BeeoHat Posted March 8, 2014 Share Posted March 8, 2014 The floor of the attached garage on my house slopes slightly away toward the driveway (roughly, 10 inches over 20 feet). I've been unable to find any tool/adjustment that allows me to accomplish this. I know that the terrain tools allow for sloping on the surrounding terrain, but not the inside of the house/garage. Is there any way I can model this sloped garage floor in my plan? Link to comment Share on other sites More sharing options...
Solution Gawdzira Posted March 8, 2014 Solution Share Posted March 8, 2014 Make it a ramp. It is a ramp at nearly 1:12. 1 Link to comment Share on other sites More sharing options...
VinnieVicon Posted March 8, 2014 Share Posted March 8, 2014 Make a ramp the change the materials to concrete Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 8, 2014 Share Posted March 8, 2014 On 3/8/2014 at 8:48 PM, BeeoHat said: The floor of the attached garage on my house slopes slightly away toward the driveway (roughly, 10 inches over 20 feet)... That does not sound like it would qualify as "slopes slightly" to me. That would be the single most extreme garage slab slope I have ever seen. Did you perhaps type those number incorrectly?? Link to comment Share on other sites More sharing options...
joey_martin Posted March 8, 2014 Share Posted March 8, 2014 Either use the ramp as others have already stated, or you will have to manually create the slab and pull the slope as needed. Link to comment Share on other sites More sharing options...
BeeoHat Posted March 9, 2014 Author Share Posted March 9, 2014 Thanks for all the prompt responses. The ramp worked perfectly!! 1 Link to comment Share on other sites More sharing options...
Nicinus Posted November 17, 2014 Share Posted November 17, 2014 I'm doing a patio of about 50'x60' and my planned slope of about 3/8" per foot needs to be shown in elevation. Would a ramp be suitable in this case as well? I can't seem to figure out how to make a slope on a slab? Link to comment Share on other sites More sharing options...
Chief16Designer Posted November 17, 2014 Share Posted November 17, 2014 I would use a polyline solid ,but instead of drawing the polyline solid in plan view I would draw it in an elevation view spanning the distance , when you draw a polyline solid in an elevation view you can shape it in the elevation and then you can set the thickness , check knowledge base polyline being drawn in an elevation 1 Link to comment Share on other sites More sharing options...
dshall Posted November 17, 2014 Share Posted November 17, 2014 On 11/17/2014 at 7:05 AM, peteandra said: I would use a polyline solid ,but instead of drawing the polyline solid in plan view I would draw it in an elevation view spanning the distance , when you draw a polyline solid in an elevation view you can shape it in the elevation and then you can set the thickness , check knowledge base polyline being drawn in an elevation Suppose the garage is "L" shaped? Link to comment Share on other sites More sharing options...
tommy1 Posted November 17, 2014 Share Posted November 17, 2014 On 11/17/2014 at 7:56 AM, dshall said: Suppose the garage is "L" shaped? If the area is "L" shaped, I would definitely use a solid from an elevation. Slope it in the elevation, shape it in plan view. 1 1 Link to comment Share on other sites More sharing options...
ebdesign Posted November 17, 2014 Share Posted November 17, 2014 I use the terrain tool & elevation data in a separate plan. Multi-shaped garages, different slopes, floor drains in the middle of the garage......no problem. 1 Link to comment Share on other sites More sharing options...
dshall Posted November 17, 2014 Share Posted November 17, 2014 On 11/17/2014 at 12:40 PM, tommy1 said: If the area is "L" shaped, I would definitely use a solid from an elevation. Slope it in the elevation, shape it in plan view. I do not think this is possible. Link to comment Share on other sites More sharing options...
tommy1 Posted November 17, 2014 Share Posted November 17, 2014 On 11/17/2014 at 1:43 PM, dshall said: I do not think this is possible. Sure it is. I've done it before when I absolutely had to show a slope. Link to comment Share on other sites More sharing options...
tommy1 Posted November 17, 2014 Share Posted November 17, 2014 You could use a terrain tool as Jim suggests. Same idea, different approach. Link to comment Share on other sites More sharing options...
