detail. With the second plan method all you have to do is Save As 2 times and you're done. Of course you have to change the Plan Display back and forth for both methods. Link to comment Share on other sites More sharing options...
ACVNarch Posted September 9, 2022 Share Posted September 9, 2022 As of x14, it appears that the "Use Line for Framing" default is floor specific, but not view-specific. Compare 1st & 2nd floor of the Framing, Roof Plan View: FramingLines.plan Link to comment Share on other sites More sharing options...
dshall Posted September 9, 2022 Author Share Posted September 9, 2022 1 minute ago, ACVNarch said: As of x14, it appears that the "Use Line for Framing" default is floor specific, but not view-specific. Compare 1st & 2nd floor of the Framing, Roof Plan View: FramingLines.plan 4.86 MB · 0 downloads Thanks for bringing this up again. I think it would be wonderful if it was VIEW SPECIFIC. Example: in floor plan I would like to show ridge beams as double dash line and in framing plan I would like to show the ridge beam as single dashed line. 2 Link to comment Share on other sites More sharing options...
ACVNarch Posted September 9, 2022 Share Posted September 9, 2022 I submitted a suggestion. Hopefully CA will improve the feature (I also plagiarized your example, hope that's OK!) 1 Link to comment Share on other sites More sharing options...
dshall Posted September 9, 2022 Author Share Posted September 9, 2022 Thanks for sending that in. I have requested it before. I also talked to the Chief Muckety Mucks at the UGM about this.... specifically Brian. The more folks that request it the sooner it happens. BTW, the UGM was awesome this year, the CA team was awesome, and I learned a lot. It was probably the best UGM I have attended..... maybe because I learned a lot. They said they had 144 folks attending which apparently is a record. I hope to return next year. 1 Link to comment Share on other sites More sharing options...
ROAMdesignstudio Posted August 8, 2024 Share Posted August 8, 2024 If you are still looking for this, I just found that it is in the default settings under framing. In plan display, there is a tab to toggle on/off single line vs double. 1 Link to comment Share on other sites More sharing options...
tundra_dweller Posted July 19 Share Posted July 19 Does anyone know where the framing display option for plan view (line vs. box) went in X17? The help file says the setting is in automatic framing defaults, but I can't find it there or anywhere else. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 19 Share Posted July 19 2 minutes ago, tundra_dweller said: Does anyone know where the framing display option for plan view (line vs. box) went in X17? The help file says the setting is in automatic framing defaults, but I can't find it there or anywhere else. Its in the General Plan Defaults now Link to comment Share on other sites More sharing options...
tundra_dweller Posted July 19 Share Posted July 19 2 minutes ago, Alaskan_Son said: ts in the General Plan Defaults now Thanks! I must have looked right past it. Link to comment Share on other sites More sharing options...
jtcapa1 Posted Wednesday at 10:46 PM Share Posted Wednesday at 10:46 PM I'll upvote that suggestion on single lines versus double lines for framing. I think there is a real good need for this option. Link to comment Share on other sites More sharing options...
Renerabbitt Posted Wednesday at 11:04 PM Share Posted Wednesday at 11:04 PM 18 minutes ago, jtcapa1 said: I'll upvote that suggestion on single lines versus double lines for framing. I think there is a real good need for this option. what suggestion? we can do this currently? Link to comment Share on other sites More sharing options...
jtcapa1 Posted Wednesday at 11:06 PM Share Posted Wednesday at 11:06 PM It was the OP's suggestion. Would have thought that was clear. Are you saying that it changed in X17? I've not checked. Link to comment Share on other sites More sharing options...
Renerabbitt Posted Wednesday at 11:11 PM Share Posted Wednesday at 11:11 PM 4 minutes ago, jtcapa1 said: It was the OP's suggestion. Would have thought that was clear. Are you saying that it changed in X17? I've not checked. sorry I missed the request about it being different for different views Link to comment Share on other sites More sharing options...
tundra_dweller Posted Wednesday at 11:29 PM Share Posted Wednesday at 11:29 PM I assume since the line vs box setting is in general defaults now that it's a plan-wide setting versus by floor as in previous versions. By the view would be optimal. I haven't messed with it in X17 other than try to figure out where the setting went. Link to comment Share on other sites More sharing options...
DBCooper Posted yesterday at 05:04 AM Share Posted yesterday at 05:04 AM Quote I'll upvote that suggestion on single lines versus double lines for framing. I think there is a real good need for this option. I don't think this technically counts as a suggestion since it is in the Q&A forum so a plus one probably won't mean anything. You might want to post something on the suggestions forum instead. Link to comment Share on other sites More sharing options...
dshall Posted yesterday at 02:23 PM Author Share Posted yesterday at 02:23 PM 15 hours ago, Renerabbitt said: sorry I missed the request about it being different for different views I have long wished for different setting for single line vs double line depending on the view. In floor plan I would like the double line, in framing view I would like single line. Link to comment Share on other sites More sharing options...
Renerabbitt Posted yesterday at 02:28 PM Share Posted yesterday at 02:28 PM 4 minutes ago, dshall said: I have long wished for different setting for single line vs double line depending on the view. In floor plan I would like the double line, in framing view I would like single line. You coming to Idaho next month? Link to comment Share on other sites More sharing options...
