robdyck Posted March 19, 2020 Share Posted March 19, 2020 Here's a life changing earth shattering tip for new users to Chief. Have you ever wondered if there was a logical way to start drawing a floor plan? Well, there is. It's called the 'Reference Grid'. Unfortunately, Chief's out-of-the-box settings have this grid set so light that it's hardly visible. Let's take a look at those settings: Next, let's see what a working screen looks like using a typical plan started from a Chief template: The whole building... A closeup: Notice that neither the Reference Grid, nor the Snap Grid are clearly visible. Let's change those colors so we can see them better. I've turned on 'Walls, Main Layer Only' in order to help see the wall drawing process. Notice in the view above that none of the walls align with either Grid. This should be addressed before you start drawing anything. 1. Change the Grid colors so you can see them. 2. Using the Input Point tool, place a CAD Point as shown below: This new point would be a great spot to: 1. Place a Marker and specify it as Framing Reference 2. Start drawing the floor plan in a clock-wise fashion. This will place your project in the positive portion of the x and y axis and help you have an intuitive grasp as to the buildings location as well as object locations. Everything will flow much easier, and I'm pretty sure both Chief and your computer will want to give you a hug. 1 3 Link to comment Share on other sites More sharing options...
QualicoreHomes Posted March 19, 2020 Share Posted March 19, 2020 Thanks for explaining that. I did not know this but had wondered before where the "ground 0" would be. Link to comment Share on other sites More sharing options...
SNestor Posted March 21, 2020 Share Posted March 21, 2020 I personally don’t like the snap grid lines to be “on” and almost never use them. For plan development I like to set the grid snap to either 12” or sometimes I’ll set it to 4”. You don’t need to see the grid to use a fixed snap dimension - and the grid lines just make the drawing that more complex. Rough in the exterior walls to even dimensions - then autu dimension - then go around clockwise and adjust the wall offset dimensions as needed. Fast and simple. Link to comment Share on other sites More sharing options...
Kiwideziner Posted March 21, 2020 Share Posted March 21, 2020 Never used the grid function that I can remember in 20 years of using CA. They are just more lines to contend with 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 21, 2020 Share Posted March 21, 2020 Been a user since 1995, when they added the "Grid" back in version X5 or so, I never used it on purpose, it is the first thing I turn off before starting a plan (The snap grid actually makes it harder for me to precisely place objects as they "snap" to the "Grid" instead of where I often intend those objects to go, no thank you, thank you VERY much! DJP PS: it IS ok for others to use the POS 1 Link to comment Share on other sites More sharing options...
glennw Posted March 21, 2020 Share Posted March 21, 2020 Having that stupid Reference Grid displaying is one of my pet peeves! I hate the thing but I find it is turned on in just about every Chief plan I look at. 1 Link to comment Share on other sites More sharing options...
dshall Posted March 21, 2020 Share Posted March 21, 2020 I never use it. I only ensure that the first wall I draw is located at an absolute point that is not a fraction. 1 Link to comment Share on other sites More sharing options...
parkwest Posted March 21, 2020 Share Posted March 21, 2020 I wonder how much scrap lumber would be reduced if houses were designed on 2 foot snap intervals or even possibly 4 foot? 1 Link to comment Share on other sites More sharing options...
basketballman Posted March 21, 2020 Share Posted March 21, 2020 On 3/21/2020 at 12:47 PM, parkwest said: I wonder how much scrap lumber would be reduced if houses were designed on 2 foot snap intervals or even possibly 4 foot? Expand Probably enough to build a few houses ... 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted March 21, 2020 Share Posted March 21, 2020 The only time I display graph lines is in layout files that I create to do sketching. I have one I made for an 11x17 sheet that I bring to sites when doing field measure and then one that I have for 8.5x11 sheets for notes when I need to sketch a quick detail and send out for an RFI. If the snap grid is on by mistake (new install of the program, etc.) the discovery is followed by language I generally reserve for responses to news reports by politicians. Link to comment Share on other sites More sharing options...
Gawdzira Posted March 21, 2020 Share Posted March 21, 2020 One of my professors designed a near zero waste building. A pyramidal hip roof that used all plywood without scraps. His design would be even more relevant today with better pre-cut engineered lumber packages. While it was a nice simple design, it was not heavy on being a beautiful design. More like a repeatable army barracks where economy would trump design. 1 Link to comment Share on other sites More sharing options...
dshall Posted March 21, 2020 Share Posted March 21, 2020 On 3/21/2020 at 4:20 PM, Gawdzira said: The only time I display graph lines is in layout files that I create to do sketching. I have one I made for an 11x17 sheet that I bring to sites when doing field measure and then one that I have for 8.5x11 sheets for notes when I need to sketch a quick detail and send out for an RFI...... Expand Yeah, so do I. 1 Link to comment Share on other sites More sharing options...