MickeyToo Posted November 17, 2014 Share Posted November 17, 2014 So if Chief can slope a ramp and a polyline solid, why not a slab? It would certainly be more intuitive. 1 Link to comment Share on other sites More sharing options...
rlackore Posted November 17, 2014 Share Posted November 17, 2014 Decks should be slope-able. Slabs also. Even odd shapes should be slope-able. If CA can figure out roof intersections at an angle, it can figure out sloped decks and slabs that intersect at an angle. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 17, 2014 Share Posted November 17, 2014 Can't you have no floor in the garage, and just put a ramp in there. Link to comment Share on other sites More sharing options...
Nicinus Posted November 17, 2014 Share Posted November 17, 2014 On 11/17/2014 at 1:53 PM, tommy1 said: Sure it is. I've done it before when I absolutely had to show a slope. I can't get this to work. I can create the shape and control the extrude, but not the shape in plan view. Did you use boolean operations? Link to comment Share on other sites More sharing options...
Nicinus Posted November 17, 2014 Share Posted November 17, 2014 On 11/17/2014 at 1:31 PM, ebdesign said: I use the terrain tool & elevation data in a separate plan. Multi-shaped garages, different slopes, floor drains in the middle of the garage......no problem. My original patio was created as a terrain feature. I don't understand what you mean here, how would I do it in a separate plan? 1 Link to comment Share on other sites More sharing options...
ebdesign Posted November 17, 2014 Share Posted November 17, 2014 Draw/build what you need in a separate plan w/ the terrain tools, & then make it a symbol & bring it into the real plan. The minor drawback w/ the ramp is that it has a flat bottom. Is there a way to have the ramp bottom follow the slope of the top? 1 Link to comment Share on other sites More sharing options...
ebdesign Posted November 17, 2014 Share Posted November 17, 2014 I didn't believe you Tommy but decided to try it anyway. Sure enough, if I draw a SOLID in plan, tilt it in an elevation & then come back to plan, I can edit the 2D shape to pretty much anything. I get a pretty squirrelly selection box in plan, but......... Good one! Link to comment Share on other sites More sharing options...
dshall Posted November 17, 2014 Share Posted November 17, 2014 On 11/17/2014 at 7:36 PM, ebdesign said: I didn't believe you Tommy but decided to try it anyway. Sure enough, if I draw a SOLID in plan, tilt it in an elevation & then come back to plan, I can edit the 2D shape to pretty much anything. I get a pretty squirrelly selection box in plan, but......... Good one! I am so confused with this. Is this a solid or a PSOLID? Link to comment Share on other sites More sharing options...
ebdesign Posted November 17, 2014 Share Posted November 17, 2014 Scott, The full name of what I used is the "Polyline Solid". I don't know any other kind of ".solid"- other than the other geometric shapes in the drop-down. I usually draw slabs in plan, polyline solids in elevation. I'm probably confused. It is Monday, after all. Link to comment Share on other sites More sharing options...
dshall Posted November 17, 2014 Share Posted November 17, 2014 On 11/17/2014 at 8:28 PM, ebdesign said: Scott, The full name of what I used is the "Polyline Solid". I don't know any other kind of ".solid"- other than the other geometric shapes in the drop-down. I usually draw slabs in plan, polyline solids in elevation. I'm probably confused. It is Monday, after all. That is what I thought. When I first read TB's response, I did not think it was possible. So I went in office, drew a profile in elevation, gave it a 48" depth, went to plan and tried to break an edge to reconfigure for an "L" shaped garage plan, and I could not break an edge in PLAN. Would you mind posting a small plan of this working? For some reason, I cannot break the edge of a PSOLID in plan view, created/ drawn in elevation. Link to comment Share on other sites More sharing options...
dshall Posted November 17, 2014 Share Posted November 17, 2014 And to confirm, I right click on an edge in plan view, the contextual menu shows up, and the break tool IS NOT AVAILABLE. So I don't think it is possible to break the edge of a PSOLID drawn in elevation. But you guys say it is possible..... another example of my "P" size brain (no reference to the Real P. Man) not working. Link to comment Share on other sites More sharing options...
