Tristan89
Help - Is Intel HD Graphics 620 enough for X9?
I am looking at purchasing a new laptop with the specifications as attached/below, is this enough to run X9?
Microprocessor
Intel Core i7-7500U (2.7 GHz, up to 3.5 GHz with Intel Turbo Boost Technology, 4 MB cache, 2 cores)
Memory
Standard  16 GB DDR4-2133 SDRAM (2 x 8 GB)
Graphics
Storage
1 TB 5400 rpm SATA
https://www.pbtech.co.nz/product/NBKHNB15133I/HP-Remanufacture-Envy-15-as133cl-Entertainment-Not
Why don't you call tech support and ask them, as I have never had any intel video card. I like NVidia.
That I7-7500U/HD 620 combo is getting old, and it doesn't have any dedicated memory or solid state cache, though the Envy does have plenty of main RAM for it to scavenge. Chief would run, but if you do a lot of work in 3D views I would expect the performance to be below average. It's also got a slow HDD. I'd spend my $1400 on a gaming laptop with dedicated memory and an SDD, or at least a 7200RPM HDD - there are plenty of open box and refurbished machines available from NewEgg, Tiger, Amazon, etc. If you're an HP fan, you can buy a new gaming Omen laptop (from HP) with an I7-7700HQ with 6MB cache, nVidia 1050Ti with 4GB GDDR5, 16GB DDR4, and a 1TB 7200 HDD with a 512GB PCIe SDD - altogether a much better option for $1460, brand new.
I doubt that it is
always get a dedicated video card to run Chief
preferably Nvidia
with a dedicated video card you can also upgrade in the future if needed ( usually)
get at least 8 GB ram on video card - preferably 16 GB or more
Lew
Lew, What are you running for video card (s) ???
Lew
He's looking at a laptop - much more difficult to swap or upgrade GPUs. Any laptop with a 16GB GPU is going to be more than twice the OP's presumed budget.
http://www.dell.com/learn/us/en/19/help-me-choose/hmc-video-card-inspiron-lt
I believe if the video card is independent it is swapable
I have a 2008 laptop with an Nvidia card with 512 MB
I don't do much in the way of rendering or rays
my partner did those
this was my laptop for doing client presentations with a 17" screen
Lew
For most laptops the discrete graphics is built into the motherboard, it is not a swappable card like a desktop. With a laptop you should buy it already configured to your needs, very few laptops are designed to be easily upgradable if upgradable at all.
Fair number of gaming laptops with 900 series had desktop GPU and even some of the mobile ones are upgrade-able , mine is BUT they are not upgradeable to the newer Pascal chips so no point.
Far more laptops with Pascal GPUs are up-gradeable- no telling it the next generation will be compatible though.
Graham:
it is possible to upgrade a laptop's video card
it was probably easier a decade ago when they were bigger and heavier
but it is still possible
Those links indicate that most laptops are not designed to provide upgradable GPUs after purchase. Yes there may be some methods to do it but not likely worth it and certainly not for the average user.
There are no GPUs currently on the market running 16GB VRAM, "8GB - 16GB RAM" would be referring to system memory.  At this time the NVidia GeForce 10-series is the top of the line card, for laptops specifically its the GTX 1080, running 8GB GDDR5.  For desktops it is the GTX 1080 Ti running a (rather unusual) 11GB GDDR5X.
Regarding upgrading the GPU of your laptop: while there are a few very specific models of high-end gaming laptop where this is a possibility, for the most part the GPU is absolutely NOT an upgradable component for most laptops, and you would not expect such a thing from a laptop running an integrated Intel chipset.  If you are shopping specifically for a laptop that has this capability, please do your research and set your expectations accordingly, otherwise it is best to operate under the assumption that, as a Laptop, the only upgradable components will be Memory and Storage, period.
To directly answer Tristan89's initial question though, we support Intel chipsets Generation 4 and later; the Intel 620 is a 7th generation chipset and should be fine.  Please see https://www.chiefarchitect.com/support/article/KB-03076/using-chief-architect-with-intel-integrated-graphics-controllers.html for specific information regarding running Chief Architect.
Taylor B.
Chief Architect Technical Support
Taylor B.
Yep, but if budget isn't a problem you can get a rig with dual 1080's and SLI:
...just sayin'
I'd add that I think upgradeable GPU is just a sales buzzword. While mine is, that had nothing to do with my purchase. Since Pascal chips hit many more laptops  (gaming) tout upgradable. Thing is will the next generation socket match, will the MOBO be compatible.  Or the generation after that.? Even though we now see many more with desktop GPUs they still plug into the MOBO not a slot.
I guess I'm remembering days long ago when laptops have full-size slots for video cards
and could be swapped out
my current laptop was purchased in 2008
assuming the video card can't be upgraded
it is important to focus on getting the best one you can afford
same with screen size and resolution
spend $$ on items that can't be upgraded later
Lew
11 hours ago, taylorb said:
Thank you Taylor for setting us all straight, but since we are on the subject there is a Titan Xp model by NVidia that is 12 GB GDDRX5 and not that I am recommending it because my 1070 seems to be more than adequate but if you have $2400.00 you can order a limit of two of these: https://www.nvidia.com/en-us/geforce/products/10series/titan-xp/
...just sayin'
Man, that thing must weigh close to 20 pounds! Might, over time, require shoulder surgery!
    27478
    Oilersfan20
    Oilersfan20
