teewhite7 Posted July 18, 2021 Share Posted July 18, 2021 This probably wouldn't be an issue when a brick ledge isn't required but does anyone have tips on how to model a patio drop? For example, i have a covered rear patio, i need the footings to continue for the patio floor slab at the brick ledge depth. I'm able to model a 2" drop for the patio but when it reached the outer edge it auto places a curb to reach back to the floor level. I guess its kind of like a garage drop, how there's a curb around for the stud wall, but at the garage door it doesn't curb due to the garage door threshold Chief architect premier x13 Intel I9 10900k RTX 2080 super oc 32gb trident z royal 3600 Link to comment Share on other sites More sharing options...
Kbird1 Posted July 18, 2021 Share Posted July 18, 2021 Drop the Patio Floor the Depth of the Brick Ledge? Or as Eric mentioned post the plan and/or pics otherwise it is a guessing game , and not many want to play "20 Questions" Link to comment Share on other sites More sharing options...
teewhite7 Posted July 18, 2021 Author Share Posted July 18, 2021 Images of patio w/ & w/o walls & lowered the absolute elv. of the patio floor. Now granted, i can manually edit this one footing on the patio end to remove this curb, and model it to match the other footing depths but on any of my projects this seems to throw a ton of other things way off and it turns into a big mess elsewhere. I was just hoping there was something I'm missing in the auto/defaults because this is a pretty basic detail on mono slabs. Link to comment Share on other sites More sharing options...
rgardner Posted July 18, 2021 Share Posted July 18, 2021 On 7/18/2021 at 4:55 PM, teewhite7 said: Images of patio w/ & w/o walls & lowered the absolute elv. of the patio floor. Now granted, i can manually edit this one footing on the patio end to remove this curb, and model it to match the other footing depths but on any of my projects this seems to throw a ton of other things way off and it turns into a big mess elsewhere. I was just hoping there was something I'm missing in the auto/defaults because this is a pretty basic detail on mono slabs. Expand Lots of variables without seeing the plan file. If this doesn’t answer your problem your best bet is to provide the .plan file. My Guess: You already played with it before dropping the floor and manually adjusted that wall already. Open the wall dbx and select default wall top and bottoms and see if that fixes it. Otherwise too many variables to keep guessing. Link to comment Share on other sites More sharing options...
teewhite7 Posted July 18, 2021 Author Share Posted July 18, 2021 On 7/18/2021 at 5:59 PM, rgardner said: Lots of variables without seeing the plan file. If this doesn’t answer your problem your best bet is to provide the .plan file. My Guess: You already played with it before dropping the floor and manually adjusted that wall already. Open the wall dbx and select default wall top and bottoms and see if that fixes it. Otherwise too many variables to keep guessing. Expand Default wall top & bottoms are "greyed out" **attached plan patio slab.planFetching info... Link to comment Share on other sites More sharing options...
Kbird1 Posted July 18, 2021 Share Posted July 18, 2021 On 7/18/2021 at 7:24 PM, teewhite7 said: Default wall top & bottoms are "greyed out" Expand That tells you you have not "played" with the wall in 3D/elevation which isn't recommended as standard operating procedure....(SOP) in chief. Link to comment Share on other sites More sharing options...
teewhite7 Posted July 18, 2021 Author Share Posted July 18, 2021 Right, i dont think the other guy read what i wrote i CAN manually edit this into what i need but that defeats the purpose of what im trying to accomplish which is like you said SOP. *I keep my Autocad subscription because of stuff like this, if theres no way around manually editing a slab patio like this, i feel like its way faster to just do it on cad. I do like how CA implements a garage drop into the foundation build dialogue, if there was something similar for poch/patios that'd be great 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted July 18, 2021 Share Posted July 18, 2021 On 7/18/2021 at 8:25 PM, teewhite7 said: I do like how CA implements a garage drop into the foundation build dialogue, if there was something similar for porch/patios that'd be great Expand This Option works fine IF , you don't use the Auto Monoslab foundation. *Chief likes Monos all at the same floor Height Chief Cheats and does not actually build a monoslab it is really a stemwall foundation made with a 16" thick stemwall and a 4" height to match the slab thickness so I use the same method , only manually, then add a few CAD lines as needed eg if you need a chamfer where you are? it may still show issues in 3D though *I keep my Autocad subscription because of stuff like this, *** TurboCAD Deluxe is way cheaper.... Link to comment Share on other sites More sharing options...
