ACADuser Posted June 24, 2015 Share Posted June 24, 2015 OK I have a 3 story condo, units A & B I have created a schedule for door & another for windows on "Floor one plan" for each unit as the units are in separate Plan files & one Layout file. GC wants all items to have separate numbers, so I did that. CA has a way of not numbering as I want numbered! I want the table sorted by floor first of all. So I activate the table & drag items around to group them by floor. I think this is the only way we can change the numbers or position in the table, right? Then I see the block wall 1st floor doors have wood headers in the list so I open the dbx for those & eliminate the header. Well kiss my grits, CA must think I don't know what I want as it rearranged the table for me. Again I drag items around to sort buy floors. Now I want front door as #1 and then all exterior doors. Then inside the front door I work my way through the unit arranging numbers as I like. OK now I want to doe floor 2 & then 3. But switching to floor 2 i can not longer get to the table as it is back on floor one. What would be workable is to have a split screen with the table in one window & the 2nd floor in the other. Is there a way to do that? Please tell me there is. In my opinion you should be able to renumber by dragging one label to another & they would swap numbers. This would make things a lot faster for me that is. This CA method is very clumsy IMO. Link to comment Share on other sites More sharing options...
dshall Posted June 24, 2015 Share Posted June 24, 2015 Number the doors and windows individually via the labels. Put the door and window schedule in a cad detail and put it where ever you want it... IOW , do not put schedule in plan but put it in a cad detail. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 24, 2015 Share Posted June 24, 2015 Alan, Use a separate Schedule for each floor (put in a CAD Detail Window as Scott suggested) Now you just need to rearrange the rows in each Schedule. Link to comment Share on other sites More sharing options...
ACADuser Posted June 24, 2015 Author Share Posted June 24, 2015 The GC does not want two D01 or W01 in the plan So one schedule is needed correct? So you create the schedule in floor one & then make it a block? Not sure I am getting this. The CAD detail is unfamiliar territory for me at this time. Still lot's to learn. Link to comment Share on other sites More sharing options...
johnny Posted June 24, 2015 Share Posted June 24, 2015 The GC does not want two D01 or W01 in the plan So one schedule is needed correct? So you create the schedule in floor one & then make it a block? Not sure I am getting this. The CAD detail is unfamiliar territory for me at this time. Still lot's to learn. I think the reason they are suggesting this is so the schedule doesn't update automatically (breaking the link). Also, I think they are saying you need to hand input this data...there isn't an automatic feature in getting this done. Im curious why the GC wants it like this.... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 24, 2015 Share Posted June 24, 2015 The GC does not want two D01 or W01 in the plan So one schedule is needed correct? The 1st Floor Schedule would be D1 resulting in numbers D101, D102, D103, etc The 2nd Floor Schedule would be D2 resulting in numbers D201, D202, D203, etc So you create the schedule in floor one & then make it a block? Not sure I am getting this. The CAD detail is unfamiliar territory for me at this time. Still lot's to learn. No, just create an empty CAD Detail Window and create the Schedules there instead of in the Floor Plan Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 24, 2015 Share Posted June 24, 2015 I think the reason they are suggesting this is so the schedule doesn't update automatically. Also, I think they are saying you need to hand input this data...there isn't an automatic feature in getting this done. Wrong, the Schedules will still update automatically. It just make is easier to arrange and send to Layout. This makes it possible to send the Schedules (or anything else) to Layout separately from the Floor Plan. CAD Detail Windows are just like Elevations, Sections, etc in that respect. It also makes it easier to organize the data in the Plan File by names which appear in the Project Browser. Link to comment Share on other sites More sharing options...
HumbleChief Posted June 24, 2015 Share Posted June 24, 2015 The window schedule also has the ability to create a separate schedule for each floor. Link to comment Share on other sites More sharing options...
HumbleChief Posted June 24, 2015 Share Posted June 24, 2015 Here's a brief video that may or may not help and as always it's best to pay attention to those would know more about such things. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 24, 2015 Share Posted June 24, 2015 You can copy and paste schedules into the CAD Detail window too , and at least for me the Number system in the CAD Detail seems to work better/display better but I am not sure what the difference is with numbering in CAD vs Plan , though in the one I did this morning the Plant schedule totally rearranged itself on copy and pasting ,and the Plan view renumbered itself to match. M. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 24, 2015 Share Posted June 24, 2015 It is not a good idea to Copy/Paste Schedules - unless you delete the original. Otherwise you can get double labels in the Plan. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 24, 2015 Share Posted June 24, 2015 It is not a good idea to Copy/Paste Schedules - unless you delete the original. Otherwise you can get double labels in the Plan. Yep , that's exactly what I did Joe , went back to plan view and deleted the Schedule there so I didn't get the double numbering issue which I was aware of from other posts. I should of noted that above.... M. Link to comment Share on other sites More sharing options...
