tjsage1 Posted November 25, 2020 Share Posted November 25, 2020 In designing a new home with a daylight basement, what would the floor levels be? Would the daylight basement be first floor and the next level be the second? I'm confused and need some help, videos or instructions. Link to comment Share on other sites More sharing options...
rgardner Posted November 25, 2020 Share Posted November 25, 2020 This has been discussed frequently and in quite depth in the forum. I would recommend doing a search for the positives and negatives of the two methods. Method 1: Daylight basement goes on floor 0 (footings and short stem walls on same level) Method 2: Daylight basement goes on floor 1 (footings and short stem walls on 0) Link to comment Share on other sites More sharing options...
GeneDavis Posted November 25, 2020 Share Posted November 25, 2020 Main floor is 1, walkout is 0. Floor 0 walls will be pony walls framed wall up, foundation wall down. The frostwalls and foundation stepdowns will be edited manually by you. There are Chief training videos that give you the how-to. Link to comment Share on other sites More sharing options...
Dermot Posted November 25, 2020 Share Posted November 25, 2020 See if this helps: https://www.chiefarchitect.com/support/article/KB-00376/creating-a-walk-out-basement.html Link to comment Share on other sites More sharing options...
joey_martin Posted November 25, 2020 Share Posted November 25, 2020 Pictures...thousand words..... Link to comment Share on other sites More sharing options...
ShaneK Posted November 25, 2020 Share Posted November 25, 2020 Foundation & daylight wall = 0 Link to comment Share on other sites More sharing options...
Chrisb222 Posted November 25, 2020 Share Posted November 25, 2020 3 hours ago, GeneDavis said: Main floor is 1, walkout is 0. Floor 0 walls will be pony walls framed wall up, foundation wall down. The frostwalls and foundation stepdowns will be edited manually by you. This is exactly how I do it. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 25, 2020 Share Posted November 25, 2020 I like walkouts on level 1 b/c I like the foundation on its own level. Link to comment Share on other sites More sharing options...
