JBHammer Posted March 16, 2014 Share Posted March 16, 2014 Is there a macro which can be displayed on each floor plan title, that will give total living area of all floors??? Link to comment Share on other sites More sharing options...
JBHammer Posted March 16, 2014 Author Share Posted March 16, 2014 That one give the square footage for the floor your on only. I'm looking for one that gives a total for all floors. Link to comment Share on other sites More sharing options...
GerryT Posted March 16, 2014 Share Posted March 16, 2014 There are two approaches: 1. Just use a room finish schedule and check all floors 2. Use Floor identification macros & global memory Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 16, 2014 Share Posted March 16, 2014 Yes, Gerry I use the room finish schedule for square footage analysis. When doing additions you just turn off "'include in schedule" and just the added area will be included. Although, the final number is off by just a couple of s.f. b/c Chief figures the square footage to the center of the existing wall. I will never know why they did that. It's just wrong, but close enough to use. Link to comment Share on other sites More sharing options...
JBHammer Posted March 16, 2014 Author Share Posted March 16, 2014 Thank you for the answers. For new construction, I do need exact sq. footage. Gerry, I'm not sure about your #2 answer, I'm new to macros. Is that a way to get exact footage? I've always just drawn a room polyline and adjusted it to the main layer to get my footage. But it would be nice to have a macro set up on each floor plan that gave total footage for the project. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 16, 2014 Share Posted March 16, 2014 New construction will give you a better number but I still think it cuts the garage wall in halve, but its close enough for me. Link to comment Share on other sites More sharing options...
GerryT Posted March 17, 2014 Share Posted March 17, 2014 FYI --There's no advantage to using a macro as those macro's use the same functions as the normal Chief footage. Just a matter of preference. Standard cals.,unfortunately, are not very constant in that they cal to outside on the outside living area and center to center on the inside.--- mostly. If you want exact dims, as you say, the only way is to draw the internal dims yourself and zero in to make sure they are at the location you want. The room schedule does gives a total area at the bottom. -- Not sure about the accuracy -- but close. The problem is really with the programing of the various cals which are not consistent. Using internal dims would involve too many macros to be practical. IOW -- everything available is a approximation to some degree. Link to comment Share on other sites More sharing options...
mrscott Posted January 5, 2017 Share Posted January 5, 2017 Guys, There is a %Living.area% macro in Layout but is Grayed out. I would like to use this figure on my cover page plan title. How do I get it there and have it remain dynamic with plan changes? Thanks, Link to comment Share on other sites More sharing options...
lbuttery Posted January 5, 2017 Share Posted January 5, 2017 Note: CA has stated that the living area jumping problem has been fixed in X9 Lew Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 5, 2017 Share Posted January 5, 2017 I have a "Living Areas" Macro Package that consists of 3 macros %Living Areas Get Totals% - when placed in the Default Room Label accumulates all Floor Living Areas %Living Areas Table% - placed in a Text Box displays each Floor Living Area and the Total %Living Areas Total% - placed in a Text Box displays the Total Living Area of all Floors This Package is $10.00 usd. Let me know if you want it. 3 Link to comment Share on other sites More sharing options...
mrscott Posted January 5, 2017 Share Posted January 5, 2017 Joe, I may take you up on this and your other macro packages once I get my SAM Template completed.It may require some coaching from you if enable all the features you have designed into the package. What I am wondering is..."Why is the LIVING AREA (grayed out) in Layout?" Link to comment Share on other sites More sharing options...
HumbleChief Posted January 5, 2017 Share Posted January 5, 2017 3 minutes ago, mrscott said: What I am wondering is..."Why is the LIVING AREA (grayed out) in Layout?" It's a function of the plan not the Layout. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 5, 2017 Share Posted January 5, 2017 1 minute ago, mrscott said: "Why is the LIVING AREA (grayed out) in Layout?" Because it isn't supported in Layout. It's only a function of the Plan. See the Help File (Defaults - Plan - Living Area) Link to comment Share on other sites More sharing options...
mrscott Posted January 5, 2017 Share Posted January 5, 2017 "It's a function of the plan not the Layout"....okay....It must be there for a reason I have yet to discover. So, the search continues. Thanks, Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 5, 2017 Share Posted January 5, 2017 Scott, "Living Area" is an attribute of Rooms. Rooms (including the phantom room defined for the "Living Area Label") only exist in the Plan, not in the Layout. The Layout is only Sheet Size 2D CAD. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 5, 2017 Share Posted January 5, 2017 My macros to display the Table and the Totals will work in Layout because they are accessing the Global variables created by the first one in the Plan. OTOH, I prefer to put them in a CAD Detail Window in the Plan and send that to Layout. It's much cleaner and more reliable. Link to comment Share on other sites More sharing options...
