Making Projects More Photo Realistic?
buildinthevoid
6 minutes ago, buildinthevoid said:
Hey so I’m trying to find a way to make my projects look as photo realistic as possible. Ray tracings improve my projects a lot, but I was wondering if there are any other techniques or compatible softwares with Chief Architect to enhance how a project looks in terms of realism?
Do a search on PBR inside Chief....if you're talking actual photo grade where you can't tell the difference of a real photo vs rendering you will need to supplement with 3rd party software.
Lumion or Twinmotion
Ultra real = VRay
  • Upvote 2
On 12/3/2020 at 6:31 PM, buildinthevoid said:
Gotcha. Would I be able to import a project from Chief Architect to any of these softwares and enhance them from there?
X13 will have enhanced PBR RTRT views in the Windows version (only) if you have a Nvidia RTX capable video Card,
but there are also other render Apps like Twinmotion and D5 Render which are free ( or were) but come with the added
complexity of learning another program.
Lumion is on of the better paid Renders as Johnny mentioned but still not quite photo-realistic from what I have seen
Unreal engine is out there too , but last time I looked it was harder to get files out of Chief for it...though that may have changed?
Best for me is to export from Chief as DAE (no vertex limit as in 3ds), convert to FBX (with FBX converter from AC),
then import into Sketchup (via TRANSMUTR)----and only then render in Vray for photorealistic results.
Just learning to put in 3D grass. Next is to start using LAUBWERK to put in trees and bushes.
It has taken me a long to figure this pipeline out, but the results from Vray are taking me to the quality of light/rendering I want.
Chief geometry is superb to work with. Attached are a couple of draft renders as per time of day in SKP/Vray.
I'm curious why you're trying to get to an FBX file in your process?  You can export from Chief to Collada (as you do now) and then import that right into Sketchup and its a pretty clean file without the 3DS issues.  I do wish Chief exported FBX directly for other reasons, but unless you plan to use the file in Unreal Engine or other gaming software I don't see the point of adding that step....but i'd love to hear your reason.  Perhaps there is some other advantage I'm not aware of.
Another thing i'm trying is using Vray with Blender which I find is WAY WAY better to organically shape terrains.  Not only that but Blender is free and very robust.
I have never been able to take a Collada file directly into Sketchup with materials attached correctly to the geometry
(as per image).
However, when I translate the collada file to fbx, it attaches the materials. It embeds media properly.
But the reason for fbx is to be able to use Transmutr. It brings my model cleanly into SKP. Equally important, it can make any
model I bring in as a proxy for Vray before I open it up. I have not tried it just yet, but the potential to import a whole slew of houses or trees, etc. as proxies
(and reduce file size) so as to not grind SKP to a halt is something I want to be able to do, for sure.
You are absolutely right about using Vray in Blender. Collada into Blender works very well, of course. So that could be the ideal solution, but in truth,
I am reasonably comfortable in SKP and just do not have the heart to learn one more program right now.
BTW, Vray 5 for Sketchup on a PC can produce real-time renderings. Unfortunately, it is not yet available for a Mac (nor sure when).
On 12/5/2020 at 3:08 PM, joey_martin said:
I have been playing with Twinmotion recently. These are Chief models exported in 3DS format. I have spent just a few hours with TM and this is what I have come up with.
Hey Joey, I got the free version of TM but I have
never gotten around to playing with it yet. Not to
be a nit picker but I was curious as to why the light
shining from the fixtures over the garage doors
seems to be displaced up and to the left of where
one would expect it to fall on the wall and doors?
Just wondering?
If i were to send over a chief architect file to someone with Sketchup, would they be able to open it as a .plan file?
No , not as a .plan file , only Chief and the Home Designer Products can open them...
(as per image).
That is interesting...i've tried several models into Sketchup with collada and the textures come in just fine....so just FYI maybe there is some subtle issue - but if the whole system works for you then I guess it works.
I will try to import Collada directly into SKP again and see if I can find that 'subtle issue', but changing a dae file into
an fbx file is only a matter of 5 seconds or less. What is important to me here is TRANSMUTR.
Transmutr only imports fbx, not collada, but it does what I need really well: It reduces file
size to begin with, and further, converts anything I bring in to Vray proxies. This eliminates trying to work with large files
in SKP itself, yet gets things set up to correctly render the proxies when in Vray.
It is possible to get really nice results from the Ray Trace feature in Chief. I've found that the most important things to learn are materials (and material properties), lighting and Ray Trace settings. There's really no easy answer, you just need to take the time to learn each of the settings and experiment so you can see the effect on the final image. Below are a couple of examples that were modeled and rendered in Chief:
1797534325_1318FlowerCtSWRTa.thumb.jpg.b8e4dab3712b153cdf1a09e3692a64bc.jpg1353648009_LivingRoom-Modern02-RTa.thumb.jpg.085ffc2697597fa4fa81f31061f342ee.jpg
A great place to start is with these videos - https://www.chiefarchitect.com/search/?default_tab=video&q=ray+tracing
On 12/6/2020 at 2:21 PM, joey_martin said:
@Rich_Winsor as far as I know the lights don't come with the export so I added them from the TM library. They must be off a bit, I hadn't noticed.
I wasn't picking on you, just trying to figure
out the process. I may be over-sensitive to
this issue as I just installed a pair of similar
fixtures on my project so I can see where
the light actually shines. :)
To completely digress I will give an unsolicited
testimonial to Genie for their new wall mounted
garage door openers. I just installed the first
garage door (as seen in the pic) with the wall
mounted opener and it's a WAY simpler and
more efficient system. Installing the unit literally
involves tightening 3 set screws onto the torsion
shaft and lagging one bracket to the wall.
what about your upper and lower limits?
I'm using TwinMotion when I need to produce higher-end renderings. This is a screen porch addition modeled in Chief with lights and vegetation from TwinMotion. It's not photorealistic, but it's significantly faster and better than a Chief raytrace. These particular examples use TwinMotion's Light Line filter (there are several available "artistic" filters):
1809815461_Image5-Exterioreastside.thumb.png.944626b234b28335eade932e1987817d.png1122763726_Image8-BreezewaylookingintoPorchatnight.thumb.png.867f26a394e1d428d59a8877940f688b.png
Nice, Robert. I especially like the the daylight shot and the vegetation. May have to dust off my copy of TM. I used it on a limited basis for exterior views when it first came out, but have been swamped with work for some time and just relying on CA. I hope X13 will be much improved in this area and their RTRT.
Better get a longer column or your house may fall down ( pic 2 ) :)
   Renderings look great ,  btw
Check out this if you haven't already it seems to make use of vray ..
https://www.chaosgroup.com/gallery/arc-media-chelsea-island
Real simple 3 button (set/up/down) system to
program the limits. It also has a nice feature
where the speed of the door opener is regulated
so that it slows down when it starts and stops a
cycle. When you close the door it starts slowly
for about the first foot or so and then briskly
continues on down until about the last foot of
travel where it slows down again and nestles
down on the weather seal like a butterfly with
sore feet. B)
Yes, once I am into final renders I will have to make sure my house doesn't appear to fall down.......:)
Thanks for the link---good interior renderings.
Another solid little model in Chief, including siding materials, boxes and flowers, brought into Sketchup (I Am now buying better entourage).
I like the quality of the sunlight in Vray and how the interiors glow with bounced light.
