akabuilder Posted November 17, 2019 Share Posted November 17, 2019 I often have trouble drawing a roof that is below another roof, i.e. on a 2nd or 3rd story house. If i use "Build Roof Planes", the roof planes keep will build on the upper floor even though i am working on the 1st Level. They attach to the upper story roof instead of a 1st story roof plane. How do I correct this? In this instance I have a deck and entry door at a split level and this is where I would like the roof to appear over. Link to comment Share on other sites More sharing options...
akabuilder Posted November 17, 2019 Author Share Posted November 17, 2019 3D Space. Link to comment Share on other sites More sharing options...
akabuilder Posted November 17, 2019 Author Share Posted November 17, 2019 Kent_House.plan Link to comment Share on other sites More sharing options...
akabuilder Posted November 17, 2019 Author Share Posted November 17, 2019 Hancock House DOUBLE GABLE Plan_.plan Link to comment Share on other sites More sharing options...
BrownTiger Posted November 17, 2019 Share Posted November 17, 2019 >I often have trouble drawing a roof that is below another roof, i.e. on a 2nd or 3rd story house. If i use "Build Roof Planes", the roof planes keep will build on the upper floor even though i am working on the 1st Level. Like Solver stated roof builds everywhere where it is needed. > In this instance I have a deck and entry door at a split level and this is where I would like the roof to appear over. Sometimes it is easier to just start drawing a roof plane by pressing Q key. You can 1) make baseline polynine, to make polyline and give roof builder the direction to build/rebuild roofs. 2) for your front porch you can section off the area you want to have roof, and open this room and specify roof over this room. 3) Or my preference: press Q, set 1 st point outside the deck corner post, drag cursor along the stairs to specify how wide your roof plane should be click, now draw toward the house [final click]. All it takes 3 clicks [5 seconds tops] BTW: It is very discouraged to have a deck over any living space. Link to comment Share on other sites More sharing options...
tommy1 Posted November 17, 2019 Share Posted November 17, 2019 I hate to say this because often it's not a popular answer but if you learn how to draw roofs manually and understand how they work, you can usually make the roof work fairly easily. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 17, 2019 Share Posted November 17, 2019 On 11/17/2019 at 1:54 AM, akabuilder said: How do I correct this? Expand As Tommy said and I agree, learn the tools, dialog boxes, settings of Chief and use it as a tool, and not a misunderstood "partner", this is NOT "rocket science". I gave up waiting for Chief to "do" things long ago and just caused them as I needed and wanted. DJP Link to comment Share on other sites More sharing options...
joey_martin Posted November 17, 2019 Share Posted November 17, 2019 Here is what I do... I layout the first floor...obviously....and when I am ready for the second floor, I set the second floor ceiling height to the height I want my knee walls. In this sample I set them to 54". So that means my entire second floor will have 54" ceiling heights, and that is OK with me. Now, when I am ready to start laying out my rooms up there, I TURN OFF auto roof build. Now I can move those ceiling heights up to 97" and my roof stays where it's suppose to be. 2 Link to comment Share on other sites More sharing options...
SNestor Posted November 17, 2019 Share Posted November 17, 2019 On 11/17/2019 at 3:11 PM, joey_martin said: Here is what I do... I layout the first floor...obviously....and when I am ready for the second floor, I set the second floor ceiling height to the height I want my knee walls. In this sample I set them to 54". So that means my entire second floor will have 54" ceiling heights, and that is OK with me. Now, when I am ready to start laying out my rooms up there, I TURN OFF auto roof build. Now I can move those ceiling heights up to 97" and my roof stays where it's suppose to be. Expand Listen to Joey...he knows what he’s doing. Great tip Joey... Link to comment Share on other sites More sharing options...
Kbird1 Posted November 17, 2019 Share Posted November 17, 2019 On 11/17/2019 at 2:34 AM, akabuilder said: Hancock House DOUBLE GABLE Plan_.planFetching info... Expand I think you just drew those 2 roof planes along the wrong wall perhaps ? ( deleted them in pic below ) Using the Deck Railings it seems to work fine................. Link to comment Share on other sites More sharing options...
akabuilder Posted November 18, 2019 Author Share Posted November 18, 2019 On 11/17/2019 at 7:38 PM, SNestor said: Listen to Joey...he knows what he’s doing. Great tip Joey... Expand That is a great tip - Thanks Link to comment Share on other sites More sharing options...
Alexnicu Posted November 18, 2019 Share Posted November 18, 2019 Hy! how can i clear the space between the wall and the roof Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 18, 2019 Share Posted November 18, 2019 On 11/17/2019 at 3:11 PM, joey_martin said: Here is what I do... I layout the first floor...obviously....and when I am ready for the second floor, I set the second floor ceiling height to the height I want my knee walls. In this sample I set them to 54". So that means my entire second floor will have 54" ceiling heights, and that is OK with me. Now, when I am ready to start laying out my rooms up there, I TURN OFF auto roof build. Now I can move those ceiling heights up to 97" and my roof stays where it's suppose to be. Expand Yup. This is a very good method. In addition, I also use the ceiling height on attic levels again at a third height for temporary purposes in order to use the Ceiling Break Lines to show where my usable ceiling height areas are when laying out bathrooms, cabinetry, etc. Once things are positioned I move ceilings back up to where they should be. Link to comment Share on other sites More sharing options...
