johnny Posted August 12, 2015 Share Posted August 12, 2015 I have a client who wants a Greene&Greene inspired home - including battered walls in certain areas. My plan was to use a modeling profile the full length of my wall section - I wanted to see if anyone had a better idea - but that is the best idea I can think of. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 12, 2015 Share Posted August 12, 2015 Johnny, Use a Room Molding Polyline (Exterior Room). This will allow you to apply your Molding Profile to the entire perimeter and then "suppress" on selected edges. Link to comment Share on other sites More sharing options...
HumbleChief Posted August 12, 2015 Share Posted August 12, 2015 I think I like Joe's idea though I'm not exactly sure how to implement it. If it's only in 'certain areas' another method is to create simple poly-line solids in elevation and copy/distribute/shape ends as needed. Quicker than it seems. I also have created a second framing Layer in the wall dbx but there were serious limitations. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 12, 2015 Share Posted August 12, 2015 Joe, isn't there a problem with windows and doors poking thru with that method. I would just say Chief just doesn't do it, without a lot of hand work. and trouble. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted August 12, 2015 Share Posted August 12, 2015 You should consider using a very steeply sloping ROOF for this. It's easy to cut out openings for doors & windows, whereas with a molding polyline, you have to use multiple ones above and below openings. Of course, if you're just talking about a stone wainscot, then a molding polyline will work fine. Edit: Sorry, mistakenly wrote "wall." Link to comment Share on other sites More sharing options...
johnny Posted August 12, 2015 Author Share Posted August 12, 2015 Ok, I was experimenting on how to do this (appreciate your comments) - and here is what I did: 1. Created the exterior molding line as Joe said. 2. Set the line segment along the window to no molding 3. Created a new molding line segment that matches the window 4. Bring my molding profile into a section view 5. Cut the molding profile based on the vertical window segment 6. Take the 2 new molding profiles into library 7. Set the vertical off-sets of the 2 moldings as measured in the section cut That may seem like a lot of work per window, but I personally dont change my header heights and keep most my horizontal lines parallel. So I may have to make a couple more sectioned moldings, but this was actually fairly fast. I've shown pictures - but please keep in mind this is just an experiment drawings, as the real design is coming. A few comments on things I wish I could do and I can't see a way. 1. Show the 2d molding lines differently and with a fill. Right now I have 2 lines representing my "molding" lines. 2. Shift around the profiles in a "live" view. I have this in other apps and its great. 3. Multiple elements like this that overlap each-other means you have to know exactly where the lines are, since there is no visual distinction. In Vectorworks I would "group" these lines so when I double clicked every other aspect of the model greys out and I only see/edit the lines I want to work on. Anyway, thanks again. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 12, 2015 Share Posted August 12, 2015 Nicely done "young jedi". 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 12, 2015 Share Posted August 12, 2015 Johnny Are you just looking for 3d?, if not, How does it frame for you? How does the foundation work for you? What about electrical. Are there too many lines in vector view? Link to comment Share on other sites More sharing options...
johnny Posted August 12, 2015 Author Share Posted August 12, 2015 Johnny Are you just looking for 3d?, if not, How does it frame for you? How does the foundation work for you? What about electrical. Are there too many lines in vector view? Good questions that I am thinking about right now and how that might work in CA. My client has a degree in architecture, and was a professor - but never practiced. Whatever I do needs to pass just the visual test. Link to comment Share on other sites More sharing options...
yusuf-333 Posted August 13, 2015 Share Posted August 13, 2015 OK nice ones Johnny is doing great job in ca. My take on battered walls, some times I post the apples while the apples are needed. I used my favourite tool(roof) combined with walls. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 13, 2015 Share Posted August 13, 2015 Yusuf, Am I correct that you are using "Skylight" openings where the doors and windows are in the walls? Link to comment Share on other sites More sharing options...
yusuf-333 Posted August 13, 2015 Share Posted August 13, 2015 Yusuf, Am I correct that you are using "Skylight" openings where the doors and windows are in the walls? Sure Joe, you are about the opening. You started, let's continue questions and answers session, what do you think the white casing is?, what is the framing also? $-- question. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted August 13, 2015 Share Posted August 13, 2015 Yusuf, Am I correct that you are using "Skylight" openings where the doors and windows are in the walls? Also, one advantage to roofs is the ability to use the polyline to roof hole tool, off of the "magic wand" selections, which gives you flexibility in openings that a polyline molding does not have. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 13, 2015 Share Posted August 13, 2015 Did I not see a video on you doing this Yusef ? Link to comment Share on other sites More sharing options...
yusuf-333 Posted August 13, 2015 Share Posted August 13, 2015 Did I not see a video on you doing this Yusef ? Actually yes, it was posted on my YouTube channel. It is a short vid with bad resolution. I will post a HQ one with "how to". but I think the plan is more helpful for now since it is just a roof that makes the trick. battered wall.plan Link to comment Share on other sites More sharing options...
johnny Posted August 13, 2015 Author Share Posted August 13, 2015 Thanks Yusuf - this is very interesting and I didn't even think of using a roof poly. I will check this out and try it. Link to comment Share on other sites More sharing options...
johnny Posted August 13, 2015 Author Share Posted August 13, 2015 Could you provide a link to your youtube again Yusuf...? Link to comment Share on other sites More sharing options...
yusuf-333 Posted August 13, 2015 Share Posted August 13, 2015 Thanks Yusuf - this is very interesting and I didn't even think of using a roof poly. I will check this out and try it. Thanks johnny, I am glad if that helps. Here is it, https://youtu.be/6q3-nGUJEU0 Link to comment Share on other sites More sharing options...
ShaneK Posted August 14, 2015 Share Posted August 14, 2015 Yusuf-333 = the roof plane MASTER. Very creative my friend. Link to comment Share on other sites More sharing options...
yusuf-333 Posted August 14, 2015 Share Posted August 14, 2015 Yusuf-333 = the roof plane MASTER. Very creative my friend. Thanks ShaneK. Link to comment Share on other sites More sharing options...
