Stair Tread at top Even with Floor?
wjmdes
  On 7/23/2020 at 3:06 PM, wjmdes said:
This is with a 2X12 joist, with a 2X10, there is not a whole lotta nailing space:)
Expand
A quick google search of "stair to deck connections" would show many appropriate connecting methods that resolve the 'nailing' issue. Just the thought of stair stringers end nailed or toe-nailed to a rim-joist is cringe-worthy.
  On 7/23/2020 at 3:23 PM, wjmdes said:
The strap @robdyck posted works, but luckily I have been doing 2X12 rim Boards on decks anyway, cause it does not meet Simpson's criteria with a 2X10.
Expand
That's right, and even with a 2X12, the rise would be limited to 7 1/8"...not quite enough for some installations. There are some fairly simple methods to add material below the rim joists in order to provide increased backer material. Easy enough to detail if necessary, but no doubt each carpenter may have their own preferences. Michael provided one nice example that's very simple to execute.
  On 7/23/2020 at 11:51 PM, robdyck said:
That's not a skill that has been evenly distributed.
Expand
You making Fun of us Builders ? :o :D
I usually drop the Rim Joist lower ie use 2x12 at the stairs if 2x10 joists and add a 2x6 under the top tread between the stringers as well and attach it through that with Structural Screws, absolutely no toe nailing of stringers ever...that is asking for trouble....
