Doug_N Posted March 9, 2020 Share Posted March 9, 2020 Here is a little macro I made for displaying area in meters instead of sq ft. a=area*0.092903 a.round(2) As a habit, I use the three letters own or ref to tell if the macro is to be used in an item label or attached as a referenced macro. If I put this into a macro such as "object_area_own_metric" in an imperial drawing, and insert the macro into an enclosed polyline it returns 112.52 SQ FT. Why is it attaching the units to the output? If I use a referenced macro "object_area_ref_metric" and connect a text box to it the output is 112.52 with no units. Obviously I want sq m not sq ft after the output, Any idea how to stop the units from displaying if I use an owner macro in a polyline label? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 9, 2020 Share Posted March 9, 2020 In X12 all numeric attributes are Measurements that have "UNITS". Calculations return the same Units even though that isn't what you want. Change your macro to: a=(area*0.092903).round(2).to_f.sq_m.to_s Link to comment Share on other sites More sharing options...
BenMerritt Posted March 9, 2020 Share Posted March 9, 2020 It's also possible to leverage the unit system to handle the conversion for you, which is useful when you don't want to look up conversion constants: area.convert_to("sq m").round(2) Link to comment Share on other sites More sharing options...
Doug_N Posted March 9, 2020 Author Share Posted March 9, 2020 11 minutes ago, Joe_Carrick said: In X12 all numeric attributes are Measurements that have "UNITS". Calculations return the same Units even though that isn't what you want. Change your macro to: a=(area*0.092903).round(2).to_f.sq_m.to_s 2 minutes ago, BenMerritt said: It's also possible to leverage the unit system to handle the conversion for you, which is useful when you don't want to look up conversion constants: area.convert_to("sq m").round(2) Wow, thank you Joe and Ben. Ben your solution is very elegant, Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 10, 2020 Share Posted March 10, 2020 1 hour ago, Doug_N said: Wow, thank you Joe and Ben. Ben your solution is very elegant, Yes, Ben's solution using the .convert_to() method works nicely but I'm not really up on the methods available with the Measurement Class. I really need a pdf document that is akin to the Ruby.org documentation. I think CA should provide that in their help files or a separate PDF for us. 3 Link to comment Share on other sites More sharing options...
Chopsaw Posted March 10, 2020 Share Posted March 10, 2020 1 hour ago, Joe_Carrick said: Yes, Ben's solution using the .convert_to() method works nicely but I'm not really up on the methods available with the Measurement Class. I really need a pdf document that is akin to the Ruby.org documentation. I think CA should provide that in their help files or a separate PDF for us. Yes Please. That would be great. @BenMerritt Link to comment Share on other sites More sharing options...
Doug_N Posted March 10, 2020 Author Share Posted March 10, 2020 I agree. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 10, 2020 Share Posted March 10, 2020 8 hours ago, BenMerritt said: It's also possible to leverage the unit system to handle the conversion for you, which is useful when you don't want to look up conversion constants: area.convert_to("sq m").round(2) It can actually be even shorter. I believe area.to_sq_m.round(2) does the same thing right? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 10, 2020 Share Posted March 10, 2020 It's not a full list if what can be done, an explanation of exactly how the conversions work, or an explanation of the different types of Measurements (Linear vs. Area vs. Volume), but here's a list of a few of the basic methods you can use to convert measurements to floats based on other units: .to_inch .to_in .to_foot .to_ft .to_yard .to_yd .to_mm .to_cm .to_dm .to_m .to_sq_inch .to_sq_in .to_sq_foot .to_sq_ft .to_sq_yard .to_sq_yd .to_sq_mm .to_sq_cm .to_sq_dm .to_sq_m .to_cu_inch .to_cu_in .to_cu_foot .to_cu_ft .to_cu_yard .to_cu_yd .to_cu_mm .to_cu_cm .to_cu_dm .to_cu_m And here's a list of what you can use to convert a float to a measurement... .inch .in .foot .ft .yard .yd .mm .cm .dm .m .sq_inch .sq_in .sq_foot .sq_ft .sq_yard .sq_yd .sq_mm .sq_cm .sq_dm .sq_m .cu_inch .cu_in .cu_foot .cu_ft .cu_yard .cu_yd .cu_mm .cu_cm .cu_dm .cu_m ...again, learning exactly how the conversion works is a bit more complicated but if you use .to_s you will get the newly created Measurement and its units. There are other similar methods as well such as .convert_to (as was mentioned above by Ben) as well as Measurement.new(value, optional unit). In addition Chief also has a built in NumberFormatter functionality that you can use to format various measurements. It basically works exactly like the Dimension formatting options we have. I don't have the time or inclination to go into all of it in this post, but it's pretty cool. Link to comment Share on other sites More sharing options...
