joey_martin Posted February 23, 2017 Share Posted February 23, 2017 Ok Gurus. I need to put multiple windows into the box widow (see pic). When I place the box it only allows a single window...I need four....how? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 23, 2017 Share Posted February 23, 2017 I would personally recommend you don't screw around with the box window tool and instead build it using other methods. Link to comment Share on other sites More sharing options...
Francois Posted February 23, 2017 Share Posted February 23, 2017 I run into that problem. I created a wall, placed windows in it and changed the height of the wall by raising it. 1 Link to comment Share on other sites More sharing options...
johnny Posted February 23, 2017 Share Posted February 23, 2017 I'm running into this issue often. Michael is right, but if Chief is watching this it would be very nice to have a box window tools that wasn't so limiting....as I really like certain aspects of the box window tool. As Joey mentions, we should be able to add windows BUT also we should have the ability to copy and paste a copy of this element. It would be SUPER cool if we could save these elements to our Library. Link to comment Share on other sites More sharing options...
joey_martin Posted February 23, 2017 Author Share Posted February 23, 2017 I was afraid of something like this. I haven't used these tools (box, bay, etc..) for sometime because of the extreme limitation, was hoping something had changed. I built it with multiple walls. Link to comment Share on other sites More sharing options...
SNestor Posted February 23, 2017 Share Posted February 23, 2017 Maybe someone could do a video on this topic. I have generally built boxed/bay windows manually...but, it's difficult to say the least. At least for me...I'm no guru. I hadn't realized that the "box window" tool was so limiting. Thanks for posting Joey...learned something new...again. Link to comment Share on other sites More sharing options...
dshall Posted February 23, 2017 Share Posted February 23, 2017 23 minutes ago, SNestor said: Maybe someone could do a video on this topic. I have generally built boxed/bay windows manually...but, it's difficult to say the least. At least for me...I'm no guru. I hadn't realized that the "box window" tool was so limiting. Thanks for posting Joey...learned something new...again. The box window and the bay tool is essentially useless in my opinion. I am not smart enough to use it.... and apparently Joey isn't smart enough either. I always manually build. It is a room with a raised floor and I have done multiple vids on this many many years ago...... but I am sure I could not find them. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 23, 2017 Share Posted February 23, 2017 Yep, it's one of those tools that simply isn't that simple. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 23, 2017 Share Posted February 23, 2017 it's only ok if you have one window per wall, other than that manually build Link to comment Share on other sites More sharing options...
johnny Posted February 23, 2017 Share Posted February 23, 2017 I've used them for a few instances myself but boy they could be so much more helpful with just a small amount of adjustment. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 23, 2017 Share Posted February 23, 2017 It would be really nice if there was a way to "explode" so that you then had the individual walls and windows to edit. I have no idea why CA didn't provide that simple capability. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 24, 2017 Share Posted February 24, 2017 Yes why not , they do for dormers Link to comment Share on other sites More sharing options...
Francois Posted February 24, 2017 Share Posted February 24, 2017 9 hours ago, Francois said: I run into that problem. I created a wall, placed windows in it and changed the height of the wall by raising it. For the sake of learning something, was that a wrong answer? I thought that it is how I did it a while ago. I would appreciate if someone can comment on it. A yes on no would be ok. Thank you Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 24, 2017 Share Posted February 24, 2017 OK, It's a bit convoluted but her goes: In a blank plan create a section of a wall insert 4 windows to make up the size you need and mull them together reduce the surrounding wall to just a hair larger than the mulled unit convert that to a Millwork or Exterior Fixture Symbol back in your Plan with the Box Window set the size of the Window and convert it to a Pass-Thru put the Symbol in the opening I told you it was a bit convoluted 2 Link to comment Share on other sites More sharing options...
parkwest Posted February 24, 2017 Share Posted February 24, 2017 Can you click on the box window and then click on ungroup icon? It was a few months ago, but I think that was how I did it. Link to comment Share on other sites More sharing options...
Francois Posted February 24, 2017 Share Posted February 24, 2017 2 hours ago, Joe_Carrick said: OK, It's a bit convoluted but her goes: In a blank plan create a section of a wall insert 4 windows to make up the size you need and mull them together reduce the surrounding wall to just a hair larger than the mulled unit convert that to a Millwork or Exterior Fixture Symbol back in your Plan with the Box Window set the size of the Window and convert it to a Pass-Thru put the Symbol in the opening I told you it was a bit convoluted Thank you Joe for that convoluted but really appreciated reply. 1 point goes to you Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 24, 2017 Share Posted February 24, 2017 For most windows in Chief you could just "Replace From Library" and use any "Window Symbol". Unfortunately, that tool isn't available for the component windows within a Box, Bay or Bow Window. Link to comment Share on other sites More sharing options...
