HHHomes Posted March 24, 2021 Share Posted March 24, 2021 Question: Is it possible to have 2 different window schedules and only show the label from schedule #1 on the window AND also show that WXX number from schedule #1 on the 2nd schedule so that they NEVER get out of sync? Rather than each schedule having it's own WXX number that sometimes gets out of sync. 1st schedule on framing plan - limited info 2nd schedule on style/schedule sheet - full info (divided lites, 3D) etc. Link to comment Share on other sites More sharing options...
HHHomes Posted March 24, 2021 Author Share Posted March 24, 2021 To be more concise - I need 2 different window schedules with varying amounts of info which will be on two different layout sheets, but...I need 1 common window label number on the window itself (in elevations and plan view) and in the schedules so it's all unified. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 24, 2021 Share Posted March 24, 2021 That is definitely possible but there is the potential for them to get out of sync. You could leave both callouts turned on until the end to be able to quickly confirm they are the same and then just turn one off before printing. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 24, 2021 Share Posted March 24, 2021 There's a way to do it with just one Schedule and some tricky placement(s) in the Layout. I'll let you ponder that concept. Link to comment Share on other sites More sharing options...
stephenbc Posted March 24, 2021 Share Posted March 24, 2021 Perhaps you could use a custom object field like 'window-ID' (in the Window Specification) and bring that up in both schedules to keep the windows locked with one common identifier in both schedules.(that's, if I understand you correctly). Link to comment Share on other sites More sharing options...
rlackore Posted March 24, 2021 Share Posted March 24, 2021 Yes, it's easy if you use callouts for the labels: Create schedule #1. Duplicate schedule #1. Open schedule #2 and uncheck Labels>Use Callout for Label. This will give you two schedules, only one label (in both plan and elevation), perfectly in sync. 1 Link to comment Share on other sites More sharing options...
rgardner Posted March 24, 2021 Share Posted March 24, 2021 1 hour ago, rlackore said: Yes, it's easy if you use callouts for the labels: Create schedule #1. Duplicate schedule #1. Open schedule #2 and uncheck Labels>Use Callout for Label. This will give you two schedules, only one label (in both plan and elevation), perfectly in sync. Unless a window gets added or deleted, or moved in one schedule. Then it will be out of sync. 13 hours ago, HHHomes said: Question: Is it possible to have 2 different window schedules and only show the label from schedule #1 on the window AND also show that WXX number from schedule #1 on the 2nd schedule so that they NEVER get out of sync? Rather than each schedule having it's own WXX number that sometimes gets out of sync. 1st schedule on framing plan - limited info 2nd schedule on style/schedule sheet - full info (divided lites, 3D) etc. Best way I could see it would be to wait till the end of the con docs and then copy the schedule and change as is written here: 1 hour ago, rlackore said: Open schedule #2 and uncheck Labels>Use Callout for Label. then add and delete the information you want shown on the second schedule and send to layout. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 24, 2021 Share Posted March 24, 2021 Best way was already given here: 11 hours ago, Joe_Carrick said: There's a way to do it with just one Schedule and some tricky placement(s) in the Layout. I'll let you ponder that concept. Although not real tricky if you're down with copy/paste in place Link to comment Share on other sites More sharing options...
rlackore Posted March 24, 2021 Share Posted March 24, 2021 12 minutes ago, rgardner said: Unless a window gets added or deleted, or moved in one schedule. Then it will be out of sync. Yes, definitely a problem with this solution. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 24, 2021 Share Posted March 24, 2021 It would help if you could describe very specifically HOW the schedules are to be different. There are other ways of handling this using a single schedule. Link to comment Share on other sites More sharing options...
HHHomes Posted March 24, 2021 Author Share Posted March 24, 2021 The more pared down schedule is on the framing plane - single line height in the table and has 8 characteristics listed (columns) - I do this so I can add that schedule to the Arch D framing sheet and it still fit with most houses. The second schedule has a 3D image column and 3 more columns (arches, divided lites, panels), thus the line height in the table us MUCH more. Due to this, I don't think the "trick placement" method works. I like @stephenbc recommendation of applying a constant identifier to each window and referencing it on both schedules, that's what I'm wanting to do, but is there any way to have that done automatically and increment up? W01, W02, etc. or would it have to be manual? Link to comment Share on other sites More sharing options...
robdyck Posted March 24, 2021 Share Posted March 24, 2021 2 hours ago, HHHomes said: The more pared down schedule is on the framing plane - single line height in the table and has 8 characteristics listed (columns) - I do this so I can add that schedule to the Arch D framing sheet and it still fit with most houses. The second schedule has a 3D image column and 3 more columns (arches, divided lites, panels), thus the line height in the table us MUCH more. Due to this, I don't think the "trick placement" method works. I like @stephenbc recommendation of applying a constant identifier to each window and referencing it on both schedules, that's what I'm wanting to do, but is there any way to have that done automatically and increment up? W01, W02, etc. or would it have to be manual? Use the object information panel to group the info you want into less columns. Then you won't have the wasted paper issue that you get with Chief's schedule format. 1 schedule and a bit of copying and cropping in layout. Link to comment Share on other sites More sharing options...
HHHomes Posted March 30, 2021 Author Share Posted March 30, 2021 @robdyck - can you expound on this a bit? I'm not quite following. (UPDATE: I now understand what you are saying about grouping information) - BUT - is there a way to make a "schedule" type table without it auto assigning a schedule number so it won't automatically pick up in my label? Link to comment Share on other sites More sharing options...
Chopsaw Posted March 30, 2021 Share Posted March 30, 2021 1 hour ago, HHHomes said: is there a way to make a "schedule" type table without it auto assigning a schedule number so it won't automatically pick up in my label? Link to comment Share on other sites More sharing options...