ChiefPlagman Posted March 10, 2020 Share Posted March 10, 2020 15 hours ago, Joe_Carrick said: I think CA should provide that in their help files or a separate PDF for us. See "Measurement and NumberFormatter Classes" under "Ruby in Chief Architect" in Help. Link to comment Share on other sites More sharing options...
Doug_N Posted March 10, 2020 Author Share Posted March 10, 2020 Well here it is, the links to usefull resources for Ruby in Chief Architect Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 11, 2020 Share Posted March 11, 2020 Notably missing from the Help is an example of using the NumberFormatter class. Basically it has to be created first. There's no reason to create it for every time you want to format a number - particularly if you are always going to be using the same parameters. Here's the way I create a persistent instance of the class and how it can be used: $NF = NumberFormatter.new $NF.unit = "'-\"" $NF.use_fractions = true $NF.denominator = 8 This sets the parameters to what I want. Then I can use the following whenever I need to format a number: $NF.apply( 123.5.in ) ---> 10' 3-1/2" Note the inclusion of .in so the formatter knows the value is in inches. If passing a Measurement value then that wouldn't need to be included. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 11, 2020 Share Posted March 11, 2020 I’m curious if there’s a way to access and modify the initial settings in the NumberFormatter class. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 11, 2020 Share Posted March 11, 2020 1 minute ago, Alaskan_Son said: I’m curious if there’s a way to access and modify the initial settings in the NumberFormatter class. Not that I'm aware of. They are initialized automatically by the .new method. That's why I set up a global as my NumberFormatter. You could actually have several globals, each with different settings - or just use 1 and change the parameters on the fly. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 11, 2020 Share Posted March 11, 2020 You should be able to create your own "derived class" with whatever settings you want but I'm not 100% sure it would work since the NumberFormatter class is one that Chief created and it may not be registered. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 11, 2020 Share Posted March 11, 2020 The .inspect method will give you some that information, depending on the units being used. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 11, 2020 Share Posted March 11, 2020 Ya, I know how to use it and I currently have a base macro set up that I can modify and simply copy as necessary for various formatting. I was just thinking aloud and wondering whether we could access the settings for the class itself or not. Not a big deal at all. I might search the program files to see if it’s hidden in there somewhere. It’s just a personal curiosity really and not too important. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 11, 2020 Share Posted March 11, 2020 It would be nice if Chief's Help included what the "defaults" are for each parameter. The only one they mention is: reduce_fractions() I think that all of the True | False settings are defaulted to False 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 12, 2020 Share Posted March 12, 2020 On 3/11/2020 at 9:47 AM, Joe_Carrick said: It would be nice if Chief's Help included what the "defaults" are for each parameter. The only one they mention is: reduce_fractions() I think that all of the True | False settings are defaulted to False These are the apparent OOB settings... unit = Not set show_unit = true show_leading_zero = true show_trailing_zeros = false use_fractions = false decimal_places = 6 denominator = 16 thousands_separator = , show_denominator = true reduce_fractions = gcd (greatest common divisor) Link to comment Share on other sites More sharing options...
SageDesign Posted January 25 Share Posted January 25 How do I get my window schedule in Chief 16 to display "dimensions", "width", and "height" in feet and fractional inches. It now shows in "feet" with 5 decimal places! Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 25 Share Posted January 25 6 minutes ago, SageDesign said: How do I get my window schedule in Chief 16 to display "dimensions", "width", and "height" in feet and fractional inches. It now shows in "feet" with 5 decimal places! There is a Number Formatting column in your schedule in X16, pick the column you want to change the format on and format accordingly Link to comment Share on other sites More sharing options...
SageDesign Posted January 26 Share Posted January 26 Thanks for getting back to me so quickly. I seem to only be able to select the entire table "schedule". It does not let me select only one column. And in the "Schedule Specification Screen", if I click on the "Number Formatting" tab, there are NO columns to select for formatting. Chief does not seem to "see" any columns with numerical values. Suggestions? Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 26 Share Posted January 26 mine does for at least width and height. maybe you are using a different column? you might want to post th eplan Link to comment Share on other sites More sharing options...
DBCooper Posted January 27 Share Posted January 27 If you are trying to use a custom field as a schedule column and you want to control the formatting, you need to check the "format as number" option when you create it. You can also edit your custom field settings in your default settings under "schedules" if you need to change one you already have. Link to comment Share on other sites More sharing options...
ComputerMaster86 Posted April 19 Share Posted April 19 I have read this thread a billion times trying to take in knowledge of these number formaters and conversions. I have one question if you don't mind. If using text to display room height as a custom room label, why can't one simply use something like... %room.height.ceiling.convert_to("foot")% to change the output to feet??? The output is inches. There must be something I am not understanding. Link to comment Share on other sites More sharing options...
