ACADuser Posted January 31, 2016 Share Posted January 31, 2016 Looking at some threads I did not find many. I was asked to furnish alternate front elevations. The columns on the porch will change. The wall finish will change from stucco to siding and the font hip will change to a gable. How does one accomplish this showing two elevations in one plan? Perhaps I did not find the relevant post or video for this problem. Thanks Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 31, 2016 Share Posted January 31, 2016 I personally don't usually make that extent of changes inside the same plan. I just do a Save As and start a new version of the plan. Link to comment Share on other sites More sharing options...
ACADuser Posted January 31, 2016 Author Share Posted January 31, 2016 Thanks Michael. Link to comment Share on other sites More sharing options...
Rosco2017 Posted January 31, 2016 Share Posted January 31, 2016 I do what Michael does as well. I usually will create a folder and place the extra files that I "Save As" 'd in them to easily find them. I usually name them whatever the file name is with "Elevation A, B, C, etc. And then I render different elevations. Good Luck Sir! Link to comment Share on other sites More sharing options...
Rashid_Garuba Posted January 31, 2016 Share Posted January 31, 2016 Ross, How do you handle things if a revision is made that must be applied to all versions? Link to comment Share on other sites More sharing options...
Rosco2017 Posted January 31, 2016 Share Posted January 31, 2016 The only time I do this is when we build a spec, and the builder specifically asks for it. I'm not asked to do this all the time. We don't have "Stock Plans" like most builders. We are a very custom, luxury builder. If that were the case, I normally wouldn't do anymore than 3 elevations (3 Files) and you can bet I charge for my time. Lol 1 Link to comment Share on other sites More sharing options...
ACADuser Posted January 31, 2016 Author Share Posted January 31, 2016 Mr hall has an interesting method of handling revisions here: Link to comment Share on other sites More sharing options...
ACADuser Posted January 31, 2016 Author Share Posted January 31, 2016 I read that cosmetic options like wall finishes can be handles with Material Regions on different layers. But most changes take a structural change and best use the second copy of the plan file. I'll give this a try. BTW when you stop using a PLAN file associated with a LAYOUT file do you need to do anything special to sever this relation? Say you delete all views in the LAYOUT file and save it to a new project. Is there any baggage from the old PLAN associated with the Save AS Layout file? Link to comment Share on other sites More sharing options...
lbuttery Posted January 31, 2016 Share Posted January 31, 2016 Rashid: you pray that doesn't happen it can be a real PITA it would be nice if we had TOTAL layer control and could have as-built, remod, alt1, alt2 etc all in the same plan I understand that Softplan as had the "Build options" feature for many versions now but have never seen a demo of it with TOTAL layer control it would be - now you see it - now you don't Lew Link to comment Share on other sites More sharing options...
javatom Posted January 31, 2016 Share Posted January 31, 2016 Maybe I missed something. How are walls being cut from one plan and placed in the exact same place on a DIFFERENT plan. I think he said "6" every time he did this. Is that a macro? How are those walls going back exactly where they would have been even though the cut is from one plan and the paste is on another? Link to comment Share on other sites More sharing options...
ACADuser Posted January 31, 2016 Author Share Posted January 31, 2016 All plans he used are copies from the ORIGINAL plan so there offset from the origin is exactly the same. I use Ctrl+Alt+V (paste hold position) Link to comment Share on other sites More sharing options...
javatom Posted January 31, 2016 Share Posted January 31, 2016 OK that makes sense. Thanks Link to comment Share on other sites More sharing options...
LevisL Posted February 1, 2016 Share Posted February 1, 2016 One tip I would add is to place (and save) your camera view(s) in the first elevation, BEFORE doing a save as. This way, you can have the exact same camera angle(s) in all the alternate elevations. Unfortunately, we can't copy and paste cameras from one plan to another and just applying the same numbers in the camera dbx doesn't always work if you've zoomed in with your mouse. 1 Link to comment Share on other sites More sharing options...
ACADuser Posted February 2, 2016 Author Share Posted February 2, 2016 Great tip! Link to comment Share on other sites More sharing options...
Rich_Winsor Posted February 2, 2016 Share Posted February 2, 2016 .... Unfortunately, we can't copy and paste cameras from one plan to another and just applying the same numbers in the camera dbx doesn't always work if you've zoomed in with your mouse. I don't think this is hijacking as it seems germane to the thread, but why can't we use the copy & paste functions with cameras (and the undo/redo functions as well)? There are many times I have wished that I could duplicate a camera setup that I had used in a previous iteration of a plan. Just recently I wanted to Copy & Reflect About a camera position so I could have identical shots of two duplexes that have mirror image floor plans. Also if you use the edit handles to move a camera in plan view you can't Undo the moves. What gives? 1 Link to comment Share on other sites More sharing options...
kMoquin Posted February 2, 2016 Share Posted February 2, 2016 Here's a tip to replicate a camera from one plan to the next (since we can't copy them) Draw a line from the camera to the marker at the end that matches the camera you'd like to copy in the first plan. (CAM 1) Copy the line and paste in place in the second plan. Create a new camera (CAM 2) in the second plan snapping to the ends of the line you copied. Open the camera specifications on the camera in the first plan (CAM 1) and record the settings on the "Camera" tab. Input these settings in the dialog box for the new camera (CAM 2). Note that in step 1 you cannot snap to the camera object. If both plans need 'exactly' the same camera point of view you can use steps 2 through 5 to make two exact cameras. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 2, 2016 Share Posted February 2, 2016 This is why I have all my cameras already set up in my template plans and all I have to do is move them around. I really don't have to create camera's anymore. Elevations, sections, interior 3d views ,already set up and sent to the layout template, so when I start a new job it's all done so you can get to designing very quickly. Everything generates to the layout as you design. 1 Link to comment Share on other sites More sharing options...
Sydney23 Posted March 24, 2016 Share Posted March 24, 2016 Perry, what a superb time-saving tip. I will definitely try and implement this. Thanks!! Link to comment Share on other sites More sharing options...