mrscott Posted January 5, 2017 Share Posted January 5, 2017 Joe, Any idea why Chief would have it show up in Layout? If it is not applicable to Layout then why is it in the Macro list in Layout at all? I guess I should have checked the Help Files before asking the Forum. Sometimes it is quicker to ask the experts than to get bogged down searching HELP, Videos, or The Manual for answers. Of course ALL are very informative but often get me "Off Task". Thanks again, Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 5, 2017 Share Posted January 5, 2017 5 minutes ago, mrscott said: Any idea why Chief would have it show up in Layout? If it is not applicable to Layout then why is it in the Macro list in Layout at all? It's a matter of menu programming. It's much easier to set the "access/color" of a menu item than is is to create a completely separate menu. Menus and Hotkeys are independent of the current active window within Chief - so the menus are shared but the accessibility of each item is dependent on the active window. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 5, 2017 Share Posted January 5, 2017 9 hours ago, mrscott said: Guys, There is a %Living.area% macro in Layout but is Grayed out. I would like to use this figure on my cover page plan title. How do I get it there and have it remain dynamic with plan changes? Thanks, 3 ways... 1. Use macros created by Joe, myself, or others. 2. Create your own custom macros 3. Just create your desired text box in plan and send it to layout using a very small layout window. You just have to make sure your text box in plan is in a nice and stable position. Link to comment Share on other sites More sharing options...
mrscott Posted January 5, 2017 Share Posted January 5, 2017 So, kind of like the way I do my Schedules where i place them somewhere on the plan view and send that view to Layout and crop what I want to see. That works. Thanks, Link to comment Share on other sites More sharing options...
mrscott Posted January 5, 2017 Share Posted January 5, 2017 Mike/Joe, What I did... In Plan under "Annotation Sets" create a New Annoset/Layer Set Called "General Annotations - 1/2" Scale" Edit the 7 Attributes as desired, OK Select "Layer Display Options" and make a copy of the TEXT, RICH and Rename it "TEXT, RICH, GENERAL ANNOTATIONS 1/2"" OK Select Level 1, and in my case, choose the new Annoset. Using Rich Text entered the Macro %Living,area% (Anywhere on the screen) Sent it to Layout and positioned it as desired. (BEAUTIFUL!) In Plan,and from any layer, make sure the "TEXT, RICH, GENERAL ANNOTATIONS 1/2"" LAYER is set to display only on that layer (Modify ALL). What's interesting is I can turn off the display in PLAN and it still reports just fine in Layout. We'll see how it goes from here but a cool first shot. Thanks Guys, Link to comment Share on other sites More sharing options...
mrscott Posted August 23, 2017 Share Posted August 23, 2017 On 1/5/2017 at 10:39 AM, Joe_Carrick said: I have a "Living Areas" Macro Package that consists of 3 macros %Living Areas Get Totals% - when placed in the Default Room Label accumulates all Floor Living Areas %Living Areas Table% - placed in a Text Box displays each Floor Living Area and the Total %Living Areas Total% - placed in a Text Box displays the Total Living Area of all Floors This Package is $10.00 usd. Let me know if you want it. Joe, I want to purchase the above. How do you want to process this transaction? 1 Link to comment Share on other sites More sharing options...
wjmdes Posted June 3, 2020 Share Posted June 3, 2020 On 1/5/2017 at 11:39 AM, Joe_Carrick said: I have a "Living Areas" Macro Package that consists of 3 macros %Living Areas Get Totals% - when placed in the Default Room Label accumulates all Floor Living Areas %Living Areas Table% - placed in a Text Box displays each Floor Living Area and the Total %Living Areas Total% - placed in a Text Box displays the Total Living Area of all Floors This Package is $10.00 usd. Let me know if you want it. Joe, is this something you still have? Link to comment Share on other sites More sharing options...
rgardner Posted June 3, 2020 Share Posted June 3, 2020 55 minutes ago, wjmdes said: Joe, is this something you still have? Also interested. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 8, 2020 Share Posted July 8, 2020 On 1/5/2017 at 11:39 AM, Joe_Carrick said: I have a "Living Areas" Macro Package that consists of 3 macros %Living Areas Get Totals% - when placed in the Default Room Label accumulates all Floor Living Areas %Living Areas Table% - placed in a Text Box displays each Floor Living Area and the Total %Living Areas Total% - placed in a Text Box displays the Total Living Area of all Floors This Package is $10.00 usd. Let me know if you want it. Hi Joseph, I am trying to find this very thing and my search will continue. However, how I can purchase this macro from you? in ADT I have a main floor outline a second floor outline if exist a third floor outline if exist and then I total those on the elevation page I do not count sq.ft. the garage I find the sq ft of the lower, but that stands on it own and is not part of the total. Link to comment Share on other sites More sharing options...
