carowe Posted March 30, 2023 Share Posted March 30, 2023 I am using X15 am drawing a 3 story house. The first floor has the floor joists showing - as in the picture below - but the remaining two floors have drywall ceilings. And, as you can see in the pic, there is a partial ceiling in this room as well where the skylights are. Thought it was figured out, but when I got the joists to display on the first floor, they did on all of the floors. Is there a way to do this? TIA! Link to comment Share on other sites More sharing options...
Chopsaw Posted March 30, 2023 Share Posted March 30, 2023 You should be able to delete the ceiling finish layers from the room definition. Not exactly sure what is what is going on on the left though if that is a separately defined room or if it would require a manual ceiling plane. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 30, 2023 Share Posted March 30, 2023 Just as Chopsaw said, delete the layers in Ceiling Finish in the Room Specification DBX. Make sure you have defined rooms so you can keep it to only the room you want exposed joists. Link to comment Share on other sites More sharing options...
ValleyGuy Posted March 31, 2023 Share Posted March 31, 2023 13 hours ago, carowe said: I am using X15 am drawing a 3 story house. The first floor has the floor joists showing - as in the picture below - but the remaining two floors have drywall ceilings. And, as you can see in the pic, there is a partial ceiling in this room as well where the skylights are. Thought it was figured out, but when I got the joists to display on the first floor, they did on all of the floors. Is there a way to do this? TIA! In order to have the nice white wall finish at the end of the floor joist.... room divide the main floor directly under the 2nd floor. In addition to removing the ceiling layers on the main floor, remove the upper floor structure (leave the subfloor and finished floor), just delete the joist material from the 2nd floor. Then manually draw in a floor beam at the 2x material size you want on Level 1, place the new beam at the edge of the room divider and adjust the heigh to the underside of the sub-floor, multiple copy and add in the additional things like ducting, blocking, etc and you are done. Put these newly made beams on a layer of their own and there is no need to turn on any other floor framing. Link to comment Share on other sites More sharing options...
carowe Posted March 31, 2023 Author Share Posted March 31, 2023 Thanks so much - got it!!! So appreciative of the help folks give on this forum!!! Link to comment Share on other sites More sharing options...
Ange822 Posted February 12, 2025 Share Posted February 12, 2025 I tried to remove the ceiling layer - but unfortunately the floor joists from above aren't showing. Also now have a blank area where the rim joist / floor joists would be at the sundeck. Any ideas? Link to comment Share on other sites More sharing options...
MPDesign Posted February 12, 2025 Share Posted February 12, 2025 Have you created the floor framing? Your 3rd picture shows that they don't exist yet. No red plus in the used column. Link to comment Share on other sites More sharing options...
robdyck Posted February 12, 2025 Share Posted February 12, 2025 3 hours ago, Ange822 said: Also now have a blank area where the rim joist / floor joists would be at the sundeck This seems like it would more likely be caused not having any deck framing, but not because of removing the ceiling in a basement room. Link to comment Share on other sites More sharing options...
Ange822 Posted February 12, 2025 Share Posted February 12, 2025 7 hours ago, MPDesign said: Have you created the floor framing? Your 3rd picture shows that they don't exist yet. No red plus in the used column. Thank you I had not! I don't typically use the framing functions but would like to start. I have specified "Lumber" as the type of floor joist, and it keeps showing as "I-Joist". Any ideas on why this is? I have tried "re-build framing" function. 4 hours ago, robdyck said: This seems like it would more likely be caused not having any deck framing, but not because of removing the ceiling in a basement room. Thanks Rob that did the trick! I have issues with the deck framing disappearing quite often. Not sure if this is a common pain point, I have tried looking up in forums and would like to start a new topic at some point. Link to comment Share on other sites More sharing options...
DBCooper Posted February 13, 2025 Share Posted February 13, 2025 Quote I have specified "Lumber" as the type of floor joist, and it keeps showing as "I-Joist". Any ideas on why this is? I have tried "re-build framing" function. In theory, that should work. Might be a problem with not setting it for the right room(s) or you set it for a floor but you are seeing a ceiling (or vice versa). I would usually set this up in my floor/ceiling defaults and then make sure all my rooms are set to "use default". If that doesn't help, you should post your plan and someone can look into it more. Link to comment Share on other sites More sharing options...
robdyck Posted February 13, 2025 Share Posted February 13, 2025 19 hours ago, Ange822 said: I have specified "Lumber" If you are changing this on a per room basis instead of for the entire floor, then you will also need to move the framing to the next group. Link to comment Share on other sites More sharing options...
Ange822 Posted February 21, 2025 Share Posted February 21, 2025 On 2/12/2025 at 7:12 PM, DBCooper said: In theory, that should work. Might be a problem with not setting it for the right room(s) or you set it for a floor but you are seeing a ceiling (or vice versa). I would usually set this up in my floor/ceiling defaults and then make sure all my rooms are set to "use default". If that doesn't help, you should post your plan and someone can look into it more. Okay great I finally got it to work! I used the default floor structure / re-built the framing. I really don't have much knowledge with the 3D automatic framing but would like to get a better understanding. On 2/13/2025 at 11:38 AM, robdyck said: If you are changing this on a per room basis instead of for the entire floor, then you will also need to move the framing to the next group. Hi Rob - I did try changing the group, but again don't have much knowledge here, I tried just doing #2? Maybe this also contributed to it working? Thank you everyone for your help! 1 Link to comment Share on other sites More sharing options...