glennw Posted July 18, 2021 Share Posted July 18, 2021 Assuming you want a mono slab. Select the Patio room and change the Stem Wall Top to -2". 1 Link to comment Share on other sites More sharing options...
teewhite7 Posted July 19, 2021 Author Share Posted July 19, 2021 AH i was afraid that was it, i'll just have to stick to doing them manually. Thanks for the tip on turbocad, i havent heard of that one. thanks Link to comment Share on other sites More sharing options...
rgardner Posted July 19, 2021 Share Posted July 19, 2021 On 7/18/2021 at 8:25 PM, teewhite7 said: Right, i dont think the other guy read what i wrote Expand No I did read it, however 95% of the time when something similar to this is posted here that is what it is caused by. Many will try to fix it and at one point actually fix it but the second that you manually adjust a wall in elevation the dynamic auto build heights are removed so even if the item gets fixed it won’t adjust the walls after that unless you have the default top and bottom heights selected. In your case since in the view you showed the other heights were correct that was a starting point to rule out the issue since we didn’t have a plan file. But what Glenn is showing above should get you to what you want. Link to comment Share on other sites More sharing options...
dshall Posted July 19, 2021 Share Posted July 19, 2021 On 7/18/2021 at 3:41 AM, teewhite7 said: This probably wouldn't be an issue when a brick ledge isn't required but does anyone have tips on how to model a patio drop? For example, i have a covered rear patio, i need the footings to continue for the patio floor slab at the brick ledge depth. I'm able to model a 2" drop for the patio but when it reached the outer edge it auto places a curb to reach back to the floor level. I guess its kind of like a garage drop, how there's a curb around for the stud wall, but at the garage door it doesn't curb due to the garage door threshold Chief architect premier x13 Intel I9 10900k RTX 2080 super oc 32gb trident z royal 3600 Expand does this help? set the curb height to-6" 1 Link to comment Share on other sites More sharing options...
teewhite7 Posted July 19, 2021 Author Share Posted July 19, 2021 Glennw, dshall, First off thanks a lot of the assist, but That drops the footing depth also Link to comment Share on other sites More sharing options...
SNestor Posted July 20, 2021 Share Posted July 20, 2021 @teewhite7 - Made a video related to your topic. Hope it helps you out. 3 3 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted July 20, 2021 Share Posted July 20, 2021 Nice training video, Steve, as usual. Link to comment Share on other sites More sharing options...
SNestor Posted July 20, 2021 Share Posted July 20, 2021 @Ridge_Runner - Thank Mike! Link to comment Share on other sites More sharing options...
georg102 Posted March 28, 2022 Share Posted March 28, 2022 On 7/20/2021 at 12:23 AM, SNestor said: @teewhite7 - Made a video related to your topic. Hope it helps you out. Expand Thank you for this Video. Exactly what I needed. !!!!! Link to comment Share on other sites More sharing options...
dshall Posted March 29, 2022 Share Posted March 29, 2022 Good vid Steve. I have a question, suppose you did not have a second pour group, how would that change the model? 1 Link to comment Share on other sites More sharing options...
SNestor Posted March 30, 2022 Share Posted March 30, 2022 On 3/29/2022 at 11:59 AM, dshall said: Good vid Steve. I have a question, suppose you did not have a second pour group, how would that change the model? Expand The "pour group" is only relative to the material list. The material list will segregate the materials for each "group". It doesn't change the outcome of the foundation construction. I probably should have mentioned that in the video...oops! Link to comment Share on other sites More sharing options...
dshall Posted March 30, 2022 Share Posted March 30, 2022 On 3/30/2022 at 12:04 PM, SNestor said: The "pour group" is only relative to the material list. The material list will segregate the materials for each "group". It doesn't change the outcome of the foundation construction. I probably should have mentioned that in the video...oops! Expand Thank Steve, however, remember when we were talking about the slab to raised foundation model.... you did discover that there may be an advantage to calling out a second pour...... but now I forgot how that work..... that also tied into the width of the stem wall which "The Rabbit" pointed out. I did not mean to muddle the thread..... to circle back the advantage to calling out a second pour was for the materials list Link to comment Share on other sites More sharing options...
HumbleChief Posted March 30, 2022 Share Posted March 30, 2022 From help - did not know this. "Slab Footings and the room areas that they define can be assigned Pour Numbers in their specification dialogs. Typically, a Slab Footing will have the same Pour Number as the room it defines, although it is possible for it to define multiple rooms with differing Pour Numbers. Pour Numbers are listed separately under the Foundation category of the Materials List." Link to comment Share on other sites More sharing options...
