Time to Show YOUR GOODIES!
Adrean
  On 10/19/2015 at 11:37 AM, Dennis_Gavin said:
blue with gray reflections from the road
I'm with Dennis on this one.
"mattyt12" - where did you get those? 3D Warehouse? Would you mind sharing? I have an upscale mountain home in the works that those would look great in front of.
Thanks, Mike
Thanks, Mike
Not a problem, cant remember what model the bmw was, too long ago but the merc:
https://3dwarehouse.sketchup.com/model.html?id=uc0689cdb-11ee-4c6a-882d-e234b4d0a394
The calibz files and material settings are here though
https://www.dropbox.com/sh/6a7epsfqzprnw9d/AAA6be0l2oWSY_iju7gssT0Za?dl=0
Thanks, mattyt12. They look great. When I downloaded them some of the textures didn't make it. Both cars are white so I guess it was the exterior paint color. Also, on the BMW, the rear tag shows about 48" above the bumper; the texture for the tag didn't make it either. Not complaining - I appreciate the effort.
Thanks, Mike
Here is a hint. The exact same car with the colors of the sky and concrete reversed:
So what color is the car? That’s kind of hard to pin down. Let me try to explain how
I arrived at the result in the OP. I started out to see if I could get one of the vehicles
from the Library Browser to display more realistically in a ray trace. My idea was to
place the library symbol on a piece of generic road and see if I could get the road
stripes to reflect off of the rocker panels. To do this I obviously needed a more
reflective surface than the OOB default supplied by Chief. Chief classifies the Material
for the Body Color as a “General Material” and as such you can manipulate several
characteristics but not specifically reflectivity. This got me thinking about what type of
material would be more reflective and since I was working on a metal car with a shiny
paint job I brilliantly deduced that what I needed was a “shiny metal” material. Well
imagine my surprise when I opened the Material Class menu and, bingo, one of the
choices was “Shiny Metal”.  :)  It turns out that one of the characteristics you can
control with this class of material is “Reflection” although this can only be done in ray
trace views. There is a sliding bar where you can adjust the amount of reflection form
0% to 100% and there is a corresponding color swatch which varies from black to white.
Armed with this new material I set out to try a few test RT’s. Since I wanted a highly
reflective surface I set “Reflection” to 75% and ran a test run.
So here is the first answer to the question. The car I had displayed in the “Perspective
Full Overview” camera view I was using for the ray trace was bright red but it turned out
that didn’t matter. As the ray trace came into view I was puzzled but pleasantly surprised
that the car looked really shiny but it was not red but rather had the blue and gray tones
from the surrounding background and sky. Thinking I must have somehow altered the
color I went back and opened the material for the car body but it was still bright red. I did
a second ray trace and got the same results I had with the first one. Since it was obvious
that something was overriding the car’s material color I tried clicking on the color swatch
beside the Reflection slider and it opened the Color Selector dbx from whence I was able
to change the car’s color.
Anyhow, this is what I’ve learned. If you don’t supply a color and use the default black to
white values on the Reflection slider you essentially get a clear reflective surface not unlike
a chrome surface or a mirror as Jonathan predicted. Everything above the equator bulge
of the car reflects the values of the sky and everything below the equator bulge reflect the
ground colors. If you supply your own color you will then get a reflective colored surface.
So what color is the car? It’s red, but it isn’t. It’s no color or any color. It’s basically like a
chameleon; it takes on the color of its surroundings. Hope this isn't TMI.
Top row: How cars display in Standard View
Middle row: How cars display using default "Shiny Metal" color settings in ray trace
Bottom row: How cars display adding color to "Shiny Metal" settings in ray trace
  • 3 weeks later...
Here are a few elevations I've done over the past couple of months. I haven't posted on here lately because I honestly forgot this thread existed. There is a group on Facebook some of the users share their renderings on. Here is the linkhttps://www.facebook.com/groups/UsersofChiefArchitect/ Check it out! There are quite a few users who have joined.
  • 3 weeks later...
Rich,
It's no more than you would get off of a lower sloped roof.  The speed is faster at the eave line (ground level) so gutters are not effective.  But if you had a roof on a 2 story building without gutters, you would get the same effect - it's just the law of gravity.
On this Thanksgiving, I'm thankful for Scott Harris' Kiosk video in the SSA video library that instructed me on properly modeling a multi-tiered roof.  Attached is a ten-plane pentagonal "onion" roof.  And folks wonder about the value of SSA.
jon
  On 11/25/2015 at 12:50 PM, Dennis_Gavin said:
NIce work Jintu and Joe.
Joe - one bad for me is the TWO fires in the fire place.......
What, don't you think 2 fires is better than 1? ;)
Unfortunately that fireplace is a Chief supplied symbol.  I'll need to do a little fancy footwork to fix that.
  On 11/28/2015 at 1:11 AM, Joe_Carrick said:
No, it's one of my Spiral Stair Symbols.  It's made up of components that I have.  Let me know if you need a custom Spiral Stair.  I'll quote you a price.
Thanks Joe, I've been able to use CA stairs so far. Mine have all been outdoor or patio stair so metal has been fine.
If interior it should be a fancy stair.
jon
You too had been hijacked.