ACADuser Posted June 24, 2015 Author Share Posted June 24, 2015 Larry, Good video, thanks That helps clear up the CAD window aspect. So to move the door number in the table you thump that Icon 10 or 15 times as needed. Link to comment Share on other sites More sharing options...
CharlesVolz Posted October 30, 2015 Share Posted October 30, 2015 Also, to help the estimator get a rough estimate for some plumbing and electrical fixtures (which I don't label on the plans), I create a shorter consolidated schedule showing fewer line items by not showing their locations (floor and room). I do this by copy/paste the schedule, add "TOTALS" to schedule name, change the label to "(original)T-1(generated #)" by adding "T-1" after the existing label, and not showing the floor and room. This generates an item number that shows it is a total "T" and starts the numbering at "100" to separate these grouped items from the items on the full schedule showing the items' location. On a large multi-floor home this may be appreciated by the estimator. Link to comment Share on other sites More sharing options...
COLONIAL-CHIEF Posted October 30, 2015 Share Posted October 30, 2015 Create your schedule for ea. floor in CA export to Cad rearrange and number as you wish. Export back to CA as a cad detail. Link to comment Share on other sites More sharing options...
ACADuser Posted October 30, 2015 Author Share Posted October 30, 2015 Well, the point of having "Automatic Tables" is that they update when the plan changes. It is way too hard to make this work. (My 2 Cents) Link to comment Share on other sites More sharing options...
dshall Posted October 30, 2015 Share Posted October 30, 2015 It is not a good idea to Copy/Paste Schedules - unless you delete the original. Otherwise you can get double labels in the Plan. A reason for putting the schedules in a CAD detail. You can copy and post the cad detail/schedule on every sheet of the plans with no problems. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 30, 2015 Share Posted October 30, 2015 A reason for putting the schedules in a CAD detail. You can copy and post the cad detail/schedule on every sheet of the plans with no problems. Yep, send the CAD Detail Schedule to Layout and then copy it to any Layout Page you want. All Live Schedules - change the Plan and the Schedule is updated. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 30, 2015 Share Posted October 30, 2015 Question for Alan the OP: How automatic do you want this to be? Be real specific here. You have already seen how Chief will table the openings by floor. Link to comment Share on other sites More sharing options...
ACADuser Posted November 13, 2015 Author Share Posted November 13, 2015 Sorry for the late reply, I was off sleighing dragons.Well, maybe just putting out fires.I have another job that need room numbering as well as doors & windows.That is what brought me back to this thread.As for Chief desires, how about:Manual and automatic renumbering with these options / check boxesHorizontal - "Left to Right" or "Right to Left"Vertical - "Top to Bottom" or "Bottom to Top"Use Letters or NumbersSkip I an O option if letters.Add Prefix and Suffix fieldsStart number or Letter fieldEdit the number directly in the table, this will auto resort the table & renumber accordinglySame with Tags, this will auto resort the table & renumber accordinglyEdit any field directly from the tableSelect an item in the tab;e & option to Zoom to it in the Drawing. That's all i can think of off the top of my head. Link to comment Share on other sites More sharing options...
ACADuser Posted November 13, 2015 Author Share Posted November 13, 2015 OK here is the deal, i need a Room Name and a Room Number. These should be separate fields so I can change the room number but leave the room name as is. I know Joe has some wiz-bang Ruby scripts to do this but I don't have time to learn Ruby today. This would even be handy in a very large home. You may have more than one Hall Bath. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 13, 2015 Share Posted November 13, 2015 Alan, There is no magic way to Number Rooms. Even with my knowledge of Ruby I can't do it.I have asked (repeatedly) that Chief add Room Numbers.Here's the workaround for now: In the Room Name Field add the Number in Front such as:101 - Entry102 - Living Room103 - Dining Room etc.The above would all be on the first floor. For the second floor I use 201, 201,203, etc.If Chief had the following fields:floor_number room_number schedule_number then I could create a simple macro to Label the Rooms which could be placed in the Default Label. Link to comment Share on other sites More sharing options...
ACADuser Posted November 13, 2015 Author Share Posted November 13, 2015 Thanks Joe. In ACAD you can add xData to an object, layer,etc. Then with MACRO (Lisp) you can retrieve the xData & use in your own label etc. Too bad CA will not open the database to users. Link to comment Share on other sites More sharing options...
