davidinvest Posted February 7, 2016 Share Posted February 7, 2016 Title Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 7, 2016 Share Posted February 7, 2016 If you're asking why there isn't any T1-11 in the library, there is, it's just called something else. Materials>Siding and Paneling>Vertical Paneling. I remember having a hard time finding it when I first started using Chief too. 1 Link to comment Share on other sites More sharing options...
davidinvest Posted February 7, 2016 Author Share Posted February 7, 2016 Yeah I used that but the elevation wont show the vertical lines though Link to comment Share on other sites More sharing options...
davidinvest Posted February 7, 2016 Author Share Posted February 7, 2016 Link to comment Share on other sites More sharing options...
davidinvest Posted February 7, 2016 Author Share Posted February 7, 2016 The beige wall is the vertical paneling . Link to comment Share on other sites More sharing options...
glennw Posted February 7, 2016 Share Posted February 7, 2016 Time to get the manual out and do a bit of study. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted February 7, 2016 Share Posted February 7, 2016 What Glen is saying look at the pattern for the material and adjust accordingly. Not sure if there is one that matches exactly but you can check that out when you are looking..... Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 7, 2016 Share Posted February 7, 2016 Some siding materials don't come with patterns but you can always add patterns using the edit material button. You can also use a different material that has the pattern included. Link to comment Share on other sites More sharing options...
lbuttery Posted February 7, 2016 Share Posted February 7, 2016 still begs the question why no T-111 ready to use OOB when it is so popular Lew Link to comment Share on other sites More sharing options...
HumbleChief Posted February 7, 2016 Share Posted February 7, 2016 still begs the question why no T-111 ready to use OOB when it is so popular Lew I think it begs the question too Lew. Always wondered that myself, but I guess it really isn't so popular anymore? Link to comment Share on other sites More sharing options...
Solution dshall Posted February 7, 2016 Solution Share Posted February 7, 2016 Isn't this the T-111? I know, no 3D, but that is solved with using bump maps I believe....... I think it is difficult to have a material get the 3d look. 1 Link to comment Share on other sites More sharing options...
javatom Posted February 7, 2016 Share Posted February 7, 2016 T1-11 has too many issues with achieving brace wall shear panels. It has become associated with low end builders. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 7, 2016 Share Posted February 7, 2016 Depending on the type of t-111 you will have 2 lines or 1, but they are in the lib. You can also change the pattern line color to black to show them better in standard view. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 7, 2016 Share Posted February 7, 2016 T1-11 has too many issues with achieving brace wall shear panels. It has become associated with low end builders. I don't have any problems using t-111 over shear walls, you will of course need to shear the whole wall or furr it out to match. Not low end around here. Link to comment Share on other sites More sharing options...
RodCole Posted February 7, 2016 Share Posted February 7, 2016 I agree that this should be much easier to accomplish than it is now. It can be done using the methods stated above, but there really should be something a bit easier to work with. I had a project a few months ago that was an addition on to a house that has T-1-11 siding. I thought the same as others that with only 5/16" of remaining panel that it would not have enough shear rating to work. I was surprised to find that the actual thickness of the remaining panel was not the issue. The issue is the rating stamped on the back of the panel by the manufacturer. It turned out in my case that the siding's shear rating was fine. There is another issue with using a product that is both the sheathing and the finish siding and that is the application of the rain guard type of barrier or the lathing. Nothing so far seems to make a whole lot of sense to me about how to go about this type of situation. So, if it is not so much the shear issue that has many builders using far less T-1-11 today than they used to, then I would think that it would probably have more to do with market preferences and the association with low cost housing that is being avoided. Two cents. Link to comment Share on other sites More sharing options...
javatom Posted February 7, 2016 Share Posted February 7, 2016 Using it over shear walls is fine. A lot of builder want to use it as both the sheathing and siding. The grooves make it too thin to qualify for prescriptive panels. You can get thicker t1-11 but it may be cheaper to use sheathing and real siding. Link to comment Share on other sites More sharing options...
RodCole Posted February 7, 2016 Share Posted February 7, 2016 What I found is that in order to qualify for use in the prescriptive method it is the manufactures thickness rating, not the actual thickness of the panel that counts. I agree that it does not make a lot of sense, but that is how I understand it to be viewed by building officials. Kind of goes against everything I was taught in engineering classes, but it appears they are leaving it up to the thickness rating stamped on the back of the sheet by the manufacturer. BTW, I was using the continuously sheathed prescriptive method and it passed just fine. Another thing that I found to be a bit irritating is that it is very difficult to find the thickness rating unless you actually look at the back of the sheet. That information has to be available somewhere, but trying to determine who the manufacturer is and then find their rating is a royal pain. There probably is some consistency between manufacturers, but I did not get much help with that from any of the suppliers. Link to comment Share on other sites More sharing options...
davidinvest Posted February 7, 2016 Author Share Posted February 7, 2016 Thanks guys I found what I needed. Link to comment Share on other sites More sharing options...
Paramount Posted February 8, 2016 Share Posted February 8, 2016 IRC calls for 3/8 continuous. Rod is right the mfg rates the panel in their data sheets for shear and buckling is what some have if the stud span gets too far. I think some just want to sell more wood so say 3/8 fails which I doubt. I've seen ICC letters of approval at 3/8 but some like LP contradict it by selling 5/8 structural rate @ 16/24 told me they have bucking issues at 3/8. LP and most Engineered is glue laminated fiber junk, I'll take T1-11 with a ventilation gap behind it any day of the week. Roy O Martin one direct makes a good product I use 5/8 way cheaper than engred, no osb sheathed, or barriers. The reason why most siding fails early is due to a lack of understanding of vapor transports and hygothermal mass they don't teach in engr school. The whole vapor barrier and retarder, house wraps, smart or dumb wraps, is a mess I don't follow any of. Link to comment Share on other sites More sharing options...
