Lighthouse Posted October 19, 2020 Share Posted October 19, 2020 I'm suffering from eye strain and wonder if there is a way to change CA so the screen is black and the lines are white. A friend does this with Datacad, not sure if possible in CA? Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 19, 2020 Share Posted October 19, 2020 Of course, take a close look at "Edit - Preferences - Appearance" and other Default Settings as well but thereafter it may be difficult to share your plans with other users who do not do that. Another consideration is that "White Lines" will NOT print to paper or PDF, so your prints and PDF's by default will use a lot of Black ink to print. Basically you are intending to go into "Undiscovered Country" indeed. I know AutoCAD is set up with a black background but I am not aware of any Chief users who do so. DJP Link to comment Share on other sites More sharing options...
LevisL Posted October 19, 2020 Share Posted October 19, 2020 You would need to set up different layer sets and/or saved plan views. Some for viewing on screen with layer colors that can be viewed against a dark background, and some for printing with these same layers set to black (or whatever color you want printed). Link to comment Share on other sites More sharing options...
ericepv Posted October 19, 2020 Share Posted October 19, 2020 I've changed my colors to the 'Stone' theme which gives me a medium grey background for the toolbars and I also use a light grey background for drawing background. It is easier on the eye's. Link to comment Share on other sites More sharing options...
glennw Posted October 19, 2020 Share Posted October 19, 2020 As far as I know, having a black background does not affect sharing files with other users. Screen color is not saved with the file - it is a preference - each user will see their own background color. I don't think it has anything to do with printing either. Turn on Print Preview and I think you should see a white background even though you have a black background while drawing. Same for layout. A white line will not display on a black background, and I am pretty sure it will not print. A black line will display as white on a black background, but I am pretty sure it will print as black. 2 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted October 19, 2020 Share Posted October 19, 2020 On 10/19/2020 at 2:58 PM, DavidJPotter said: but I am not aware of any Chief users who do so. Expand @joey_martin I believe Joey does; maybe he will chime in as his plansets look great. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted October 19, 2020 Share Posted October 19, 2020 On 10/19/2020 at 5:38 PM, ericepv said: I also use a light grey background for drawing background. It is easier on the eye's. Expand Same here. Link to comment Share on other sites More sharing options...
Lighthouse Posted October 20, 2020 Author Share Posted October 20, 2020 thanks very much! I changed my background to gray and already feel better (placebo effect :-) But I think it will make a difference Link to comment Share on other sites More sharing options...
Lighthouse Posted October 20, 2020 Author Share Posted October 20, 2020 On 10/19/2020 at 5:38 PM, ericepv said: I've changed my colors to the 'Stone' theme which gives me a medium grey background for the toolbars and I also use a light grey background for drawing background. It is easier on the eye's. Expand Hmmm, I changed it in "edit preferences, appearance" which worked for plan view, but not camera views. I tried 3d preferences but don't see an option there. Is there a way to change screen color for all types of views? Also, you mentioned a stone "theme". I don't see themes, just colors. I'm in x10, maybe themes are a later version? Link to comment Share on other sites More sharing options...
joey_martin Posted October 20, 2020 Share Posted October 20, 2020 On 10/19/2020 at 4:26 PM, LevisL said: You would need to set up different layer sets and/or saved plan views. Expand I didn't. If your layers are set up to be "default" simply change the background color and the default black lines turn white automatically. It's the line that you have set to black per line that will not be visible. I only use black backgrounds. 1 Link to comment Share on other sites More sharing options...
Dermot Posted October 20, 2020 Share Posted October 20, 2020 Color themes are not available in X10. To change the background color for camera views, you will need to change this in your camera defaults under the backdrop panel. Link to comment Share on other sites More sharing options...
SunsetDrafting Posted October 8, 2021 Share Posted October 8, 2021 Windows 10, go to Color Filters, select "On" at Turn on color filters, Check Allow the short key to toggle filter on or off, next select "Grayscale inverted". Now unselect "Turn on color filters". You will now be able to draw with black screen and all text and dimensions white. This will require NO preferences changes in chief drawings. Use key combination "Windows logo key + Ctrl + C" to toggle between standard white back ground or black background with white text/dimensions. Also when using black screen, all items add will remain the same as if you are using standard white screen. Link to comment Share on other sites More sharing options...
EngelsmaHomes Posted November 29, 2022 Share Posted November 29, 2022 On 10/8/2021 at 3:32 AM, SunsetDrafting said: Windows 10, go to Color Filters, select "On" at Turn on color filters, Check Allow the short key to toggle filter on or off, next select "Grayscale inverted". Now unselect "Turn on color filters". You will now be able to draw with black screen and all text and dimensions white. This will require NO preferences changes in chief drawings. Use key combination "Windows logo key + Ctrl + C" to toggle between standard white back ground or black background with white text/dimensions. Also when using black screen, all items add will remain the same as if you are using standard white screen. Expand An alternative 3rd party tool is NegativeScreen. I like this because it has custom filters which can invert blacks and whites, and preserves colors (somewhat). See the screenshot below. Does anyone else want a dark theme? I posted it as a suggestion because I'm really hoping for one - if you want this feature too, please add your comment to the thread linked below so it can get noticed by the developers. Link to comment Share on other sites More sharing options...
Hannah2021 Posted January 16, 2024 Share Posted January 16, 2024 All, I have started inverting my screen color from my computer and not messing with my settings on chief. this keeps me producing without any double work and if I want to pop over to internet and look something up I have a keyboard shortcut to turn it off and then easily turn it back on. second picture is someones cad plan they are having me edit- the last is how the chief default layer colors appear. Link to comment Share on other sites More sharing options...
