wjmdes
Stair Tread at top Even with Floor?
Is there a setting to make the first (or last tread) even with the platform it connects to?
You should be able to set this in the Advanced Options in the stair DBX (see image). Keep in mind that the Top is actually the top of the uppermost riser, not the tread.
That does not do it....
You can do it..but you may have to get out the big stick and beat Chief to death...
@wjmdes -
What @solver said above.  If you have a runner you will probably have to remove it...
As Eric illustrated but didn't very clearly state...
You have to set the height manually.  Notice that he had to uncheck Auto Heights.
You will find that this method will give undesirable results with the railing. I'm not aware of an easy fix for this.
This is with a 2X12 joist, with a 2X10, there is not a whole lotta nailing space:)
A quick google search of "stair to deck connections" would show many appropriate connecting methods that resolve the 'nailing' issue. Just the thought of stair stringers end nailed or toe-nailed to a rim-joist is cringe-worthy.
I usually use some variation of this general idea...
The strap @robdyck posted works, but luckily I have been doing 2X12 rim Boards on decks anyway, cause it does not meet Simpson's criteria with a 2X10.
That's right, and even with a 2X12, the rise would be limited to 7 1/8"...not quite enough for some installations. There are some fairly simple methods to add material below the rim joists in order to provide increased backer material. Easy enough to detail if necessary, but no doubt each carpenter may have their own preferences. Michael provided one nice example that's very simple to execute.
Or...the stringer could continue up under the main platform and rest on the beam.
^^^ even better
2 hours ago, Ridge_Runner said:
^^^ even better
Although, it looks like it would require a bit o' thinking ahead. That's not a skill that has been evenly distributed.
You making Fun of us Builders ? :o :D
I usually drop the Rim Joist lower ie use 2x12 at the stairs if 2x10 joists and add a 2x6 under the top tread between the stringers as well and attach it through that with Structural Screws, absolutely no toe nailing of stringers ever...that is asking for trouble....
4 minutes ago, Kbird1 said:
You making Fun of us Builders:o :D
Definitely not 'us builders', it's 'those builders'!
Good save!:)
That's alright then :)  , but I  am unfortunately well aware of some of the work down by  "Those Builders"
M
    28448
    Burtonmadness
    Burtonmadness
