Larry_Sweeney Posted June 29, 2015 Share Posted June 29, 2015 I would like to curve the top of a exterior railing wall (attachment), and I'm getting a sore spot on my head from all the scratching. I've been unable to find any info on this so far. Is this possible to do with walls in CA? Of course I could make it out of a p-solid, but would prefer using a wall if possible. If this can be done can anyone point me in the right direction for the info or instruct me on the procedure? As always all advice is greatly appreciated. Link to comment Share on other sites More sharing options...
DeedeeU Posted June 29, 2015 Share Posted June 29, 2015 Hello Larry, That is a great question and a great idea for a feature request! Unfortunately there is not a way to curve the top of walls. You could create many breaks in the top of a wall and create a sectioned curve with multiple angled edges. Link to comment Share on other sites More sharing options...
Bill_Emery Posted June 29, 2015 Share Posted June 29, 2015 Use a roof plane as the wall cap, And the wall will be restricted by the curve of the roof plane. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted June 29, 2015 Author Share Posted June 29, 2015 Bill........Thankyou---seems like a good work around. I'm not sure how often this problem comes up, but as CA's Deedeeu said, "it would make a great feature request". I try your idea and see if I run into any problems and follow up on this thread later. Have a great day. Link to comment Share on other sites More sharing options...
BenPalmer Posted June 29, 2015 Share Posted June 29, 2015 I usually do that out of polyline solids. Bill's curved roof cap idea is good to. Definitely needs to be a feature in chief. Link to comment Share on other sites More sharing options...
Ginkgohouse Posted June 29, 2015 Share Posted June 29, 2015 I use the roof method - Works pretty well. And you can add shadow boards/frieze for more molding details. Attached is the plan I keep in my templates for a starting place when using rails in the plan Curved Rail.plan 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted June 29, 2015 Share Posted June 29, 2015 I use the roof method - Works pretty well. And you can add shadow boards/frieze for more molding details. Attached is the plan I keep in my templates for a starting place when using rails in the plan Cool Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted June 29, 2015 Author Share Posted June 29, 2015 Ginkgohouse.......Looks great, but I'm having a "brain fart". For what ever reason my roof won't cut the wall. Do you or anyone have any ideas to what I'm doing or not doing that is keeping the roof from cutting the wall or do you need to see the plan? I'll have to show it through Dropbox if that's the case. Thanks for taking the time. Link to comment Share on other sites More sharing options...
dshall Posted June 29, 2015 Share Posted June 29, 2015 Ginkgohouse.......Looks great, but I'm having a "brain fart". For what ever reason my roof won't cut the wall. CURVED TOP WALL 2.JPG Do you or anyone have any ideas to what I'm doing or not doing that is keeping the roof from cutting the wall or do you need to see the plan? I'll have to show it through Dropbox if that's the case. Thanks for taking the time. I bet that is defined as a RAILING WALL Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted June 29, 2015 Author Share Posted June 29, 2015 https://dl.dropboxusercontent.com/u/49042923/BERLIN%20PROJECT%2006292015.zip Scott.......No it's not a railing wall. To eliminate aggravation, here's the link to the plan in Dropbox, which is still in an early phase of the design process Link to comment Share on other sites More sharing options...
CJSpud Posted June 29, 2015 Share Posted June 29, 2015 No data in plan .... close the plan 1st then post. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted June 29, 2015 Author Share Posted June 29, 2015 https://dl.dropboxusercontent.com/u/49042923/BERLIN%20PROJECT%2006292015.zip Sorry about that..............Like I said earlier, my mind is in "brain fart" mode. Link to comment Share on other sites More sharing options...
Ginkgohouse Posted June 29, 2015 Share Posted June 29, 2015 No data in either of the two links......You might want to see a Doctor about those BFs Link to comment Share on other sites More sharing options...
ShaneK Posted June 29, 2015 Share Posted June 29, 2015 Ginkohouse nailed it, poly solid quickest but roofs allow more detail. Not sure we need a magic button to create it. Link to comment Share on other sites More sharing options...
BenPalmer Posted June 29, 2015 Share Posted June 29, 2015 Ginkohouse nailed it, poly solid quickest but roofs allow more detail. Not sure we need a magic button to create it. The feature request (or magic button) would be the ability to curve the tops of walls...seems like the 'change line/arc' tool would be great here. Select the top of wall, 'change line/arc' and edit as needed. Nice and quick...faster then polyline solid in this case. Link to comment Share on other sites More sharing options...
CJSpud Posted June 29, 2015 Share Posted June 29, 2015 I think Ben's idea would be the way to go. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted June 29, 2015 Author Share Posted June 29, 2015 https://dl.dropboxusercontent.com/u/49042923/BERLIN%20REAR%20ADDITION%20PROJECT.zip How does that saying go. If you don't succeed TRY, TRY AGAIN!! I'm not sure what I did wrong the last time, but if this doesn't work I'm going for a walk. Maybe it's best if I go back to bed and start this day all over again. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 29, 2015 Share Posted June 29, 2015 thx Ginkgo , nice to have an example to look at. M. Link to comment Share on other sites More sharing options...
Ginkgohouse Posted June 29, 2015 Share Posted June 29, 2015 Larry - Click "Default Wall Top Ht" in Wall DBX and rebuild if necessary P.S. Nice Eyebrow ! Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted June 29, 2015 Author Share Posted June 29, 2015 Ginkgohouse......That worked! Ginkgohouse and to all............Thank you for your time and comments------much appreciated. Have a great day P.S. Ginkgohouse---Do you have a name? Link to comment Share on other sites More sharing options...
Ginkgohouse Posted June 29, 2015 Share Posted June 29, 2015 No Problem ! Also, Did you create the gargoyle in CA or Sketchup? Mark <--- Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted June 29, 2015 Author Share Posted June 29, 2015 I think Ben's idea would be the way to go. Curt.......this would definitely have been easier, but in plan view I wanted to show an actual wall. Now the next thing will be installing a cap on top like I want. I'm going to try and use a roof, shadow boards and freize to get what I'm after. This is the profile I'm after. I'm hoping to be able to use the roof rather than a 3D molding p-line. I have a feeling using a p-line will be a real pain. If it the "roof" idea works I'll show it on this thread. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted June 29, 2015 Author Share Posted June 29, 2015 Mark.........The gargoyle came from Google Wharehouse. It was close enough to what the customer had purchased to use in the design. That section is still a work in progress. The actual gargoyle weighs 900lbs. It's solid concrete. I told the customer to get one formed out of dense foam, (He thought I was joking!) The cost of building the structure to sit it on would be W-A-Y less expensive. Structurally it's a real PITA! I'll need an engineers stamp for sure. Link to comment Share on other sites More sharing options...
BenPalmer Posted June 29, 2015 Share Posted June 29, 2015 Curt.......this would definitely have been easier, but in plan view I wanted to show an actual wall. Larry, the idea referenced was for a new feature to be able to use the 'change line/arc' tool at the top of the wall. We could add to that a feature to be able to add a profiled cap...perhaps using railing wall cap could work? I like the roof on top as well. However, if the situation warrants and I decide a polyline would be better and want it to show as a wall in floor plan view, I simply put it on the wall layer (I use 2 lines for my walls and not all the other layers). It's good for us to have multiple ways to achieve something since there are so many situations and some work better then others depending on the specific situation. But the ability to edit a wall in 3d the same way we would any CAD makes sense or it's 'intuitive'. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted June 29, 2015 Author Share Posted June 29, 2015 Ben.............agree 100% Link to comment Share on other sites More sharing options...
