joey_martin 385 Posted December 31, 2016 Has anyone gone through the process yet of downloading one of these and placing it in Chief. I don't have SketchUp on the machine I am at right now, but need one of these. http://www.viega.us/4741.html Share this post Link to post Share on other sites
jcaffee 109 Posted December 31, 2016 Closest from 3D Warehouse... Mechanical_Simplified-Valves_9-Valve-Manifold-1in.skp Share this post Link to post Share on other sites
joey_martin 385 Posted January 1, 2017 I ended up finding one. I'll share it when I get back to the office. Share this post Link to post Share on other sites
joey_martin 385 Posted January 1, 2017 Here it is. Manabloc.calibz Share this post Link to post Share on other sites
facer_03 33 Posted January 2, 2017 Thank you, joey_martin. WEB search for Manabloc http://www.viega.us/4741.html picture of Manabloc.calibz Share this post Link to post Share on other sites
GeneDavis 141 Posted January 2, 2017 Out of curiosity, why the need for such 3D realism? If done in a gyprock-finished mechanical room, it's often hidden behind an access panel. And if not flush-built, the PEX lines are all going to be visible. If so, will they need to be 3D modeled, also? Share this post Link to post Share on other sites
joey_martin 385 Posted January 2, 2017 I don't show all the PEX, just want the Manabloc to show in the Materials List and on the Fixture Schedule. Share this post Link to post Share on other sites
DRAWZILLA 784 Posted January 2, 2017 Mine is in the attic area. Share this post Link to post Share on other sites
Francois 11 Posted January 2, 2017 Joey, i do not want to hijack your thread but I have run in the case of when I offer PEX on my jobs I hit a roadblock as the owners want copper by fear of leaks from this material. My question is: how confident are you in using this product? Share this post Link to post Share on other sites
SNestor 496 Posted January 3, 2017 I have managed the construction of thousands of apartments with PEX. It's a fabulous product. You should not fear using it. To me it is superior to copper. Share this post Link to post Share on other sites
joey_martin 385 Posted January 3, 2017 110% confident. No one in my area uses copper any longer. And copper leaks too if not installed properly. 1 Share this post Link to post Share on other sites
Alaskan_Son 2519 Posted January 3, 2017 In general, we haven't used copper in probably 20 years with the exception of exposed pipes. We do a lot of remodel work and I don't recall ever seeing a pex leak. We find copper failures all the time though (electrolysis, hydrolysis, etc) Having said that, the 2 things that ARE worth considering... 1. Some people fear chemicals leaking from the plastic over time. The same can be said for copper too though to a certain extent. 2. You can put power to a copper line to melt it it ever freezes. The same cannot be done with Pex. Share this post Link to post Share on other sites
chief58 66 Posted January 3, 2017 I used copper when I built my house and wish I used pex know, I am old school, wish someone slapped me across my head, use pex I would if I had to do it over again, Share this post Link to post Share on other sites
Francois 11 Posted January 3, 2017 That's reassuringnow. What about crimping system vs Sharkbite"? I know the later one is expensive. Share this post Link to post Share on other sites
Rich_Winsor 199 Posted January 3, 2017 Another advantage of PEX is that it has no resale value. You don't have to worry about vandals ripping out your water lines to sell for scrap metal. With Copper selling for about $2.50 a pound these days you don't want it laying around the construction site. Share this post Link to post Share on other sites
dssharp 15 Posted January 5, 2017 I'm finding customers don't want pex because of the particulates per million of plastic ingested. interesting enough its the same as water bottles which were deemed healthy. The long-term effects are not known at this time as far as I know of. Also, plumbers talk of critters eating holes through the stuff. Share this post Link to post Share on other sites
ACADuser 149 Posted April 9, 2017 I put CPVC under slab in my own story home in 2000. If piping is in that attic here in Tampa Florida the cold water is hot during the day with 140 deg attic temps. One problem with CPVC, it gets brittle over time. Friend of mine broke a pipe fitting while walking in the attic. Personally I have had two fitting leaks on the hot water circulation system. Yes two elbows cracked in the throat of the fitting. Had to jack hammer the floor to get at them. My theory is that there was a bow in the piping when the back fill took place. Other than that I like it. Share this post Link to post Share on other sites
Rosco2017 48 Posted April 10, 2017 On 1/2/2017 at 10:48 PM, joey_martin said: 110% confident. No one in my area uses copper any longer. And copper leaks too if not installed properly. I'm only a few hours away from Joey. No one here uses copper either. It's all pex. Share this post Link to post Share on other sites
CJSpud 87 Posted April 13, 2017 Uponor's proprietory PEX tubing has a unique fastening system (PEX ring with memory) that is reportedly stronger than the tubing itself ... which is pretty darn strong in its own right. Years ago I became a certified installer of their tubing but haven't done much of that anymore, other than for myself on occasion. With Uponor's fittings you do have to be careful not to nick the ribs (nurls) that the tubing clamps on, otherwise you could have a leak. You can actually spin their fittings (if you have room to turn them) after they've been connected to the tubing without any risk of leaking. Their life cycle tests say that the tubing and connections will last a long long time. The tubing should not be left exposed to the sunlight. My well pump column is 1" PEX tubing (about 250' in the hole) and another 150' ± from the well uphill to my house. Share this post Link to post Share on other sites
