GeorgeDosil Posted May 29, 2020 Share Posted May 29, 2020 Hi, just joined, new user. I'm trying to model two intersecting gable roofs, where one will lay over the other...it's called a blind or California valley. I did a search here and online but cant find anything on this topic. Thanks beforehand for any help. Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 29, 2020 Share Posted May 29, 2020 Not familiar with that Name "California Valley" perhaps some of the CA users can help. Without a good graphic definition for that term it is hard to offer real help. Is the image below what you are wanting, please confirm. If it is, then this sort of thing is easy to accomplish either "Automatically" or manually. DJP Link to comment Share on other sites More sharing options...
DzinEye Posted May 29, 2020 Share Posted May 29, 2020 On 5/29/2020 at 11:57 AM, DavidJPotter said: Not familiar with that Name "California Valley" Expand On 5/29/2020 at 9:59 AM, GeorgeDosil said: .it's called a blind or California valley Expand Yep, I believe you got it David... generally referred to as California Framing. If you want it modeled that way then pretty sure you have to do some things manually. If it's a simple roof as stated (two intersecting gable roofs) I'd just auto-build then modify the underlying roof plane. Link to comment Share on other sites More sharing options...
robdyck Posted May 29, 2020 Share Posted May 29, 2020 On 5/29/2020 at 3:27 PM, DzinEye said: If it's a simple roof as stated (two intersecting gable roofs) I'd just auto-build then modify the underlying roof plane. Expand Nothing wrong with this of course, but it will produce incorrect roof data...if that matters to the OP. Generally, you'd still want your valleys to connect as Chief would typically and then you'd modify the framing. Keep in mind that Chief can't produce a horizontal seat cut on a rafter. A BIG difference between modelling the 'roof' or the 'roof framing'! The former is fast, while the latter is laborious! Link to comment Share on other sites More sharing options...
DzinEye Posted May 29, 2020 Share Posted May 29, 2020 On 5/29/2020 at 3:32 PM, robdyck said: Nothing wrong with this of course, but it will produce incorrect roof data...if that matters to the OP. Generally, you'd still want your valleys to connect as Chief would typically and then you'd modify the framing. Keep in mind that Chief can't produce a horizontal seat cut on a rafter. A BIG difference between modelling the 'roof' or the 'roof framing'! The former is fast, while the latter is laborious! Expand By 'data' I assume you're talking about materials list(s)? Right, of course that getting the framing to actually model correctly is a whole-nuther thing.... although not sure I'm following you on "you'd still want your valley's to connect" ?... There wouldn't be valley framing in the lower roof plane if it's California Framed. Link to comment Share on other sites More sharing options...
robdyck Posted May 29, 2020 Share Posted May 29, 2020 On 5/29/2020 at 3:39 PM, DzinEye said: There wouldn't be valley framing in the lower roof plane if it's California Framed Expand That's right. To clarify I was referring to the valley portion of the roof plane. In Chief, you'd still want those connected. Even if you were to carry the lower roof plane through, you'd still need to model the framing manually. They're all wrong! A roof runs through it: roofs connected at valleys: a separate roof plane underneath with the surfaces removed: Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 29, 2020 Share Posted May 29, 2020 I’ve typically modeled those overframes in one of 2 ways... -Manually using solids -Using trusses that are essentially just rafters (edited as necessary in truss detail). In both cases though I’ve typically used a Truss Base for underneath the over-frame area. Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 29, 2020 Share Posted May 29, 2020 On 5/29/2020 at 4:44 PM, Alaskan_Son said: Truss Base Expand +1 On 5/29/2020 at 3:54 PM, robdyck said: you'd still need to model the framing manually. Expand True, and if I need a blind plate then I make a roof plane produce it for me and take up most of the heavy lifting so I can manually manipulate it: Link to comment Share on other sites More sharing options...
GeorgeDosil Posted May 30, 2020 Author Share Posted May 30, 2020 On 5/29/2020 at 11:57 AM, DavidJPotter said: Not familiar with that Name "California Valley" perhaps some of the CA users can help. Without a good graphic definition for that term it is hard to offer real help. Is the image below what you are wanting, please confirm. If it is, then this sort of thing is easy to accomplish either "Automatically" or manually. DJP Expand David, I should have been more descriptive with my question. The California or Blind Valley is what you have pictured in your post. Instead of a valley rafter this method uses a valley plate to which all the jacks are attached to. Here is a photo and a Youtube link which shows it in Sketchup. Link to comment Share on other sites More sharing options...
GeorgeDosil Posted May 30, 2020 Author Share Posted May 30, 2020 On 5/29/2020 at 3:54 PM, robdyck said: That's right. To clarify I was referring to the valley portion of the roof plane. In Chief, you'd still want those connected. Even if you were to carry the lower roof plane through, you'd still need to model the framing manually. They're all wrong! A roof runs through it: roofs connected at valleys: a separate roof plane underneath with the surfaces removed: Expand That's exactly the problem. How would you draw the valley plate? The jack rafters have a horizontal as well as a bevel cut to match the plane of the main roof. Can Chief do this? Link to comment Share on other sites More sharing options...
GeorgeDosil Posted May 30, 2020 Author Share Posted May 30, 2020 On 5/29/2020 at 3:39 PM, DzinEye said: By 'data' I assume you're talking about materials list(s)? Right, of course that getting the framing to actually model correctly is a whole-nuther thing.... although not sure I'm following you on "you'd still want your valley's to connect" ?... There wouldn't be valley framing in the lower roof plane if it's California Framed. Expand If I had to make a choice, I'd prefer to have the model framed correctly vs having an accurate material take-off. Link to comment Share on other sites More sharing options...
GeorgeDosil Posted May 30, 2020 Author Share Posted May 30, 2020 On 5/29/2020 at 4:44 PM, Alaskan_Son said: I’ve typically modeled those overframes in one of 2 ways... -Manually using solids -Using trusses that are essentially just rafters (edited as necessary in truss detail). In both cases though I’ve typically used a Truss Base for underneath the over-frame area. Expand Do you have any photo's you can show of the finished model? I like the truss idea, I may try that. Link to comment Share on other sites More sharing options...
parkwest Posted May 30, 2020 Share Posted May 30, 2020 This is how we like to do it... Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 30, 2020 Share Posted May 30, 2020 On 5/30/2020 at 3:50 PM, parkwest said: This is how we like to do it... Expand David, is that a Sketchup view? Link to comment Share on other sites More sharing options...
parkwest Posted May 31, 2020 Share Posted May 31, 2020 On 5/30/2020 at 7:23 PM, Ridge_Runner said: David, is that a Sketchup view? Expand No. I do my framing using SoftPlan. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 31, 2020 Share Posted May 31, 2020 OK, thanks. Just curious. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 31, 2020 Share Posted May 31, 2020 On 5/30/2020 at 9:54 AM, GeorgeDosil said: Do you have any photo's you can show of the finished model? I like the truss idea, I may try that. Expand Chief's Training Video.... https://www.chiefarchitect.com/videos/watch/350/using-a-truss-base-to-truss-intersecting-roofs.html Link to comment Share on other sites More sharing options...