SNestor Posted March 21, 2020 Share Posted March 21, 2020 On 3/21/2020 at 12:47 PM, parkwest said: I wonder how much scrap lumber would be reduced if houses were designed on 2 foot snap intervals or even possibly 4 foot? Expand Lumber is about the least expensive item in a house...so, I don't concern myself with such things as building on a 24"/48" grid. However, building on 16" increments to accommodate lumber/plywood sizes just makes sense - to a certain degree...but, not at the expense of good design. Link to comment Share on other sites More sharing options...
robdyck Posted March 21, 2020 Author Share Posted March 21, 2020 I certainly understand that many users wouldn't want to see or use the grids and then choose to have them off. My comments were based on the many plans posted by inexperienced users who are leaving them on, but are not using them to their advantage. I think it's fair to say that if you're new to the program, anything that helps you make a wall 32'-0" in length as oppose to 31'-11 3/16" is a benefit and maybe should be used. Personally, I like having the visual reference of both grids to quickly identify something that may misaligned. I also like using it elevation view as a guide for quickly and accurately placing cad reference lines to help guide items like material regions, stepped foundations, wall area polylines, manually placed trims or decorative elements. Of course, the elevation view guides are very helpful....if you started your floorplan on the grid at 0&0 on the x and y axis. Maybe it's from having been a builder, but I like instinctively knowing where every item in the house is on the x,y,z coordinates. But I also draw and model a lot of things that Chief doesn't have library items for. Link to comment Share on other sites More sharing options...
robdyck Posted March 21, 2020 Author Share Posted March 21, 2020 On 3/21/2020 at 12:47 PM, parkwest said: I wonder how much scrap lumber would be reduced if houses were designed on 2 foot snap intervals or even possibly 4 foot? Expand Waste lumber is not dependent on the measurements of the building but rather on the skill of those doing the building. Believe it or not, I framed many 2000 to 4000 sq ft houses with only a single 6 yard dumpster of scrap. In large custom homes, there is a place to use almost every cutoff of either lumber or sheet goods. In simple tract homes, optimization of dimensions becomes more important. 1 Link to comment Share on other sites More sharing options...
robdyck Posted March 21, 2020 Author Share Posted March 21, 2020 You guys who all say you don't like the grid aren't new to the program...you've got a system that works and your comfortable using it, right? There's times when I don't want to see it either so I just hit the toggle button docked in my toolbar. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 22, 2020 Share Posted March 22, 2020 On 3/21/2020 at 7:13 PM, SNestor said: Lumber is about the least expensive item in a house...so, I don't concern myself with such things as building on a 24"/48" grid. However, building on 16" increments to accommodate lumber/plywood sizes just makes sense - to a certain degree...but, not at the expense of good design. Expand Not here, lumber is one of the most expensive in the home. Framing is also one of the most expensive things. Link to comment Share on other sites More sharing options...
parkwest Posted March 22, 2020 Share Posted March 22, 2020 According to the numbers I saw from NAHB, on average across the nation, framing is one of the highest single cost at around 18% of the total cost of building a new house. I always figured if I paid for the lumber, it should be going into the house, not the landfill. In the 90's I used a software specifically to optimize the use of framing materials... and I also found out which framers made me the most money... which was hard to quantify when building one of a kind custom homes... before I used that software. Link to comment Share on other sites More sharing options...
danielfoster Posted August 11, 2020 Share Posted August 11, 2020 Many of the greatest architects use or used grid lines. Frank Lloyd Wright always designed to a grid, very often 24" x 48". All of traditional Japanese house design is also done to a grid. It's a very useful tool. Link to comment Share on other sites More sharing options...
bluesparrowllc Posted August 12, 2020 Share Posted August 12, 2020 I use the grid...sometimes. I find it most useful when I'm looking at small increments but can't be bothered to take a dimension i.e. to see if how much room I have between a cabinet and window/door framing. It's just easier for me to zoom up and take a look. I also have a better sense of the space with the grid on when I am in the first stages of a plan. (I'm pretty visual and room dimensions don't really have any physical meaning for me.) Now that I've stopped moving walls, they are turned off. Link to comment Share on other sites More sharing options...
StephenGreene Posted September 27, 2020 Share Posted September 27, 2020 On 3/21/2020 at 9:05 PM, robdyck said: Waste lumber is not dependent on the measurements of the building but rather on the skill of those doing the building. Believe it or not, I framed many 2000 to 4000 sq ft houses with only a single 6 yard dumpster of scrap. In large custom homes, there is a place to use almost every cutoff of either lumber or sheet goods. In simple tract homes, optimization of dimensions becomes more important. Expand Same here. Me and my crew often would frame a house and the scraps would barely fill a couple of wheelbarrows, while the crew next door would have enough scrap to fill a roll-off dumpster. And I've seen drywall hangers and bricklayers that were just as bad (or good). 1 Link to comment Share on other sites More sharing options...
WendyFlow Posted November 23, 2020 Share Posted November 23, 2020 Thanks for the useful information. Didn't really know about such a useful thing. Now I think I still need to read some useful information about the settings Link to comment Share on other sites More sharing options...
